Date/Time: Sat, 18 May 2024 04:05:18 +0000
Add column in TradeDOM for keyboard input
View Count: 832
[2019-06-27 16:35:21] |
User895355 - Posts: 55 |
Is it possible to add a column in the TradeDOM so I can click in a box to "mark" key price level areas?
[2019-06-27 18:29:25] |
This is not supported. But you can use the Horizontal Lines study to do this. Just add the Horizontal Line study, and be sure it is set to be in Region 1. Then put the price levels that you want to mark for each horizontal line. Then in the Subgraphs tab, sset the Draw Style for each Subgraph that you are using to Subgraph Name and Value Labels Only, then turn on the Name or Value label as you want and set it to display in the Label Column. Then go to Trade >> Customize Trade/Chart DOM Columns and add the Label column to your DOM. You will then see just the labels displayed in the DOM. Refer to the following for the Horizontal Line Study, which also includes a link to the Name and Value Labels: Horizontal Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-28 17:52:24
[2019-06-27 18:33:55] |
Bummer, in the "heat of the moment" that would be way too many moving parts.
[2019-06-28 17:53:38] |
You could also use the Horizontal Line tool: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line This is supported in newer versions on a Trading DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
