Date/Time: Thu, 02 May 2024 22:19:18 +0000
high pullback ask/bid vol diff - displaying zero
View Count: 1622
[2019-07-01 08:19:33] |
User529571 - Posts: 5 |
Hi In the Numbers Bars Calculated Values Study, the "high pullback ask/bid vol diff" and "low pullback ask/bid vol diff" display zeros (see attached chart.) Please help. |
2019-07-01_04-00-59.png / V - Attached On 2019-07-01 08:04:18 UTC - Size: 134.34 KB - 794 views NUMBERS BARS - HIGH LOW.Cht - Attached On 2019-07-01 08:19:05 UTC - Size: 103.4 KB - 510 views |
[2019-07-01 21:47:22] |
John - SC Support - Posts: 31334 |
You need to set the Historical Pullback Data option to something other than None. The need for this is described in the documentation for the High Pullback Ask Volume Bid Volume Difference/Low Pullback Ask Volume Bid Volume Difference descriptions for the Numbers Bars Calculated Values study. These can be found in this section here: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions That section links to the Chart Settings for recording the pullback data, but here is the direct link as well: Chart Settings: Historical Pullback Data (Chart >> Chart Settings >> Chart Data >> Chart Data menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
