Date/Time: Sun, 19 May 2024 00:52:43 +0000
Volume double what it should be Error
View Count: 721
[2019-08-26 19:20:46] |
Woodzy - Posts: 30 |
I noticed when i reload a certain chart I have built, the volume data changes, so I opened a duplicate of the chart to compare volume live and it is different on the original by almost double per bar. Please see the image attached. I have created a complex chartbook so would rather not have to rebuild, what could be the basic reasons for this?
2019-08-26_2007_vol_issue.png / V - Attached On 2019-08-26 19:19:39 UTC - Size: 55.73 KB - 220 views |
[2019-08-27 02:01:38] |
Make sure those charts are not using volume filtering: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Make sure the Session Times are identical for both charts: Chart Session Times And are these charts both in the same running instance of Sierra Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 02:01:56
[2019-08-27 06:44:43] |
Yes I checked volume filtering that's what I first thought, and the session times are the same. The strange thing is that if I duplicate the chart in question, the volume on the new duplicated chart is fine. So I'm going to use the duplicate and will just have to update a few other studies which reference the problem chart, not as big a problem as I first thought
[2019-08-27 07:43:39] |
There must be something else going on that we are not aware of because what you are showing really is an impossibility. This just simply does not happen ever.
[2019-08-27 18:30:34] |
I couldn't find the exact problem but I had a lot of additional symbol studies on the ES chart (most hidden) of market stats NISS-NYSE, Tick etc. Once they were removed the volume of the main ESU19 chart was fixed, so I have just changed my chartbook around and spit all the market stats onto a separate chart. Probably too many studies on a single chart?
