Date/Time: Tue, 14 May 2024 07:25:29 +0000
Server Side OCO Orders
View Count: 2352
[2019-08-29 16:34:33] |
User34124 - Posts: 271 |
Thank you it all got working. Could you just please confirm regarding Attached Orders: Handling of Attached Orders when Sierra Chart Intermediary Server is Used That with Use Server Side OCO Orders and Use Server Side Bracket Orders BOTH unchecked, and with my FXCM GBP account, that attached limit and stop orders will be held on the intermediary server with Trading Technologies? Meaning if I close Sierra overnight, and the market happens to move to a Stop/Target, it will still get filled? |
[2019-08-29 18:42:26] |
You do not have a TT account. You have a FXCM account. With those options disabled, until the parent order fills, those orders are held within Sierra Chart on your computer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-31 10:57:56] |
So if Use Server Side OCO Orders is checked OR Use Server Side Bracket Orders is checked I can leave positions overnight, the weekend, or just turn my computer off, trusting that the SL/TP can be filled, as they are being managed at the intermediary server? Is there any difference between OCO orders or Bracket orders, or is the bracket just the term for the 'Offset' being fixed to parent order? |
[2019-09-02 12:48:17] |
Keep both of those options checked and the orders will be server-side when using the FXCM trading service.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 12:49:09
[2019-09-11 01:43:02] |
User256311 - Posts: 11 |
Hello sierra charts, I have both the "use server side OCO orders"& "uses server side bracket orders" ticked but this dose not seem to be working. I do not that it says ( if supported), can a clarify if sierra supports server side oco/bracket orders ? if so why would I be having these issues. |
[2019-09-11 06:20:05] |
You are using CQG. So server side bracket orders are not supported with CQG. If you want server-side bracket orders, switch over to this service which is available through AMP: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
