Date/Time: Thu, 02 May 2024 11:57:48 +0000
Switched to Denali Exchange Data Feed
View Count: 870
[2019-10-12 19:25:04] |
gayer2428 - Posts: 75 |
Dear SC Support: I switched over to Denali Data Feed after market close yesterday (Fri), so did not get a chance to see if real-time trading works. My broker is Interactive Brokers. Could you please check out my data feed set-up and let me know if I have set it up properly, so I know I'm ready to trade Mon morning? Thank you. |
[2019-10-12 19:43:16] |
I meant to say: "...check out my account set-up...". Thanks.
[2019-10-13 09:46:02] |
Yes the data feed is set up properly. Also refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
