Date/Time: Sun, 19 May 2024 02:58:02 +0000
Candle and time correlation
View Count: 598
[2019-09-18 13:59:38] |
User942178 - Posts: 25 |
I have my custom bar chart period set at 8 minute intervals. Why are the bars opening on the opposite 8 minute intervals? Example - bar period is 08:48 but new candle on my chart shows it opening at 08:44. How do I correct this. |
[2019-09-18 15:58:00] |
Refer to the following: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
