Date/Time: Fri, 03 May 2024 08:09:55 +0000
can't download v1056 having plenty of usage time left
View Count: 1168
[2013-12-01 19:13:57] |
namlem - Posts: 94 |
subject Software version: 1055 | 2013-12-01 19:10:53 Your usage time has ended. You are in FREE MODE. Features are restricted. | 2013-12-01 19:10:53 To purchase more time select Help>>Purchase on the menu. | 2013-12-01 19:10:54 |
[2013-12-01 19:54:32] |
You need to update to version 1056. You can download it from here: http://www.sierrachart.com/index.php?l=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
