Date/Time: Sun, 19 May 2024 09:47:33 +0000
Customize Chart/Trade DOM Columns
View Count: 894
[2019-08-01 14:27:09] |
User98657 - Posts: 304 |
I'm having an issue opening Trade>> Customize Chart/Trade DOM Columns. It is trying to open. It acts like its open in that it locks up the chart/DOM, but i can't see it. Using Version 1957 64-bit (27856M) |
[2019-08-01 21:23:56] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display (30.40) We will add a patch to the next release to solve this Microsoft issue. But the patch we are going to add will cause the window to show at the top left of your desktop rather than be centered. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
