Date/Time: Wed, 08 May 2024 19:01:19 +0000
Denali datafeed and Daily Charts on intraday data basis
View Count: 727
[2019-09-08 12:32:40] |
User138602 - Posts: 169 |
If i setup a daily chart using the chart data type "intraday chart only", then i get a chart behavior i dont understand: Although loading 30 days of data (chart settings), the chart itself only display 6! daily bars. If i go into advanced settings and change the Continuous Contract setting to "none", then all 30 days get loaded/displayed. In both cases the box for Automatically Rollover Future Symbols got checkmarked (main chart settings). Does this mean the denali symbols get auotmatically rolled over on the server side? Edit: It doesnt apply to every symbol though. I checked equity indizes(SP500 and Nasdaq100) and it works as intented. But it is as described with 10 and 5Year US t-notes. Thx Date Time Of Last Edit: 2019-09-08 12:54:15
[2019-09-08 15:25:00] |
Re-download the data in the chart following these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data In both cases the box for Automatically Rollover Future Symbols got checkmarked (main chart settings). No. The documentation for that setting is here:Does this mean the denali symbols get auotmatically rolled over on the server side? Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-08 19:45:36] |
OK, Using AMP+CQG/Denali combination and downloading historical data failes for F.US.M6EZ19, for example. Can you confirm that? Edit: I just opened 11 different chartbooks for future contracts. EVERY single one of them had on its historical charts this red msg "Failed Download" poping up. Thats not normal. Date Time Of Last Edit: 2019-09-08 22:36:14
[2019-09-09 05:59:57] |
We think you have encountered the historical daily download limit for the day which is explained here at item 3: Continuous Futures Contract Charts: Limitations We are working on a proper solution for this limitation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-09 06:00:09
[2019-09-09 14:04:16] |
For now it works as expected. Didnt know about these limits. I adjust some CFD chartbooks to future contracts. The historical charts in there had MANY!!! days to load, because it didnt matter and never caused problems. I just trimmed it down in the settings and all is good today. Date Time Of Last Edit: 2019-09-09 14:05:08
