Date/Time: Tue, 07 May 2024 05:17:57 +0000
Sierra Chart Closing Down
View Count: 1178
[2019-06-26 16:17:40] |
gmorgan111 - Posts: 121 |
My Sierra Chart continues to disconnect during the day. I know it is not my internet because on the same computer I can easily access other websites. I have attached the log to see if you can see what is happening. ThankReading Internal Order ID file. | 2019-06-24 06:10:52 Reading Trade Orders file. | 2019-06-24 06:10:52 Reading Trade Positions file. | 2019-06-24 06:10:52 Reading Account Balance file. | 2019-06-24 06:10:52 UDPListener (1336). Port 22904 | Listening on UDP port 22904. | 2019-06-24 06:10:52 Software version: 1918 64-bit | 2019-06-24 06:10:52 Usage end date: 2019-06-28 | 2019-06-24 06:10:52 Enabled for: Advanced Features. | 2019-06-24 06:10:52 Enabled for: Advanced Features 2. | 2019-06-24 06:10:52 Enabled for: Sierra Chart Historical Data Service. | 2019-06-24 06:10:52 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-06-24 06:10:52 Current selected Data/Trading service: Rithmic Trading | 2019-06-24 06:10:52 Chart Update Interval: 500 | 2019-06-24 06:10:52 Intraday Data Storage Time Unit: 0 | 2019-06-24 06:10:52 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-06-24 06:10:52 2019-06-24 06:10:52 Local computer time | 2019-06-24 06:10:52 2019-06-24 11:10:52 Local computer time in UTC | 2019-06-24 06:10:52 2019-06-24 06:10:52 Local computer time in SC Time Zone | 2019-06-24 06:10:52 Program path: C:\SierraChart\ | 2019-06-24 06:10:52 Data Files path: C:\SierraChart\Data\ | 2019-06-24 06:10:52 OS Version Number: 10.0 | 2019-06-24 06:10:52 Locale Setting: C | 2019-06-24 06:10:52 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-06-24 06:10:52 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-06-24 06:10:52 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Creating socket. Using TLS 1.2. | 2019-06-24 06:10:52 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Connecting to IP: 46.4.97.203. | 2019-06-24 06:10:52 Rithmic Trading | Port for executable: 50251 | 2019-06-24 06:10:56 Listening socket (1368). Port 50251 | Closed. | 2019-06-24 06:10:56 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 06:10:56 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50251. Current folder: C:\SierraChart\Rim | 2019-06-24 06:10:56 Rithmic Trading | Bridge process is running. | 2019-06-24 06:10:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50251 | 2019-06-24 06:10:58 DTC Client socket (4) | Creating socket. | 2019-06-24 06:10:58 DTC Client socket (4) | Connecting to IP: 127.0.0.1. | 2019-06-24 06:10:58 Rithmic Trading | Connected to server. | 2019-06-24 06:10:58 Rithmic Trading | Starting socket receive thread. | 2019-06-24 06:10:58 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-24 06:10:58 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-24 06:10:58 Rithmic Trading | Sending logon request message. | 2019-06-24 06:10:58 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-24 06:10:58 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-24 06:10:58 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-24 06:10:58 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-24 06:11:12 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-24 06:11:13 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-24 06:11:13 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-06-24 06:11:13 * HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2019-06-24 06:11:13 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-06-24 06:11:13 * Request for symbol settings MD5 finished unsuccessfully. Request ID: 1. Socket connection closed during the connection attempt. | 2019-06-24 06:11:13 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Closed. | 2019-06-24 06:11:13 Rithmic Trading | Received logon response. | 2019-06-24 06:11:13 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-24 06:11:13 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-24 06:11:13 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-24 06:11:13 Rithmic Trading | Trading is supported. | 2019-06-24 06:11:13 Rithmic Trading | Order cancel and replace is supported. | 2019-06-24 06:11:13 Rithmic Trading | OCO Orders supported. | 2019-06-24 06:11:13 Rithmic Trading | Connected to data and trading server. | 2019-06-24 06:11:13 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-24 06:11:13 GCQ9-COMEX 2 Min #8 | Reloading chart. | 2019-06-24 06:13:04 ZNM9-CBOT [C] 2 Min #9 | Reloading chart. | 2019-06-24 06:13:04 6CM9-CME 2 Min #4 | Reloading chart. | 2019-06-24 06:13:05 6AM9-CME 3 Min #13 | Reloading chart. | 2019-06-24 06:13:05 RTYM9-CME 1 Min #16 | Reloading chart. | 2019-06-24 06:13:05 NGM9-NYMEX 2 Min #17 | Reloading chart. | 2019-06-24 06:13:05 NQU9-CME 3 Min #2 | Reloading chart. | 2019-06-24 06:13:05 NQU9-CME 3 Min #10 | Reloading chart. | 2019-06-24 06:13:05 NQU9-CME [C] 60 Min #12 | Reloading chart. | 2019-06-24 06:13:05 NQU9-CME 1 Min #1 | Reloading chart. | 2019-06-24 06:13:05 NQU9-CME [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:13:06 6CM9-CME 2 Min #4 | StartDateTimeForLoadingOrderFills: 2019-05-20 00:00:00 | 2019-06-24 06:13:06 6AM9-CME 3 Min #13 | StartDateTimeForLoadingOrderFills: 2019-05-19 17:00:00 | 2019-06-24 06:13:06 GCQ9-COMEX 2 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-26 00:00:00 | 2019-06-24 06:13:06 NQU9-CME 3 Min #10 | StartDateTimeForLoadingOrderFills: 2019-06-21 08:30:00 | 2019-06-24 06:13:06 NQU9-CME 3 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-24 06:13:06 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 1 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 1 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-24 06:13:06 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-24 06:13:06 Delaying start of download for GCQ9-COMEX | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 2 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 2 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-24 06:13:06 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 3 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 3 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-24 06:13:06 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 4 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 4 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-24 06:13:06 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 5 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 5 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-24 06:13:06 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 6 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 6 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-24 06:13:06 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 7 Service code: rithmic.trading | 2019-06-24 06:13:06 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 7 | 2019-06-24 06:13:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-24 06:13:06 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-24 06:13:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-24 06:13:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-24 06:13:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-24 06:13:06 NQU9-CME 1 Min #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-24 06:13:06 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-24 06:13:06 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 06:13:06 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 06:13:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-24 06:13:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-24 06:13:06 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 06:13:06 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-24 06:13:06 RTYM9-CME 1 Min #16 | StartDateTimeForLoadingOrderFills: 2018-12-04 09:22:00 | 2019-06-24 06:13:07 HD Request # 2 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-24 06:13:11 HD Request # 2 | Download start date-time: 2019-06-24 06:07:51.000 | 2019-06-24 06:13:11 HD Request # 2 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:13:11 Socket (1) | Creating socket. | 2019-06-24 06:13:11 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:13:11 HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:11 HD Request # 2 | Sending historical data logon request message. | 2019-06-24 06:13:11 HD Request # 2 | Requesting Intraday data. Start date-time: 2019-06-24 06:07:51. Record interval: 0. Symbol: GCQ19 | 2019-06-24 06:13:11 HD Request # 2 | Decompressing data. | 2019-06-24 06:13:11 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:11 Historical data download thread signaled to stop. | 2019-06-24 06:13:11 HD Request # 2 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-24 06:13:11 HD Request # 2 | Completion time: 0s | 2019-06-24 06:13:11 HD Request # 2 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 1 | 2019-06-24 06:13:11 Removed historical data download ID 1 | 2019-06-24 06:13:11 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-24 06:13:11 Intraday chart data file opened for GCQ9-COMEX | 2019-06-24 06:13:11 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-24 06:13:11 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-24 06:13:11 HD Request # 3 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-24 06:13:11 HD Request # 3 | Download start date-time: 2019-06-24 06:07:51.000 | 2019-06-24 06:13:11 HD Request # 3 | Sending historical data request. Start date-time: 2019-06-24 06:07:51. