Date/Time: Tue, 07 May 2024 11:00:29 +0000
Technical Notice: Version 1059/1060 and TT FIX
View Count: 4037
[2013-12-06 20:28:34] |
Hello, While we were solving a problem with the symbol settings for CBOT symbols, when using TT FIX and the new Sierra Chart real-time futures data feed, this introduced a problem in 1059 where there was incorrect translation of the CME exchange to the CBOT exchange. The most obvious problem this would cause is that your current trade position may not display on a chart or Trade DOM. You may briefly see it and then it will go back to zero. Your current position can always be correctly viewed through Trade >> Trade Orders and Positions >> Positions. There is also the issue where when trading markets on the CBOT, in most but not all cases, the Exchange on the symbol should be CME instead of CBOT. In the File >> Find Symbol window, you would see the CBOT symbols listed twice. One for CME and one for CBOT. This has caused confusion. We have now comprehensively solved all of these issues. Please follow these instructions if you are using TT FIX or AMP/TTNet. 1. If you are running version 1059 or even 1060, please update by selecting Help >> Download Prerelease to get the very latest revision of 1060 which has the proper solution. 2. Go to Global Settings >> Symbol Settings. 3. Press the Full Reset button. 4. Press OK. 5. Wait for the symbol list to fill back up and then press OK. 6. Go through your charts and Trade DOM Windows for markets that are on the CBOT like the YM or ZB. On those charts and Trade DOM windows, select Chart >> Chart Settings. Press the Find button beside the Symbol box and reselect the symbol. This will ensure that the proper exchange suffix is used. This will either be CME or CBOT. For a particular futures market, you will only see one symbol listed. It will either be with CME or CBOT. 7. In some cases, and this is uncommon, you may need to uncheck Global Settings >> Data/Trade Service Settings >> Use CME Gateway for CBOT Symbols. Do not uncheck this option unless you are getting rejections when submitting orders. If you change this option you need to reconnect to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-06 20:33:40
[2013-12-06 20:34:45] |
If you have any questions, please post them here.
[2013-12-07 13:01:15] |
salsem - Posts: 43 |
12/06/2013 problems With SC/TTNet versions 1059 and 1060 I had problems with SC / TTNet in the orders placed. current trade position may not display on a chart or Trade DOM. You may briefly see it and then it will go back to zero. SC / TTnet version 1059 in an order positions >> positions the orders were visible I updated the 1060 issue that gave me 2 open positions with ES while in reality I was flat. yesterday i negotiated these symbols futures : ES,YM,6C,NQ Waiting for a response and solution at this problem Thanks in advance Date Time Of Last Edit: 2013-12-07 13:44:14
[2013-12-07 21:32:31] |
There could not be a case where Sierra Chart would indicate a position in the Trade >> Trade Orders and Positions >> Positions tab when you do not have one unless the server was indicating that. Is there incorrect position displayed on Trade >> Trade Orders and Positions >> Positions? If so, report this to your broker. We recommend resetting the Trade Position data so any invalid symbols are removed from the list. Here are the instructions for that: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#ResetPositionForSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-07 21:33:21
[2013-12-08 10:19:05] |
Hello Support SC , my broker AMP said that are flat, SC 1060 (- 2 order open ) Date Time Of Last Edit: 2013-12-08 10:20:38
SC TTNet orders and positions.jpg / V - Attached On 2013-12-08 10:18:41 UTC - Size: 84.47 KB - 493 views |
[2013-12-08 11:04:46] |
This is a different kind of issue. This is the Trade Stats for Charts tab. Refer to the documentation here to clear that data: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#TradeStatsResettingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-09 10:12:05] |
with version 1061 I tried to clear that date http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#TradeStatsResettingData ,but the problem has remained Friday I had big problems with the 1059 version from view orders placed on these futures: ES, YM, NQ and 6C previous version 1058 has not problems trade stats for charts and visual orders placed live |
[2013-12-09 14:48:02] |
Sawtooth - Posts: 3993 |
After updating to v1061 and doing a Full Reset of Symbol Settings, the YM-201312-CBOT chart reports Symbol is Unknown..., and does not update realtime. If I uncheck 'Use CME Gateway for CBOT Symbols' the YM-201312-CBOT will update realtime, but it still reports Symbol is Unknown... Please advise. |
[2013-12-09 16:00:13] |
scunagin - Posts: 7 |
After following the steps above for AMP/TTNet, specifically the YM - CBOT, the intraday chart is showing one huge bar (400 Tick) for today's data so far. When swithching that intraday chart back to the CME Gateway symbol (thought there should only be one symbol for the YM after following the steps above), the chart shows correctly(or more correct anyways). I have run through the entire process twice now with the same outcome, so I am asking for a little help. What have I done or what have I missed?
[2013-12-09 16:26:41] |
Responses Post #7: Completely clear the Trade Activity data for the symbol that your position is flat for following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ClearingtheLog This is all you need to do. This is what the documentation indicates to do in this particular case. The Trade Stats for Charts tab should not be relied upon to show your accurate position. It can be wrong because it has a dependency upon order fills and those could sometimes be missed for different kinds of conditions. Post #8: You need to uncheck 'Use CME Gateway for CBOT Symbols' and reconnect to the data feed. You may still see the Symbol is Unknown message continue to appear for up to 30 seconds even after unchecking that option and reconnecting. Disregard that. Post #9: Do not use the CBOT symbols. Only the CME symbols. We had not released the updated settings for AMP/TTNet. We have now. If there is a problem with the data in the chart re-download it by selecting Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-09 16:28:25
