Date/Time: Thu, 02 May 2024 03:44:06 +0000
Max Time&Sales Depth Levels
View Count: 1472
[2019-07-03 12:49:37] |
User98657 - Posts: 304 |
I recently switched to SC Data and CQG Routing. I originally set the Max Time&Sales Depth level to 100 which gave me 50 levels on each side as expected. This morning I wanted to see more so I increased the Max Time&Sales Depth Levels to 200, exited and restarted SC, but I'm still only seeing 50 on each side. The Service is CQG WebAPI (Trading), and Allow Support for Sierra Chart DAta Feeds is checked. Number of Stored Time and Sales Records is 4000. |
[2019-07-03 16:33:19] |
That setting is eventually going to go out in about a week. It will no longer be relevant. It is only needed with the Bid and Ask Depth Bars study. You need to adjust this setting to increase the number of depth levels received: Data/Trade Service Settings: Maximum Time and Sales Depth Levels (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-03 16:33:31