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-24 06:13:11 HD Request # 4 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-24 06:13:11 HD Request # 4 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-24 06:13:11 HD Request # 4 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 06:13:11 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:11 Socket (2) | Creating socket. | 2019-06-24 06:13:11 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 06:13:11 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:13:12 Socket (1) | Closed. | 2019-06-24 06:13:12 HD Request # 4 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:12 HD Request # 4 | Sending historical data logon request message. | 2019-06-24 06:13:12 HD Request # 4 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-24 06:13:12 HD Request # 3 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-24 06:07:51 | 2019-06-24 06:13:12 HD Request # 3 | Timestamp of first Intraday data file record written: 2019-06-24 06:07:54 | 2019-06-24 06:13:12 HD Request # 3 | Received 487 records from 2019-06-24 06:07:51.000 to 2019-06-24 06:13:10.000 (5.3 minutes) and wrote 479 records for GCQ9-COMEX | 2019-06-24 06:13:12 HD Request # 3 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 3 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 8 | 2019-06-24 06:13:12 Removed historical data download ID 8 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-24 06:13:12 Intraday chart data file opened for GCQ9-COMEX | 2019-06-24 06:13:12 HD Request # 4 | Decompressing data. | 2019-06-24 06:13:12 HD Request # 4 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-24 06:13:12 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:12 Historical data download thread signaled to stop. | 2019-06-24 06:13:12 HD Request # 4 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-24 06:13:12 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 06:13:12 Socket (2) | Closed. | 2019-06-24 06:13:12 HD Request # 4 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 4 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 2 | 2019-06-24 06:13:12 Removed historical data download ID 2 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-24 06:13:12 Intraday chart data file opened for ZNM9-CBOT | 2019-06-24 06:13:12 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-24 06:13:12 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-24 06:13:12 HD Request # 5 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-24 06:13:12 HD Request # 5 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-24 06:13:12 HD Request # 5 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-24 06:13:12 HD Request # 6 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-24 06:13:12 HD Request # 6 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-24 06:13:12 HD Request # 6 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:13:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:12 Socket (1) | Creating socket. | 2019-06-24 06:13:12 HD Request # 5 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 06:13:12 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:13:12 HD Request # 5 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-24 06:13:12 HD Request # 5 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 5 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 9 | 2019-06-24 06:13:12 Removed historical data download ID 9 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-24 06:13:12 Intraday chart data file opened for ZNM9-CBOT | 2019-06-24 06:13:12 HD Request # 6 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:12 HD Request # 6 | Sending historical data logon request message. | 2019-06-24 06:13:12 HD Request # 6 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-24 06:13:12 HD Request # 6 | Decompressing data. | 2019-06-24 06:13:12 HD Request # 6 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-24 06:13:12 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:12 Historical data download thread signaled to stop. | 2019-06-24 06:13:12 HD Request # 6 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-24 06:13:12 HD Request # 6 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 6 | Intraday data download complete for 6CM9-CME. Unique request ID: 3 | 2019-06-24 06:13:12 Removed historical data download ID 3 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-24 06:13:12 Intraday chart data file opened for 6CM9-CME | 2019-06-24 06:13:12 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-24 06:13:12 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-24 06:13:12 HD Request # 7 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-24 06:13:12 HD Request # 7 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-24 06:13:12 HD Request # 7 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-24 06:13:12 HD Request # 8 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-24 06:13:12 HD Request # 8 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-24 06:13:12 HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 06:13:12 Socket (2) | Creating socket. | 2019-06-24 06:13:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:12 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 06:13:12 HD Request # 7 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 06:13:12 HD Request # 7 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-24 06:13:12 HD Request # 7 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 7 | Intraday data download complete for 6CM9-CME. Unique request ID: 10 | 2019-06-24 06:13:12 Removed historical data download ID 10 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-24 06:13:12 Intraday chart data file opened for 6CM9-CME | 2019-06-24 06:13:12 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:13:12 Socket (1) | Closed. | 