Date/Time: Fri, 03 May 2024 08:19:50 +0000
Saving and Loading Multiple Graphics Settings Configurations
View Count: 1324
[2019-10-10 06:45:44] |
nicktrader - Posts: 665 |
I have saved some Settings. Now I'd like to use these settings on my second PC. I can't find the files. What can I do to get the same settings on my second PC? |
[2019-10-10 09:07:38] |
Mack - Posts: 83 |
I'm sure you are aware that you can just copy your "C\SierraChart\Data" folder over to your second PC. This folder has your chartbooks. The Sierra3.cfg file is under "C:\SierraChart\" and contains most thing, including how you configured your control bars ie. Unfortunately, you can't read it with a text editor. But that file is extremely important. Date Time Of Last Edit: 2019-10-10 09:08:01
[2019-10-10 09:33:50] |
@Mack, cfg file is known but on my second PC I use some different setting. Therefore I thought it could be easier to copy/paste the mentioned settings. |
[2019-10-10 09:58:53] |
Mack - Posts: 83 |
Ideally, the Sierra3.cfg should be plaintext. That way we could put it under version control, also you could see what settings actually change between saves. I typically backup my whole C:\SierraChart\ folder, without the SCID files. |
[2019-10-11 16:30:16] |
The Graphics Settings configurations are contained within Sierra3.CFG and that is the file you need to copy.
