Date/Time: Thu, 02 May 2024 22:51:15 +0000
User Email Question
View Count: 1164
[2019-09-18 03:33:26] |
Sierra Chart - Max - Posts: 5599 |
Hi sir/madam, I would like to know if you offer subject data? A friend of mine is a student of Ricky Cheung Wing On (RC). I watched the interface and how he operates the software. User experience is satisfactory. Thanks. In addition, wonder if - tick data can be exported to Excel? - Sierra chart allows putting horizontal lines in different colors and patterns as support and resistance? Sierra Chart Support |
[2019-09-18 04:20:12] |
Whatever market data is used by RC Order flow, is offered. Tick by tick data can be exported and in a comma delimited format which can then be opened in Excel. Refer to: Exporting and Importing Intraday Data Files Horizontal lines can be drawn and are fully configurable: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-18 04:31:20] |
However, RC order flow DOESN'T use Hang Seng Index real time data (i.e. 30 ticks a minute). Wonder if Sierra provides it (not Futures)? Highly appreciated.
[2019-09-18 08:21:07] |
So you are looking for the Hang Seng cash index real-time data, not futures? The closest that Sierra Chart directly provides is a CFD. Refer to this service: Sierra Chart Real Time and Historical Forex and CFD Data Service The symbol is HKG33 You could also check with Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-18 08:22:25
[2019-09-19 00:21:38] |
Hi sir /madam,
Precisely I refer to Hang Seng Index real time tick, not futures nor cash index. Please see below. Hang Seng Index CLOSED Last Updated: Sep 18, 2019 4:09 p.m. HKST 26,754.12 -36.12 -0.13% Please let me know. I am happy to enrol SC if this index is available real time. Thanks. Sierra Chart Support |
[2019-09-19 04:26:01] |
Only the CFD symbol HKG33 is available. And the futures data is available to.