2019-06-24 06:13:12 HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:12 HD Request # 8 | Sending historical data logon request message. | 2019-06-24 06:13:12 HD Request # 8 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-24 06:13:12 HD Request # 8 | Decompressing data. | 2019-06-24 06:13:12 HD Request # 8 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-24 06:13:12 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:12 Historical data download thread signaled to stop. | 2019-06-24 06:13:12 HD Request # 8 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-24 06:13:12 HD Request # 8 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 8 | Intraday data download complete for 6AM9-CME. Unique request ID: 4 | 2019-06-24 06:13:12 Removed historical data download ID 4 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-24 06:13:12 Intraday chart data file opened for 6AM9-CME | 2019-06-24 06:13:12 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-24 06:13:12 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-24 06:13:12 HD Request # 9 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-24 06:13:12 HD Request # 9 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-24 06:13:12 HD Request # 9 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-24 06:13:12 HD Request # 10 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-24 06:13:12 HD Request # 10 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-24 06:13:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:12 HD Request # 10 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:13:12 HD Request # 9 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 06:13:12 HD Request # 9 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-24 06:13:12 Socket (1) | Creating socket. | 2019-06-24 06:13:12 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:13:12 HD Request # 9 | Completion time: 0s | 2019-06-24 06:13:12 HD Request # 9 | Intraday data download complete for 6AM9-CME. Unique request ID: 11 | 2019-06-24 06:13:12 Removed historical data download ID 11 | 2019-06-24 06:13:12 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-24 06:13:12 Intraday chart data file opened for 6AM9-CME | 2019-06-24 06:13:12 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 06:13:13 Socket (2) | Closed. | 2019-06-24 06:13:13 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-24 06:13:13 HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:13 HD Request # 10 | Sending historical data logon request message. | 2019-06-24 06:13:13 HD Request # 10 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-24 06:13:13 HD Request # 10 | Decompressing data. | 2019-06-24 06:13:13 HD Request # 10 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-24 06:13:13 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:13 Historical data download thread signaled to stop. | 2019-06-24 06:13:13 HD Request # 10 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-24 06:13:13 HD Request # 10 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 10 | Intraday data download complete for RTYM9-CME. Unique request ID: 5 | 2019-06-24 06:13:13 Removed historical data download ID 5 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-24 06:13:13 Intraday chart data file opened for RTYM9-CME | 2019-06-24 06:13:13 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-24 06:13:13 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-24 06:13:13 HD Request # 11 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-24 06:13:13 HD Request # 11 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-24 06:13:13 HD Request # 11 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-24 06:13:13 HD Request # 12 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-24 06:13:13 HD Request # 12 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-24 06:13:13 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:13 HD Request # 12 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 06:13:13 Socket (2) | Creating socket. | 2019-06-24 06:13:13 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 06:13:13 HD Request # 11 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 06:13:13 HD Request # 11 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-24 06:13:13 HD Request # 11 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 11 | Intraday data download complete for RTYM9-CME. Unique request ID: 12 | 2019-06-24 06:13:13 Removed historical data download ID 12 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-24 06:13:13 Intraday chart data file opened for RTYM9-CME | 2019-06-24 06:13:13 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:13:13 Socket (1) | Closed. | 2019-06-24 06:13:13 HD Request # 12 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:13 HD Request # 12 | Sending historical data logon request message. | 2019-06-24 06:13:13 HD Request # 12 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-24 06:13:13 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-24 06:13:13 HD Request # 12 | Decompressing data. | 2019-06-24 06:13:13 HD Request # 12 