Date/Time: Sat, 18 May 2024 20:20:54 +0000
[Programming Help] - Customize Label Column on DOM
View Count: 2234
[2019-08-27 13:26:24] |
User607115 - Posts: 1 |
I am using the Label study on my Sierra DOM and I would like to manually add notes at certain price levels. I'm coming from Jigsaw Daytradr software where you can click on the label column on their DOM and type characters that will appear in the label column so you can easily label all the levels you want. Is there a way to do this with Sierra Charts and unlock those cells so that I can enter information and have it remain there as a reference? And secondly, is there a way to load an excel csv worksheet that contains all the levels I want to label to have those values imported into the DOM and to appear on the label column? This is another feature that Jigsaw Daytradr had that I really like. I'm looking to make labeling my levels on the DOM quick and easy for me each morning before I begin trading. Thanks, Doug |
[2019-08-27 17:19:20] |
You can add a Horizontal line which can then have a label. Refer to: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line You will want to disable the Opaque Label Background option: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 17:24:07
