Date/Time: Thu, 02 May 2024 21:01:06 +0000
Chart Replay Issue
View Count: 560
[2019-10-06 11:57:04] |
User226793 - Posts: 160 |
Hi there, I need some help with the chart replay. I notice that when I hit replay, different charts show different values and the tick values in all the charts are not in synch. Could you please help me with this?
[2019-10-07 10:02:31] |
When you are starting the replay, what is the Charts to Replay setting set to? Also make sure the Session Times of all the charts are set identically: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-07 11:34:56] |
I have tried that as well..I have also linked all charts together...what is could be the issue
[2019-10-08 00:25:47] |
Are all the Session Times in the charts set identically and the Days to Load in Chart >> Chart Setting? The Days to Load setting does not need to be identical, but it needs to be set early enough, based upon the particular Date-Time the replay is started at. When you are starting the replay, what is the Charts to Replay setting set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 00:28:18
