Date/Time: Sun, 19 May 2024 07:24:08 +0000
FreeDLL function
View Count: 569
[2019-08-29 05:53:12] |
User536105 - Posts: 36 |
I have set the codes FreeDLL to zero but found that does not bring out the smooth results(now when dragging the charts it is quite lagging) as comparing to those studies I built some months before. May I know the reason?
[2019-08-29 10:51:49] |
That variable is no longer used in ACSIL. For this issue, refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often And also how can we possibly answer your question. Asking why there is poor performance with your study or for some other reason, when there are millions of possibilities is simply an impossibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-29 11:11:15
