Date/Time: Sun, 19 May 2024 11:05:25 +0000
Data missing for NQ and MNQ
View Count: 556
[2019-08-01 15:28:21] |
User968625 - Posts: 256 |
Hello, I have my data feed with you and NQ and MNQ are not loading yesterday action after 12. it is like everything from yesterday 12 until this morning didn't happen. all other dats is working and I tried to download the data. Thank you |
[2019-08-01 19:14:17] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Right-click on the chart before the missing data and select "Edit >>Delete And Download Data". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-01 19:14:58
[2019-08-02 11:32:46] |
I got the window "Interday Data Editor) (see the image) not sure what to do. this the first time I have this window come up |
Interday Dat Editor Msg.png / V - Attached On 2019-08-02 11:32:36 UTC - Size: 20.3 KB - 224 views |
[2019-08-02 18:28:01] |
What about the Intraday editor? This is displaying because you opened it through the Edit menu.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-02 18:28:18
[2019-08-02 18:55:27] |
It comes out from both when I right-click and when I go to Eidt
