Date/Time: Sat, 03 Oct 2026 14:43:48 +0000
Williams % R Indicator
View Count: 2138
[2019-07-03 05:07:55]
wingz - Posts: 121
Is there a possibility that Sierra engineers can add "automatic" 20 and 80 lines to your Williams % R Indicator? I can draw them on there but it would be nice if they were there when the Indicator is added to a chart, similar to the stochastic......so you can hide, move or whatever you need to do with them. Thanks.
[2019-07-03 16:31:12]
There is a way you can do this. Refer to:
Chart Studies: Adding a Horizontal Line to an Existing Study
These lines will be separate studies but you can always create Study Collections with everything that you need:
Study Collections
Date Time Of Last Edit: 2019-07-03 16:32:39
