Date/Time: Sat, 04 May 2024 03:11:38 +0000
Line changed when chart period changing
View Count: 467
[2019-09-05 06:13:40] |
User392279 - Posts: 67 |
Hi, I find that the line is not consistent at different peroids. A few lower points connected at 4 hours period and then I change the peroid to 10 minutes. It is not not same dots connected. How to fix?
[2019-09-05 18:29:05] |
Refer to the information here: Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
