Date/Time: Mon, 29 Apr 2024 11:47:15 +0000
How to open a stock not in the list
View Count: 1489
[2013-12-03 07:53:22] |
bercor - Posts: 30 |
Hello! Please tell me how you could insert a thiol equity that is not listed in the Sierra? I state that the data stream is INteractivebrokers .. For example, I would put the title tiker AAPL Apple in U.S. market ENI and the title ...... Italian ENI market tickers Thanks to those who want to give me a hand! hello |
[2013-12-03 08:07:31] |
You do this through File >> Find Symbol. Manually enter the symbol into the Selected Symbol box. Here are the symbol formats: http://www.sierrachart.com/index.php?l=doc/IBSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-03 15:26:08] |
Thanks for the link ... but I have found this in your manual that is more explanatory. http://www.sierrachart.com/index.php?l=doc/IBSymbols.html ENI-STK-BVME I tried with ENI and works with chart-hours minutes etc but not with graphic foot print as the attached chart "1 sierra." also attached chart "2 sierra" of ENi where I can not make the setting as in Figure 1 thanks |
[2013-12-04 01:52:03] |
We do not see any attachments here. Interactive Brokers does not provide the proper data for the Numbers Bars study.
[2013-12-04 08:35:22] |
Here .. attachments! Excuse me but I was wrong. I use IQFeed data for futures but also SIERAA connect with IB, but that 'provides the data for the futures! Are you telling me that instead do not provide for U.S. equities and Italian? IF so 'would you tell me who kindly providing these data for U.S. equities and ITALIAN be able to view and study Bars Numbers? thanks I attach the charts Date Time Of Last Edit: 2013-12-04 08:37:17
1 sierra.png / V - Attached On 2013-12-04 08:31:16 UTC - Size: 10.05 KB - 419 views 2 sierra.png / V - Attached On 2013-12-04 08:31:27 UTC - Size: 98.98 KB - 405 views |
[2013-12-05 03:16:24] |
Probably you will need to use Interactive Brokers for Non-US stocks and stay connected as much is possible to TWS to build up the Bid volume and Ask volume data for Numbers Bars.
