Date/Time: Thu, 02 May 2024 08:46:24 +0000
TPO value are transparent background
View Count: 940
[2019-10-12 11:27:12] |
RIFT - Posts: 124 |
I would like to make the value area transparent background on the Market Profile chart, as well as on the chart with the volume profile. I tried to do the "TPO Value Are Lines" study, it does not work, is there a way to do that? Thanks! |
2019-10-12_13h16_55.png / V - Attached On 2019-10-12 11:26:35 UTC - Size: 323.51 KB - 438 views 2019-10-12_13h03_40.png / V - Attached On 2019-10-12 11:26:48 UTC - Size: 367.02 KB - 344 views |
[2019-10-14 10:35:52] |
What is the purpose of making it transparent for a TPO Profile chart? It is also supported to color the letters themselves which are within the value area rather than the background. In the case of the Volume Value Area Lines you can use the transparent Fill Draw Styles. Refer to: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