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-24 06:13:13 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:13 Historical data download thread signaled to stop. | 2019-06-24 06:13:13 HD Request # 12 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-24 06:13:13 HD Request # 12 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 12 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 6 | 2019-06-24 06:13:13 Removed historical data download ID 6 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-24 06:13:13 Intraday chart data file opened for NGM9-NYMEX | 2019-06-24 06:13:13 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-24 06:13:13 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-24 06:13:13 HD Request # 13 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-24 06:13:13 HD Request # 13 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-24 06:13:13 HD Request # 13 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-24 06:13:13 HD Request # 14 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-24 06:13:13 HD Request # 14 | Download start date-time: 2019-06-24 06:07:50.000 | 2019-06-24 06:13:13 HD Request # 14 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:13:13 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:13 Socket (1) | Creating socket. | 2019-06-24 06:13:13 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:13:13 HD Request # 13 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 06:13:13 HD Request # 13 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-24 06:13:13 HD Request # 13 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 13 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 13 | 2019-06-24 06:13:13 Removed historical data download ID 13 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-24 06:13:13 Intraday chart data file opened for NGM9-NYMEX | 2019-06-24 06:13:13 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 06:13:13 Socket (2) | Closed. | 2019-06-24 06:13:13 HD Request # 14 | Setting DTC encoding to Binary VLS | 2019-06-24 06:13:13 HD Request # 14 | Sending historical data logon request message. | 2019-06-24 06:13:13 HD Request # 14 | Requesting Intraday data. Start date-time: 2019-06-24 06:07:50. Record interval: 0. Symbol: NQU19 | 2019-06-24 06:13:13 HD Request # 14 | Decompressing data. | 2019-06-24 06:13:13 Historical data download thread signaled to stop. | 2019-06-24 06:13:13 HD Request # 14 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-24 06:13:13 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:13 HD Request # 14 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 14 | Intraday data download complete for NQU9-CME. Unique request ID: 7 | 2019-06-24 06:13:13 Removed historical data download ID 7 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-24 06:13:13 Intraday chart data file opened for NQU9-CME | 2019-06-24 06:13:13 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-24 06:13:13 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-24 06:13:13 HD Request # 15 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-24 06:13:13 HD Request # 15 | Download start date-time: 2019-06-24 06:07:50.000 | 2019-06-24 06:13:13 HD Request # 15 | Sending historical data request. Start date-time: 2019-06-24 06:07:50. Record interval: 0. Symbol: NQU9-CME | 2019-06-24 06:13:13 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:13:13 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:13:13 Socket (1) | Closed. | 2019-06-24 06:13:13 HD Request # 15 | Receiving Intraday data for NQU9-CME starting at 2019-06-24 06:07:50 | 2019-06-24 06:13:13 HD Request # 15 | Timestamp of first Intraday data file record written: 2019-06-24 06:07:54 | 2019-06-24 06:13:13 HD Request # 15 | Received 566 records from 2019-06-24 06:07:50.000 to 2019-06-24 06:13:12.013 (5.4 minutes) and wrote 565 records for NQU9-CME | 2019-06-24 06:13:13 HD Request # 15 | Completion time: 0s | 2019-06-24 06:13:13 HD Request # 15 | Intraday data download complete for NQU9-CME. Unique request ID: 14 | 2019-06-24 06:13:13 Removed historical data download ID 14 | 2019-06-24 06:13:13 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-24 06:13:13 Intraday chart data file opened for NQU9-CME | 2019-06-24 06:13:13 ZNM9-CBOT [C] 2 Min #9 | StartDateTimeForLoadingOrderFills: 2018-06-20 00:02:00 | 2019-06-24 06:13:14 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-24 06:13:17 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-24 06:13:20 NQU9-CME [C] 60 Min #12 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:13:28 NQU9-CME [C] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:13:28 Sierra Chart account data changed. Requesting updated account information. | 2019-06-24 06:13:53 HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2019-06-24 06:13:53 HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (2) | Connecting to IP: 46.4.97.170. | 2019-06-24 06:13:53 Successfully processed Sierra Chart account data. | 2019-06-24 06:13:54 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-06-24 06:13:54 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-06-24 