Date/Time: Tue, 14 May 2024 12:48:41 +0000
VIX3M data
View Count: 865
[2019-10-01 23:38:09] |
JDMontero - Posts: 34 |
Hi, Do you have VIX3M? I see you have $VXV, but for some reason it loads Historic Daily charts, but in the present day, it does not update until the close. To summarize, I have in my chart: 200 days of $VXV in daily candles But the last candle will not appear until the close of that day. Upper left corner of the chart indicates "Symbol not found" Why is that? Is there a problem in the data? Can I use another index with the updated information? I see CBOE changed the name, could that have something to do with the problem? Please advise. I need to have the data of the constant measure of the 3-Month SP volatility. Reference http://www.cboe.com/products/vix-index-volatility/volatility-on-stock-indexes/cboe-3-month-volatility-index-vxv |
[2019-10-02 12:59:37] |
We see you are using the TD Ameritrade service. To access data for that symbol, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Real-Time Intraday Cash Index Charts You will need to pay the exchange fee and do not ask us further questions about that because this is what the exchange requires. We have no tolerance for questions surrounding exchange fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-03 17:07:21] |
Ok. Thanks. Also. Which is the Ticker for the Russell 2000 cash index? There is no $RUT, only RTY futures. And how could I set the RTY futures historical daily data to RTH 9:30 to 16:00, if I can't change the session time settings in chart settings when I use historical data? |
