Date/Time: Sun, 01 Nov 2026 19:34:10 +0000
[User Discussion] - chart Download
View Count: 2431
[2013-12-03 20:45:38]
tellerbe - Posts: 109
I am trying to run my charts at a dialysis center. I can get on the internet through their Wi-Fi. When I try to download my charts, I get a screen that says "Could not connect to server." I think they have some kind of block on their computer. Do you have some idea what it might be. What should I tell them to unblock so I can download my charts.
T Ellerbee
[2013-12-03 21:31:51]
Could you provide us a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
Or is the problem that you cannot even log into Sierra Chart and make it past the Login window?
[2013-12-04 14:48:42]
I cannot log in. I get a screen that says,"Failed to connect to server". I'll try to send the Message log later today.
TE
[2013-12-05 02:33:05]
If you are able to get to the Message Log, then this means you have successfully logged into Sierra Chart and if you need help connecting to the TransAct data and trading server you will need to contact TransAct support about this.
[2013-12-05 16:38:48]
I cannot post the Message Log. I cannot connect to the server when I am at the dialysis center.
TE
[2013-12-06 16:48:55]
Software version: 1051 | 2013-12-06 11:26:49
Enabled for: Sierra Chart Historical Data Service. | 2013-12-06 11:26:49
Active service: TransAct | 2013-12-06 11:26:49
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-06 11:26:49
2013-12-06 11:26:49 Local computer clock time | 2013-12-06 11:26:49
2013-12-06 16:26:49 GMT time | 2013-12-06 11:26:49
2013-12-06 11:26:49 Time zone adjusted time | 2013-12-06 11:26:49
Time difference to server time: 10 seconds. | 2013-12-06 11:26:49
Program path: C:\SierraChart\ | 2013-12-06 11:26:49
Data Files path: C:\SierraChart\Data\ | 2013-12-06 11:26:49
OS Version Number: 6.1 | 2013-12-06 11:26:49
Checking for new symbol settings for ta | 2013-12-06 11:26:49
Transact DTC - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2013-12-06 11:26:54
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-06 11:26:55
The network socket is connected. | 2013-12-06 11:26:55
Transact DTC: Connected to server. | 2013-12-06 11:26:55
DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-06 11:26:55
DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-06 11:26:55
Transact DTC: Sending logon request message. | 2013-12-06 11:26:55
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-13 16:17:00. Next Bar Date Time: 2013-11-13 15:53:14. Filename: C:\SierraChart\Data\TFZ3.scid | 2013-12-06 11:27:06
HD Request # 2 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: ta | 2013-12-06 11:27:06
HD Request # 2 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:27:07
HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2013-12-06 11:27:07
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-06 11:27:07
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-25 16:00:00. Next Bar Date Time: 2013-11-25 15:53:35. Filename: C:\SierraChart\Data\TFZ3.scid | 2013-12-06 11:27:07
Transact DTC: Market data feed reported to be lost. | 2013-12-06 11:27:16
Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-06 11:27:16
Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-06 11:27:16
Transact Futures - Connection error: Unknown Error Code: 60. | 2013-12-06 11:27:16
Transact Futures: Disconnected from the server. | 2013-12-06 11:27:16
HD Request # 2 - Error downloading historical Intraday data for NQZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:27:27
HD Request # 2 - Received 0 records and wrote 0 records for NQZ3 | 2013-12-06 11:27:27
HD Request # 3 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: ta | 2013-12-06 11:27:27
HD Request # 3 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:27:27
HD Request # 3 - Using server: ds3.sierracharts.com port 10149 | 2013-12-06 11:27:27
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-06 11:27:27
HD Request # 3 - Error downloading historical Intraday data for NQZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:27:47
HD Request # 3 - Received 0 records and wrote 0 records for NQZ3 | 2013-12-06 11:27:47
HD Request # 4 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: ta | 2013-12-06 11:27:47
HD Request # 4 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:27:47
HD Request # 4 - Using server: ds4.sierracharts.com port 10149 | 2013-12-06 11:27:47
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-06 11:27:47
Error received in OnConnect while connecting. Windows error code 10038: An operation was attempted on something that is not a socket. | 2013-12-06 11:27:48
HD Request # 4 - Error downloading historical Intraday data for NQZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:27:48
HD Request # 4 - Received 0 records and wrote 0 records for NQZ3 | 2013-12-06 11:27:48
HD Request # 4 - Intraday download COMPLETE for NQZ3 | 2013-12-06 11:27:48
HD Request # 5 - Downloading Intraday chart data for TFZ3 to the file TFZ3.scid. Service: ta | 2013-12-06 11:27:48
HD Request # 5 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:27:48
HD Request # 5 - Using server: ds5.sierracharts.com port 10149 | 2013-12-06 11:27:48
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-06 11:27:48
Error received in OnConnect while connecting. Windows error code 10038: An operation was attempted on something that is not a socket. | 2013-12-06 11:28:08
HD Request # 5 - Error downloading historical Intraday data for TFZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:28:08
HD Request # 5 - Received 0 records and wrote 0 records for TFZ3 | 2013-12-06 11:28:08
HD Request # 6 - Downloading Intraday chart data for TFZ3 to the file TFZ3.scid. Service: ta | 2013-12-06 11:28:08
HD Request # 6 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:28:08
HD Request # 6 - Using server: ds3.sierracharts.com port 10149 | 2013-12-06 11:28:08
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-06 11:28:08
Error received in OnConnect while connecting. Windows error code 10038: An operation was attempted on something that is not a socket. | 2013-12-06 11:28:09
HD Request # 6 - Error downloading historical Intraday data for TFZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:28:09
HD Request # 6 - Received 0 records and wrote 0 records for TFZ3 | 2013-12-06 11:28:09
HD Request # 7 - Downloading Intraday chart data for TFZ3 to the file TFZ3.scid. Service: ta | 2013-12-06 11:28:09
HD Request # 7 - Last Date-Time in file: 2013-12-06 10:05:21.0 | 2013-12-06 11:28:09
HD Request # 7 - Using server: ds4.sierracharts.com port 10149 | 2013-12-06 11:28:09
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-06 11:28:09
HD Request # 7 - Error downloading historical Intraday data for TFZ3. The network socket has been closed. Retrying download. | 2013-12-06 11:28:29
HD Request # 7 - Received 0 records and wrote 0 records for TFZ3 | 2013-12-06 11:28:29
HD Request # 7 - Intraday download COMPLETE for TFZ3 | 2013-12-06 11:28:29
[2013-12-06 18:01:20]
Follow the instructions at the bottom of this page here to use port 80:
http://www.sierrachart.com/index.php?l=doc/helpdetails41.html#UsingPort80
For help to connect to TransAct please contact TransAct support about this:
http://www.transactfutures.com/ContactUs.htm
Once you are able to get the successful connection then go to the TFZ3 chart and select Edit >> Delete All Data and Download.
[2013-12-09 18:23:22]
I tried port 80 and it did not work. TE
[2013-12-09 18:27:21]
OK, if it does not work it does not work. We cannot continue to struggle with this. We have helped you all we can. If you cannot get connectivity from that location it does not work.