06:13:54 HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:54 HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2019-06-24 06:13:54 HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (2) | Closed. | 2019-06-24 06:13:54 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:13:55 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-06-24 06:13:55 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-06-24 06:13:55 GCQ9-COMEX 2 Min #8 | Reloading chart. | 2019-06-24 06:21:27 ZNM9-CBOT [C] 2 Min #9 | Reloading chart. | 2019-06-24 06:21:27 6CM9-CME 2 Min #4 | Reloading chart. | 2019-06-24 06:21:27 6AM9-CME 3 Min #13 | Reloading chart. | 2019-06-24 06:21:27 RTYM9-CME 1 Min #16 | Reloading chart. | 2019-06-24 06:21:27 NGM9-NYMEX 2 Min #17 | Reloading chart. | 2019-06-24 06:21:27 ESU9-CME 3 Min #2 | Reloading chart. | 2019-06-24 06:21:27 ESU9-CME 3 Min #10 | Reloading chart. | 2019-06-24 06:21:27 ESU9-CME [C] 60 Min #12 | Reloading chart. | 2019-06-24 06:21:27 ESU9-CME 1 Min #1 | Reloading chart. | 2019-06-24 06:21:28 ESU9-CME [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:21:28 6CM9-CME 2 Min #4 | StartDateTimeForLoadingOrderFills: 2019-05-20 00:00:00 | 2019-06-24 06:21:28 6AM9-CME 3 Min #13 | StartDateTimeForLoadingOrderFills: 2019-05-19 17:00:00 | 2019-06-24 06:21:28 GCQ9-COMEX 2 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-26 00:00:00 | 2019-06-24 06:21:28 ESU9-CME 3 Min #10 | StartDateTimeForLoadingOrderFills: 2019-06-21 08:30:00 | 2019-06-24 06:21:28 ESU9-CME 3 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-24 06:21:28 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 8 Service code: rithmic.trading | 2019-06-24 06:21:28 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 8 | 2019-06-24 06:21:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-24 06:21:28 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-24 06:21:28 Delaying start of download for ESU9-CME | 2019-06-24 06:21:28 ESU9-CME 1 Min #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:10:00 | 2019-06-24 06:21:29 RTYM9-CME 1 Min #16 | StartDateTimeForLoadingOrderFills: 2018-12-04 09:22:00 | 2019-06-24 06:21:29 HD Request # 16 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-24 06:21:34 HD Request # 16 | Download start date-time: 2019-06-24 06:07:50.000 | 2019-06-24 06:21:34 HD Request # 16 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 06:21:34 Socket (1) | Creating socket. | 2019-06-24 06:21:34 Socket (1) | Connecting to IP: 8.18.161.135. | 2019-06-24 06:21:34 HD Request # 16 | Setting DTC encoding to Binary VLS | 2019-06-24 06:21:34 HD Request # 16 | Sending historical data logon request message. | 2019-06-24 06:21:34 HD Request # 16 | Requesting Intraday data. Start date-time: 2019-06-24 06:07:50. Record interval: 0. Symbol: ESU19 | 2019-06-24 06:21:34 HD Request # 16 | Decompressing data. | 2019-06-24 06:21:34 HD Request # 16 | Receiving Intraday data for ESU9-CME starting at 2019-06-24 06:07:50 | 2019-06-24 06:21:34 HD Request # 16 | Timestamp of first Intraday data file record written: 2019-06-24 06:07:54 | 2019-06-24 06:21:34 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:21:34 Historical data download thread signaled to stop. | 2019-06-24 06:21:34 HD Request # 16 | Received 926 records from 2019-06-24 06:07:50.000 to 2019-06-24 06:11:27.002 (3.6 minutes) and wrote 922 records for ESU9-CME | 2019-06-24 06:21:34 HD Request # 16 | Completion time: 0s | 2019-06-24 06:21:34 HD Request # 16 | Intraday data download complete for ESU9-CME. Unique request ID: 15 | 2019-06-24 06:21:34 Removed historical data download ID 15 | 2019-06-24 06:21:34 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-24 06:21:34 Intraday chart data file opened for ESU9-CME | 2019-06-24 06:21:34 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-24 06:21:34 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-24 06:21:34 HD Request # 17 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-24 06:21:34 HD Request # 17 | Download start date-time: 2019-06-24 06:11:27.000 | 2019-06-24 06:21:34 HD Request # 17 | Sending historical data request. Start date-time: 2019-06-24 06:11:27. Record interval: 0. Symbol: ESU9-CME | 2019-06-24 06:21:34 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:21:34 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:21:34 Socket (1) | Closed. | 2019-06-24 06:21:34 HD Request # 17 | Receiving Intraday data for ESU9-CME starting at 2019-06-24 06:11:27 | 2019-06-24 06:21:34 HD Request # 17 | Timestamp of first Intraday data file record written: 2019-06-24 06:11:42 | 2019-06-24 06:21:34 HD Request # 17 | Received 1040 records from 2019-06-24 06:11:27.000 to 2019-06-24 06:21:32.000 (10.1 minutes) and wrote 1037 records for ESU9-CME | 2019-06-24 06:21:34 Added 1 Time and Sales records to Intraday data file for ESU9-CME after download. | 2019-06-24 06:21:34 HD Request # 17 | Completion time: 0s | 2019-06-24 06:21:34 HD Request # 17 | Intraday data download complete for ESU9-CME. Unique request ID: 16 | 2019-06-24 06:21:34 Removed historical data download ID 16 | 2019-06-24 