Date/Time: Wed, 08 May 2024 23:25:49 +0000
How to adjust Automatically Rollover Futures?
View Count: 453
[2019-09-12 15:39:51] |
ComingHome - Posts: 18 |
SC, I've got the following two questions: 1. I have updated SC to Version 1982. And with that "E-mini Nasdaq Future" today already rolled over to DEC although I didn't want it. QUESTION: Is it possible to change it back to SEP ? 2. Prior to the SC update I have mentioned above the automatically rollover took place "1 day after the exchange rollover". Currently this would mean: The automatically rollover in SC should take place tomorrow on Friday 13.SEP (not today on 12.SEP) QUESTION: How is it possible to readjust this in SC to "1 day after the exchange rollover"? Thanks in advance for your help ! |
[2019-09-12 15:49:52] |
1. Yes. Refer to: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) You need to disable that option and then change the contract month in the Symbol field in Chart >> Chart Settings. 2. The correct rollover rules are being used for that symbol. However, refer to this setting to easily delay the rollover: General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 15:50:46
