Date/Time: Mon, 06 May 2024 20:34:59 +0000
Multiple Fill to Zero Bugs
View Count: 1442
[2013-12-09 11:06:46] |
esMike - Posts: 67 |
I didn't want to bug you guys with this, but after three bugs in Fill To Zero plotting it drove me crazy... Fill to Zero has three different bugs. 1. When the subgraph is at zero with DrawZeros = 0 or not... It will make a chopping up and down pattern instead of the fill disappearing. 2. When a subgraph data point is at zero it won't color properly. 3. When transitioning across the zeroline the color change is delayed or advanced a candle past where it transitions through the zeroline. It should be change color based upon if the fill is above or below the zeroline. For bugs 2-3... See screenshot! http://michaelyager.com/share/ftzBugs.png Date Time Of Last Edit: 2013-12-09 11:09:26
[2013-12-09 23:30:56] |
This is hard to understand because these are very fine details and it is also hard to understand what the images showing in relation to what you are writing. 3. We think we understand what you are saying here. The coloring will be based upon the subgraph value at each column and there is a fill which goes from the prior column to the column being drawn and the coloring is based upon the subgraph value at the column being drawn. The coloring will not be based upon whether the fill is predominantly within the positive area or not. It is based upon the subgraph value and we will not change that. That would be technically wrong based upon the logic used for coloring. If you are not happy with it, then set your own colors with the sc.Subgraph Data Color array. Do not rely upon us to do something which is not correct. There is not a bug here. You can disagree as much as you want, but we will not discuss this further and there shall be no changes with this. 1, 2. We will look these over when we have time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-09 23:32:46
