Date/Time: Sat, 18 May 2024 06:02:32 +0000
Removing zeros after the decimal point
View Count: 1339
[2019-06-27 20:09:49] |
Andersenqwer1 - Posts: 4 |
Hello SC Support! I can't get rid of those 5 decimal places that appear on BidVolume vs. AskVolume study. Those scales sometimes increase padding of scale as well (Notice the padding became wider and it is almost one-fifth of the whole window - see the middle chart at the bottom and two on the left). Is there any way to fix this? I couldn't find any option neither in study properties nor scale properties. Thanks! http://www.sierrachart.com/image.php?Image=1561666272183.png Date Time Of Last Edit: 2019-06-27 21:01:06
[2019-06-28 14:50:31] |
The number of decimal places that are displayed is controlled through the Value Format. Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
