Date/Time: Mon, 06 May 2024 09:47:38 +0000
Currenex not working with versions greater than 959
View Count: 1977
[2013-04-11 16:43:41] |
fxz - Posts: 32 |
Hi Currenex stops working when uograding version 959 to a 96x one Thanks |
[2013-04-11 17:35:20] |
Yes, we are aware of this. This is only in your particular case because SSL certificates are needed. Sierra Chart no longer uses stunnel. Sierra Chart now has its own SSL implementation. However we have not yet implemented support for client-side certificates (public keys). This will come. However, for now please go back to a prior version. Here is the documentation to use a prior version: http://www.sierrachart.com/index.php?l=doc/download.php#Rollback We apologize for this. We did not realize you would have updated so quickly although I guess that would be expected being there was a new version notice. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-11 17:48:43] |
fxz - Posts: 32 |
Ok i will stay on 959 in the meanwhile, please advice when ok to upgrade |
[2013-04-26 18:40:58] |
trading4roy - Posts: 6 |
Hi If possible Can you send em a screeenshot of your connection settings I can't connect with Divisa Currenex if not I understand Thank you |
[2013-04-26 20:11:38] |
They use a different protocol version. The settings they are using will not help you.
