Date/Time: Sat, 04 May 2024 23:47:13 +0000
Request: control font size on text tools
View Count: 498
[2019-09-04 11:29:24] |
T44 - Posts: 363 |
Currently there is no ability to set the text side for retracement/projection tools - it defaults to 9pt "Segoe UI" which I find difficult to read. Thank you. |
[2019-09-05 00:51:18] |
This is not true. Refer to the following: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 00:51:49
