Date/Time: Sun, 19 May 2024 08:28:59 +0000
Color Study Bar - Functions
View Count: 1136
[2019-08-10 18:47:29] |
a Gem Tree - Posts: 60 |
I have been using the "LARGE()" Function in SS. I'm curious if I can use anything like that in color bar alert study. |
[2019-08-10 23:11:53] |
This function is supported with Simple Alerts which is used by the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#LARGE_Function But you need to give it a range of data by using this method here: Study/Chart Alerts And Scanning: Referencing A Range of Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-10 23:12:32
