Date/Time: Tue, 07 May 2024 19:44:36 +0000
deleted function since todays update to version 9
View Count: 586
[2019-06-28 16:22:43] |
User897697 - Posts: 11 |
Hello, since i made the update today, the function: Hold string and pull the chart with left mouse buttom (during hand tool-mode) aint working anymore. normally one can pull the last chart position to wherever one wants at the screen. this function is now disabled. means lack of comfort. already known problem? thanks for reply |
[2019-06-28 18:01:34] |
This is still supported and how to scroll the chart horizontally with the Hand tool is documented here: Chart Drawing Tools: Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-01 06:06:30] |
Hello, what i mean was, that i could drop view from the left to the right and reverse. Means a used to hold strng and then i could drop the last position of the actual chart (for example last bar in a bar chart) to the right. This aint working no more. Regards |
[2019-07-01 21:04:04] |
The only change is that you cannot unlock or lock the Chart Right Side Fill Space using the Control key when also at the same time using the Hand tool.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 21:04:10
