Date/Time: Sun, 28 Apr 2024 15:53:14 +0000
stochastic 70/30 indicator line
View Count: 1123
[2019-07-08 14:08:48] |
User106601 - Posts: 17 |
please tell me how to show overbot oversold on the %k line of stochastics, for the life of me I can not figure it out; ty very much |
[2019-07-08 18:40:18] |
Make sure the Draw Style for those Subgraphs of the Stochastic study that you are using are set to a visible style: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-08 18:40:30
[2019-07-09 01:26:12] |
Sir: thankyou for responding. but I am not getting it. Maybe I did not explain my request properly: Using a normal slow stochastic indicator, I would like the %K line to change to a different color when it goes into the 70 zone( green) and into the 30 zone (red). but renmain the neutral color (black) when it is not in those zones. Sorry for not understanding your message; billm |
[2019-07-09 05:07:47] |
This can be done with the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition Be sure to refer to this particular section on that page as well: Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies (Coloring Subgraphs of Other Studies) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-09 05:11:16
[2019-07-11 02:16:00] |
This is very confusing I am unable to figure it out, there are no places to indicate the 70/30 coloring, When I go thru the process nothing changes nothing seems to activate. this should be such a simple thing to do,, is there any place on the site that has this indicator set to overbot, oversold that I can go to and see how it is done????? I sorry to continue to bother you, maybe this is just not possible...thankyou
[2019-07-11 02:44:05] |
It is possible. Actually you need 2 instances of the Color Bar Based on Alert Condition study to do two different colors. We will put together an example tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-11 17:30:15] |
We have put together a Study Collection that has the Stochastic - Slow study along with 2 Color Bar Based on Alert Condition studies, which colors the Slow %K line green when it is above 70 and red when it is below 30. The direct link to the Study Collection is here: https://www.sierrachart.com/AdditionalFiles/StochasticSlow-ColorAboveBelow.StdyCollct Follow the instructions here for how to use the Study Collection: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-12 01:33:44] |
hit select in data files foler to locate the study collection, but the study collection is nowhere to be found to input it. tried putting it into sierrcharttrasactma\data, could not locate the download to do that ?????data files folder wont allow me to intput the download
[2019-07-12 02:00:00] |
Sierra Chart - Max - Posts: 5597 |
The study collection has been set auto-down for you once you restart Sierra Chart. Follow the instructions here for how to use the Study Collection: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection Sierra Chart Support Date Time Of Last Edit: 2019-07-12 02:00:12
[2019-07-12 02:38:49] |
thankyou for your time sir very much
