Date/Time: Wed, 08 May 2024 05:25:44 +0000
Footprints chart
View Count: 1444
[2019-10-07 17:29:26] |
User420291 - Posts: 44 |
How can i setup a chart like the attached file?
footprint chart.png / V - Attached On 2019-10-07 17:27:09 UTC - Size: 839.88 KB - 490 views |
[2019-10-07 19:13:03] |
GreegT - Posts: 23 |
Set column 1 to bid vs ask, turn the other columns off. Set it to highlight minimum and maximum. From there its just a matter of adjusting colors; such as, text range from grey to black, background off, etc
[2019-10-08 01:17:01] |
You will need to use the Numbers Bars study: Numbers Bars If you have no background with working with the Numbers Bars study, then you can download the following Chartbook which is setup to have a Numbers Bars study to give you an idea of how to get started: https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht Refer to the information here for how to use this Chartbook: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
