Date/Time: Sat, 18 May 2024 19:51:35 +0000
RR (0,1,N0)
View Count: 634
[2019-08-01 18:05:43] |
3152sier - Posts: 46 |
hello Sierra Charts after last update i have these numbers appear on the chart; how can i remove them please let me know. thank you |
UploadImage.png / V - Attached On 2019-08-01 18:05:01 UTC - Size: 29.67 KB - 280 views |
[2019-08-02 04:41:06] |
We will want to uncheck this option in the Study Settings window: Chart Studies: Subgraphs Tab >> Display Input Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-02 04:43:12
[2019-08-03 05:32:58] |
thank you but some letters and numbers still remain
UploadImage.png / V - Attached On 2019-08-03 05:28:23 UTC - Size: 29.3 KB - 287 views |
[2019-08-03 11:30:18] |
Refer to: Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-03 19:17:10] |
it was bar count and i removed using the customize chart header under global settings thank you Sierra Charts for your fast response and help |
[2019-08-04 07:38:26] |
Ok understood. We did not recognize it that way. We thought it was a Subgraph Name and Value.
