Date/Time: Tue, 07 May 2024 01:23:40 +0000
VOLUME FILTERING
View Count: 1477
[2019-10-15 20:31:12] |
babatunde yusuf - Posts: 2 |
Hello, I am having difficulties in trying to get accurate volume filters for trade sizes that is set to a particular number say (trade greater than 99). However, I believe I am not getting accurate filter for this sizes.I am not sure if there is a settings in sierra chart that I need to change. I did a comparison with other platform (Investor R/T) and filter for the same size, I received lots more filter big lots sizes compared to sierra chart. Please assist me with fixing the problem I have attached an image of both filters for sierra and other platform using 7t reversal bar. |
2019-10-15_13-12-02.png / V - Attached On 2019-10-15 20:29:51 UTC - Size: 114.37 KB - 448 views 2019-10-15_13-12-56.png / V - Attached On 2019-10-15 20:30:00 UTC - Size: 152.38 KB - 388 views |
[2019-10-15 21:23:00] |
Make sure you are using the Volume Filter settings correctly: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) And you also need to switch to this data feed: Denali Exchange Data Feed After using this data feed re-download the data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. And then use this option: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
