Date/Time: Sat, 18 May 2024 18:26:15 +0000
Multiple Rectangle configs drawing
View Count: 785
[2019-08-28 07:09:21] |
User590016 - Posts: 50 |
Hi, 1. Is it possible to set multiple buttons with different "draw rectangle" configs on the tab e.g (green filled rectangle, organge filled rectange, red filled rectangle) 2. If you draw different rectangle colors on the chart is it possible to deselect all the rectangles of the same color in one click? Thanks |
[2019-08-28 17:07:30] |
1. Yes. Refer to the following documentation for how to set this up: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step (Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step) 2. No, this is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-28 17:11:58
