Date/Time: Sun, 05 May 2024 04:36:37 +0000
tick countdown timer on chart
View Count: 2595
[2019-06-27 02:34:00] |
User996085 - Posts: 6 |
can l display remaining ticks on my tick chart
[2019-06-27 04:12:41] |
Yes. Refer to: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-02 10:04:15] |
l look at link you give, but many, many words. My English is no so good and cannot figure out way to make a tick count down timer on my tick chart l thank you for more help to this NiƱa |
[2019-07-02 15:41:33] |
John - SC Support - Posts: 31362 |
Add the study Countdown Timer to your chart. Then go to the study settings for this study and set the Input for Display Remaining Range in Ticks to Yes.
[2019-07-02 21:50:10] |
Here are the instructions to add a study: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-06 18:39:44] |
User290496 - Posts: 56 |
Hi, Is there a built-in way to have the countdown timer show right next to the most recent price bar? |
[2020-08-06 19:13:08] |
There is no way to have it move with the most recent bar, if that is what you are asking. But you can change the placement of the Countdown Timer. Refer to the information here: Countdown Timer: Moving Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
