Date/Time: Sun, 19 May 2024 06:59:19 +0000
multiple TPO with corresponding Volume Profiles
View Count: 1021
[2019-09-04 00:04:25] |
User142613 - Posts: 4 |
Hello, I have read the setups and searched many posts (and found alot if good info too thank you) about how to create a volume profile. I cannot seem to make mine look like the attachments (from the SC posts). I want mine to look exactly (or close to exactly) like this picture I have attached. thank you
tpo_w-volume_example_2.png / V - Attached On 2019-09-03 23:59:53 UTC - Size: 96.38 KB - 421 views Attachment Deleted. tpo_w-volume_example.png / V - Attached On 2019-09-04 00:00:12 UTC - Size: 25.08 KB - 338 views |
[2019-09-04 09:01:47] |
The first step is to add a TPO Profile Chart study to the chart: Time Price Opportunity (TPO) Profile Charts: Basic Instructions Let us know when that is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-04 11:51:37] |
Hi, yes I have the TPO Profile Chart added. (30 min blocks, mult periods based on fixed time)
[2019-09-05 17:51:50] |
Therefore, you just simply add the Volume by Price study to the chart and it will be configured properly. Simply follow the instructions here: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-06 14:25:49] |
Getting close, I right aligned the Vol Profile but I need it separated from the TPO like the first picture example (so it's cleaner- not overlaid) thank you
2019-09-06_1022_w_volume.png / V - Attached On 2019-09-06 14:24:33 UTC - Size: 30.25 KB - 316 views tpo_w-volume_example.png / V - Attached On 2019-09-06 14:24:45 UTC - Size: 25.08 KB - 266 views Attachment Deleted. |
[2019-09-07 00:05:29] |
Chris_uk - Posts: 89 |
This is the input you need to change Time Price Opportunity (TPO) Profile Charts: Align Volume Profiles To TPO Profiles |
[2019-09-07 02:59:02] |
Yes you need to set this Input to No: Time Price Opportunity (TPO) Profile Charts: Align Volume Profiles To TPO Profiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