06:21:34 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-24 06:21:34 Intraday chart data file opened for ESU9-CME | 2019-06-24 06:21:34 ZNM9-CBOT [C] 2 Min #9 | StartDateTimeForLoadingOrderFills: 2018-06-20 00:02:00 | 2019-06-24 06:21:36 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-24 06:21:38 ESU9-CME [C] 60 Min #12 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:22:06 ESU9-CME [C] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:22:06 GCQ9-COMEX 2 Min #8 | Reloading chart. | 2019-06-24 06:25:01 ZNM9-CBOT [C] 2 Min #9 | Reloading chart. | 2019-06-24 06:25:01 6CM9-CME 2 Min #4 | Reloading chart. | 2019-06-24 06:25:01 6AM9-CME 3 Min #13 | Reloading chart. | 2019-06-24 06:25:01 RTYM9-CME 1 Min #16 | Reloading chart. | 2019-06-24 06:25:01 NGM9-NYMEX 2 Min #17 | Reloading chart. | 2019-06-24 06:25:01 GCQ9-COMEX 3 Min #2 | Reloading chart. | 2019-06-24 06:25:01 YMU9-CBOT 3 Min #10 | Reloading chart. | 2019-06-24 06:25:02 YMU9-CBOT [C] 60 Min #12 | Reloading chart. | 2019-06-24 06:25:02 GCQ9-COMEX 1 Min #1 | Reloading chart. | 2019-06-24 06:25:02 YMU9-CBOT [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:25:02 6CM9-CME 2 Min #4 | StartDateTimeForLoadingOrderFills: 2019-05-20 00:00:00 | 2019-06-24 06:25:02 6AM9-CME 3 Min #13 | StartDateTimeForLoadingOrderFills: 2019-05-19 17:00:00 | 2019-06-24 06:25:02 GCQ9-COMEX 2 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-26 00:00:00 | 2019-06-24 06:25:02 YMU9-CBOT 3 Min #10 | StartDateTimeForLoadingOrderFills: 2019-06-21 08:30:00 | 2019-06-24 06:25:02 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-24 06:25:02 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 9 Service code: rithmic.trading | 2019-06-24 06:25:02 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 9 | 2019-06-24 06:25:02 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-24 06:25:02 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-24 06:25:02 Delaying start of download for YMU9-CBOT | 2019-06-24 06:25:02 GCQ9-COMEX 3 Min #2 | StartDateTimeForLoadingOrderFills: 2018-11-26 04:33:00 | 2019-06-24 06:25:03 GCQ9-COMEX 1 Min #1 | StartDateTimeForLoadingOrderFills: 2018-11-26 04:34:00 | 2019-06-24 06:25:03 RTYM9-CME 1 Min #16 | StartDateTimeForLoadingOrderFills: 2018-12-04 09:22:00 | 2019-06-24 06:25:03 HD Request # 18 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-24 06:25:08 HD Request # 18 | Download start date-time: 2019-06-24 06:07:41.000 | 2019-06-24 06:25:08 HD Request # 18 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:25:08 Socket (1) | Creating socket. | 2019-06-24 06:25:08 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:25:08 HD Request # 18 | Setting DTC encoding to Binary VLS | 2019-06-24 06:25:08 HD Request # 18 | Sending historical data logon request message. | 2019-06-24 06:25:08 HD Request # 18 | Requesting Intraday data. Start date-time: 2019-06-24 06:07:41. Record interval: 0. Symbol: YMU19 | 2019-06-24 06:25:08 HD Request # 18 | Decompressing data. | 2019-06-24 06:25:08 HD Request # 18 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-24 06:07:41 | 2019-06-24 06:25:08 HD Request # 18 | Timestamp of first Intraday data file record written: 2019-06-24 06:07:54 | 2019-06-24 06:25:08 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:25:08 Historical data download thread signaled to stop. | 2019-06-24 06:25:08 HD Request # 18 | Received 281 records from 2019-06-24 06:07:41.000 to 2019-06-24 06:15:06.002 (7.4 minutes) and wrote 278 records for YMU9-CBOT | 2019-06-24 06:25:08 HD Request # 18 | Completion time: 0s | 2019-06-24 06:25:08 HD Request # 18 | Intraday data download complete for YMU9-CBOT. Unique request ID: 17 | 2019-06-24 06:25:08 Removed historical data download ID 17 | 2019-06-24 06:25:08 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-24 06:25:08 Intraday chart data file opened for YMU9-CBOT | 2019-06-24 06:25:08 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-24 06:25:08 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-24 06:25:08 HD Request # 19 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-24 06:25:08 HD Request # 19 | Download start date-time: 2019-06-24 06:15:06.000 | 2019-06-24 06:25:08 HD Request # 19 | Sending historical data request. Start date-time: 2019-06-24 06:15:06. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-24 06:25:08 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:25:08 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:25:08 Socket (1) | Closed. | 2019-06-24 06:25:08 HD Request # 19 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-24 06:15:06 | 2019-06-24 06:25:08 HD Request # 19 | Timestamp of first Intraday data file record written: 2019-06-24 06:15:08 | 2019-06-24 06:25:08 HD Request # 19 | Received 243 records from 2019-06-24 06:15:06.000 to 2019-06-24 06:25:07.003 (10.0 minutes) and wrote 240 records for YMU9-CBOT | 2019-06-24 06:25:08 HD Request # 19 | Completion time: 0s | 2019-06-24 06:25:08 HD Request # 19 | Intraday data download complete for YMU9-CBOT. Unique request ID: 18 | 2019-06-24 06:25:08 Removed historical data download ID 18 | 