Date/Time: Mon, 13 May 2024 14:56:14 +0000
Erase
View Count: 586
[2019-07-29 23:05:58] |
John Ara - Posts: 125 |
Please let me know if there is a way to select multiple drawings at a time in order to erase them. Thank you. |
[2019-07-30 03:00:02] |
You just need to go to the Erase Drawings Mode: Chart Drawing Tools: Erasing Chart Drawings And then you can just click on the drawings one at a time and erase them. You can also do a bulk delete through the Manage Chart Drawings window and multiple select drawings there: Chart Drawing Tools: Manage Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
