Date/Time: Sun, 05 May 2024 07:46:48 +0000
Message Logging
View Count: 477
[2019-09-01 02:21:18] |
101010 - Posts: 18 |
Would it be possible to enable the option to disable visible message logging by default on startup? It's quite inefficient to have to select this in each instance of Sierra every time I restart.
[2019-09-04 09:14:08] |
What we will do is if you have this option enabled: General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log) The state of Window >>Disable Visible Message Logging will remain in its prior saved state. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
