Date/Time: Sun, 28 Apr 2024 06:17:16 +0000
TPOs Above/Below POC
View Count: 1328
[2019-09-11 22:09:35] |
User864956 - Posts: 9 |
Right click on the profile graph. http://www.sierrachart.com/image.php?Image=156823652553.png Study Settings, ESU19#1-Profile Period: 1 Days TPOs, Settings and Inputs, Ignore singles in TPOs above/below POC (ln:47) Yes Right click on the profile graph. http://www.sierrachart.com/image.php?Image=156823652553.png Split profile here. http://www.sierrachart.com/image.php?Image=1568238324500.png (3 arrows) F3 on the first splitted profile graph. (arrow 1) http://www.sierrachart.com/image.php?Image=1568240506514.png TPOs Above/Below POC : 6/0 F3 on the second splitted profile graph. (arrow 2) http://www.sierrachart.com/image.php?Image=1568240595638.png TPOs Above/Below POC : 6/0 F3 on the third splitted profile graph. (arrow 3) http://www.sierrachart.com/image.php?Image=1568240696794.png TPOs Above/Below POC : 6/0 In arrows 2 and 3 the TPOs Above/Below POC is not 6/0. It is not correct. It is only correct in arrow 1. I used it before and the TPOs Above/Below POC was OK in arrows 2 and 3. Now I see wrong data. Date Time Of Last Edit: 2019-09-11 22:25:31
[2019-09-12 05:11:15] |
One thing we notice is that you are mistaken, with what Chart Values belong to what TPO profile. The arrow you have is pointing to the wrong one. Example this is wrong: http://www.sierrachart.com/image.php?Image=1568240696794.png You can tell what profile it belongs to by looking at the "Period Start" field at the top. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 05:17:12
[2019-09-12 06:33:47] |
In the link you attached, I press left click on the split profile indicated by an arrow. Then press F3 and I get the TPO Chart Values you see next to the arrow. I don't understand why I see the "Period Start" field at the top says: 2019-09-11 15:30:00 instead of 2019-09-11 9:30. How can I see the "Period Start" field and the TPOs Above / Below POC that belong to this split profile indicated by an arrow? http://www.sierrachart.com/image.php?Image=1568240696794.png |
[2019-09-12 16:00:16] |
The problem is that you are using the Chart Values Window. You need to use the Tool Values Window. The Chart Values Window only gives you the information for the last displayed column in the chart. The Tool Values Window will give you the information for the item at which the crosshairs are pointing when in Tools >> Chart Values mode. If you want to use the keyboard to open the Tool Values Window, select Alt-V, otherwise select Window >> Tool Values Window. Refer to the information here: Window and CW Menus: Tool Values Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 22:30:52
