Date/Time: Sat, 18 May 2024 04:37:37 +0000
Replay date and time
View Count: 747
[2019-06-29 16:43:51] |
seandunaway - Posts: 214 |
I'm having trouble keeping up with where I am in regards to time during Trading DOM chart replays. In the Replay Chart (Control Panel), would it be reasonable to display the current replay time? Perhaps the Date and Time text controls could keep this information once they become disabled during Play and Paused, or in the title bar. Date Time Of Last Edit: 2019-06-29 17:03:58
playback time.png / V - Attached On 2019-06-29 16:43:45 UTC - Size: 11.97 KB - 235 views |
[2019-06-30 01:49:04] |
This can be viewed directly within the chart itself which is currently active. This is what it is based on. Make sure those Date and Time fields are displayed: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-30 01:50:08
[2019-06-30 03:44:39] |
That's helpful, thank you. Can you think of an existing way to show this on Trade DOMs? I can't get a chart header or horizontal time axis on there. Also, I've tried adding a time study but it logs the live time versus the replay time. |
[2019-06-30 03:49:30] |
Ah, I see the value of this now. Each chart can replay independently, brilliant.
[2019-06-30 04:21:19] |
I think sc.CurrentDateTimeForReplay will work, thanks! SCString ValueText = sc.DateTimeToString(sc.CurrentDateTimeForReplay, FLAG_DT_COMPLETE_DATETIME); sc.AddAndManageSingleTextDrawingForStudy(sc, false, 10, 10, sc.Subgraph[0], false, ValueText, true); |
