Date/Time: Wed, 15 May 2024 12:35:27 +0000
Some study bars not being shown until study is reloaded
View Count: 627
[2019-07-24 01:40:07] |
User29419 - Posts: 14 |
I have a Bid/Ask Depth bars study loaded to a volume chart. Sometimes the study will not plot when the volume chart adds a new bar (circled area in top image of the attached file), but if I reload the study, the study bars are shown (circled area in the bottom image of the attached file). Is there a setting that would force the study to re-plot when a new bar is formed? Thank you |
Private File |
[2019-07-24 05:00:38] |
There has been a significant improvement with this study. You need to update to the latest release which is now 1957. Although you are using Transact and the data feed that the new version supports with Transact has a problem that still has to be worked out by Transact. So you need to wait a while before updating. However, you may need to use this data feed for precise millisecond timestamp support for the market depth data: Denali Exchange Data Feed Millisecond time stamping is not supported with Transact. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-24 05:02:39
[2019-07-24 12:22:33] |
Thanks for you response. Does the Denali data feed also support use of the function sc.GetBidMarketDepthStackPullValueAtPrice()? Also, related to the Stack/Pull data, is there a way to sum the total volume stacked or pulled while a bar is forming rather than just plotting the last value? |
[2019-07-24 18:00:15] |
Does the Denali data feed also support use of the function sc.GetBidMarketDepthStackPullValueAtPrice()? Also, related to the Stack/Pull data, is there a way to sum the total volume stacked or pulled while a bar is forming rather than just plotting the last value? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-03 19:55:11] |
Related to the prior response to my question. Also, related to the Stack/Pull data, is there a way to sum the total volume stacked or pulled while a bar is forming rather than just plotting the last value? Yes, we plan to add this. Has this functionality been added with recent enhancements to the Bid & Ask Depth Bars study or has it been added as a part of other updates? If not is there an estimate of when that will be completed and how a user will know once it is done? Thank You. |
