Date/Time: Sun, 12 May 2024 19:03:08 +0000
New Amp customer, can I?
View Count: 565
[2019-07-26 19:08:21] |
Brenster - Posts: 15 |
install Sierra on both my computers to trade with the same login credentials?
[2019-07-26 19:13:41] |
SC Support - Posts: 1801 |
Yes that is correct
[2019-07-26 19:19:54] |
You certainly can install Sierra Chart on two different computers and be logged into those instances of Sierra Chart at the same time. But CQG is not going to allow more than one connection at the same time to their system. If you want to use both installations at the same time you need to use this service instead of CQG: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 19:20:09
