Date/Time: Mon, 06 May 2024 09:37:12 +0000
sc.GetAskMarketDepthNumberOfLevels() and sc.GetAskMarketDepthEntryAtLevel()
View Count: 971
[2019-07-16 09:33:59] |
User132748 - Posts: 159 |
Regarding your updates on Depthbars study (not using T&S anymore) do you also plan on changing data pulling method of sc.GetAskMarketDepthNumberOfLevels() and sc.GetAskMarketDepthEntryAtLevel() functions?
[2019-07-16 21:38:17] |
No nothing is going to change with those functions. Later ACSIL will be able to access the same data that the Bid and Ask Depth Bars does.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-16 21:38:23
[2019-07-17 08:06:21] |
Could you elaborate what kind of data structure are Depthbars based on now since they dont use T&S anymore? And what kind of data would be available through ACSIL? Depthbars OHLC or its full underlying data? Thanks |
[2019-07-18 06:53:19] |
User136422 - Posts: 33 |
Could you elaborate what kind of data structure are Depthbars based on now since they dont use T&S anymore? And what kind of data would be available through ACSIL? Depthbars OHLC or its full underlying data? +1 |
[2019-07-18 07:44:35] |
We can only say that the calculations are based on every change to the market depth data.And what kind of data would be available through ACSIL? Depthbars OHLC or its full underlying data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 17:28:47] |
Any ETA on accessing depthbars data from ACSIL? Thanks
[2019-08-19 19:46:39] |
We have no idea at this point in time. It is definitely not coming in the short term.
[2019-08-29 08:29:18] |
Forward - Posts: 62 |
Hello,with the new version ( i am using 1978 64bit) the " Bid&Ask Depth Bars " doesn't appear on the screen. I can see his numbers change but not the indicator. Please , see the pic. |
2019-08-29_101027.jpg / V - Attached On 2019-08-29 08:26:26 UTC - Size: 102.37 KB - 276 views |
[2019-08-29 19:52:23] |
We see you are using IQ Feed. We tested this with IQ Feed and we do see the bars: http://www.sierrachart.com/image.php?Image=1567108328854.png Remove the study from the chart and add it again. And go to File >> Open Market Depth Window: File Menu: Open Market Depth Window (File) And let us know if you see 10 levels of depth. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-29 19:53:02
