Date/Time: Sat, 18 May 2024 04:55:23 +0000
Study names issue with v1941
View Count: 692
[2019-06-27 21:18:06] |
ILIM KIRGIZ - Posts: 187 |
I upgraded my SC to the latest release which is 1941. I have some studies with "Display study subgraphs name and value - global setting" disabled. So before 1941, I was not seeing the name of these studies at chart header. After upgrade, they started to be seen. Is this a bug or is there any other reason for this? Thanks. |
[2019-06-28 12:32:41] |
User24791 - Posts: 44 |
I have same issue referencing Studies in ver 1941 following upgrade
[2019-06-30 02:29:28] |
You need to use these two settings as well: Chart Studies: Subgraphs Tab >> Display Study Name Chart Studies: Subgraphs Tab >> Display Input Values In regards to post #2 how was your issue the same? What do you mean by "referencing studies"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
