Date/Time: Mon, 13 May 2024 10:14:20 +0000
Real Time Data Activate
View Count: 551
[2019-07-30 16:25:24] |
BradTrader - Posts: 3 |
Hi I have purchased IQ Feed and it is activated but it is not Real Time. What do I need to purchase to have realtime data reflect on my charts?
[2019-07-30 17:41:35] |
In regards to IQ Feed you need to contact IQ Feed about this. The only thing you need to do on the Sierra Chart side is follow the instructions here: DTN IQ Feed Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-30 20:52:06] |
Hi I have real time data with IQFeed already however real time data is not reflecting in my charts with Sierra. What is the solution so my charts show real time data?
[2019-07-30 22:55:04] |
There is nothing you need to do in Sierra Chart in regards to this and this is not within our control. Can you please tell us why you are using IQ Feed? We recommend using our own data feeds which we can support much much better: Sierra Chart Exchange Data Feed Denali Exchange Data Feed They are better and cost less. Although there could be a problem where the chart is not scrolled to the end or the session times are filtering out the data. Refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Or perhaps you are using the wrong symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-30 22:55:58
