Date/Time: Fri, 03 May 2024 11:20:31 +0000
[User Discussion] - Footprint Delta Profile
View Count: 4091
[2019-07-03 03:29:10] |
User214233 - Posts: 7 |
Is there a way to show Delta profile like volume profile on Footprint chart?
[2019-07-03 16:13:28] |
Yes. You just need to use the Numbers Bars study: Numbers Bars And choose a Background Type which displays a volume profile that shows the difference between Ask Volume and Bid Volume: Numbers Bars: Numbers Bars Background Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-11 05:05:32] |
ycomp - Posts: 274 |
1) also is there a way to highlight the POC simply as bold text? 2) and is there a way to draw the green or red vertical lines on the left of the footprint bar to show the current up/down direction? (also see screenshot) [solved: I found answer here: Number Bars: Red Green Open Close Lines ] 3) I don't suppose there's a way to draw the boxes (thin black line) around the current price area too (like the left platform in the screenshot) 4) I guess there's no to way to overlay one number bar study over another so that I could use both Open and Close Market Style (ln: 74) of Open To Close Boxes AND Candle Body Stick Outline on the "same" Number Bars? note to self: related: - Candlestick Numbers Bars - https://futures.io/sierra-chart/29007-ofa-sierra-chart.html Date Time Of Last Edit: 2020-07-11 09:16:56
2020-07-11 03_37_29-Greenshot.png / V - Attached On 2020-07-11 05:05:23 UTC - Size: 62.66 KB - 878 views |
