Date/Time: Wed, 29 May 2024 06:20:23 +0000
Pivot Points
View Count: 516
[2019-07-16 23:49:31] |
Jeffrey S - Posts: 42 |
How do I remove the previous Pivot Points and have only the current PPs appear?
[2019-07-17 07:57:36] |
You need to set the Draw Style for those other Subgraphs to Ignore: Chart Studies: Subgraphs Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
