Date/Time: Sun, 05 May 2024 00:06:44 +0000
datafeed
View Count: 524
[2019-07-02 15:48:22] |
User630795 - Posts: 86 |
I am an AMP Futures customer and I am currently using Sierra Chart AMP provided with CQG datafeed for index futures. I am considering switching datafeed from CQG to your datafee (for index futures). what would it take and how much would it cost? if there are more than one options, what are they? thanks.
[2019-07-02 20:47:50] |
You just need to follow the documentation here for this: Denali Exchange Data Feed This documentation is still being worked on and will be ready by morning. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-02 22:40:08] |
I am considering this switch because i think i read that your datafeed might be more accurate than CQG for stacking/pulling of order depth. is this true?
[2019-07-03 01:22:49] |
Well knowing how it is all designed since we control the full process all the way from the CME multicast feeds, we can say that it is all properly done according to specifications and guidance from the CME.