2019-06-24 06:25:08 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-24 06:25:08 Intraday chart data file opened for YMU9-CBOT | 2019-06-24 06:25:08 ZNM9-CBOT [C] 2 Min #9 | StartDateTimeForLoadingOrderFills: 2018-06-20 00:02:00 | 2019-06-24 06:25:11 YMU9-CBOT [C] 60 Min #12 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:25:12 YMU9-CBOT [C] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:25:12 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-24 06:25:22 GCQ9-COMEX [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:28:10 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCM8-COMEX | 2019-06-24 06:28:10 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ8-COMEX | 2019-06-24 06:28:10 GCQ9-COMEX [C] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 19, 20, | 2019-06-24 06:28:10 HD Request # 20 | Downloading Intraday chart data for GCM8-COMEX to the file GCM8-COMEX.scid. Service: comex | 2019-06-24 06:28:10 Compressing file: C:\SierraChart\Data\GCM8-COMEX.scid. This may take a while. | 2019-06-24 06:28:10 HD Request # 20 | Download start date-time: 2018-03-13 19:00:00.000 | 2019-06-24 06:28:10 HD Request # 20 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 06:28:10 Socket (1) | Creating socket. | 2019-06-24 06:28:10 Socket (1) | Connecting to IP: 8.18.161.135. | 2019-06-24 06:28:10 HD Request # 20 | Setting DTC encoding to Binary VLS | 2019-06-24 06:28:11 HD Request # 20 | Sending historical data logon request message. | 2019-06-24 06:28:11 HD Request # 20 | Requesting Intraday data. Start date-time: 2018-03-13 19:00:00. Record interval: 0. Symbol: GCM18 | 2019-06-24 06:28:11 HD Request # 20 | Decompressing data. | 2019-06-24 06:28:11 HD Request # 20 | Receiving Intraday data for GCM8-COMEX starting at 2018-03-13 19:00:10 | 2019-06-24 06:28:11 HD Request # 20 | Timestamp of first Intraday data file record written: 2018-03-13 19:00:10 | 2019-06-24 06:28:11 Historical data download thread signaled to stop. | 2019-06-24 06:28:37 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:28:37 HD Request # 20 | Received 9124119 records from 2018-03-13 19:00:10.000 to 2018-06-27 12:03:23.000 (105.7 days) and wrote 9124119 records for GCM8-COMEX | 2019-06-24 06:28:37 HD Request # 20 | Completion time: 27s | 2019-06-24 06:28:37 HD Request # 20 | Intraday data download complete for GCM8-COMEX. Unique request ID: 19 | 2019-06-24 06:28:37 Removed historical data download ID 19 | 2019-06-24 06:28:37 Real-time Intraday chart data file updates started for GCM8-COMEX | 2019-06-24 06:28:37 Intraday chart data file opened for GCM8-COMEX | 2019-06-24 06:28:37 Rithmic Trading | Using primary service for historical data for GCM8-COMEX | 2019-06-24 06:28:37 Intraday data recording state for symbol GCM8-COMEX is set to download 'Pending'. | 2019-06-24 06:28:37 HD Request # 21 | Downloading Intraday chart data for GCM8-COMEX to the file GCM8-COMEX.scid. Service: rithmic.trading | 2019-06-24 06:28:37 HD Request # 21 | Download start date-time: 2018-06-27 12:03:23.000 | 2019-06-24 06:28:37 HD Request # 21 | Sending historical data request. Start date-time: 2018-06-27 12:03:23. Record interval: 0. Symbol: GCM8-COMEX | 2019-06-24 06:28:37 HD Request # 22 | Downloading Intraday chart data for GCQ8-COMEX to the file GCQ8-COMEX.scid. Service: comex | 2019-06-24 06:28:37 Compressing file: C:\SierraChart\Data\GCQ8-COMEX.scid. This may take a while. | 2019-06-24 06:28:37 HD Request # 22 | Download start date-time: 2018-05-14 19:00:00.000 | 2019-06-24 06:28:37 HD Request # 22 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 06:28:37 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:28:37 Socket (2) | Creating socket. | 2019-06-24 06:28:37 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-24 06:28:37 Socket (1) | Socket gracefully closed by remote side. | 2019-06-24 06:28:37 Socket (1) | Closed. | 2019-06-24 06:28:37 HD Request # 21 | Error downloading historical Intraday data for GCM8-COMEX. Error downloading historical Tick data. Error: no data | 2019-06-24 06:28:37 HD Request # 21 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCM8-COMEX | 2019-06-24 06:28:37 HD Request # 21 | Completion time: 0s | 2019-06-24 06:28:37 HD Request # 21 | Intraday data download complete for GCM8-COMEX. Unique request ID: 21 | 2019-06-24 06:28:37 Removed historical data download ID 21 | 2019-06-24 06:28:37 Real-time Intraday chart data file updates started for GCM8-COMEX | 2019-06-24 06:28:37 Intraday chart data file opened for GCM8-COMEX | 2019-06-24 06:28:37 HD Request # 22 | Setting DTC encoding to Binary VLS | 2019-06-24 06:28:37 HD Request # 22 | Sending historical data logon request message. | 2019-06-24 06:28:37 HD Request # 22 | Requesting Intraday data. Start date-time: 2018-05-14 19:00:00. Record interval: 0. Symbol: GCQ18 | 2019-06-24 06:28:37 HD Request # 22 | Decompressing data. | 2019-06-24 06:28:37 HD Request # 22 | Receiving Intraday data for GCQ8-COMEX starting at 2018-05-14 19:02:54 | 2019-06-24 06:28:37 HD Request # 22 | Timestamp of first Intraday data file record written: 2018-05-14 19:02:54 | 2019-06-24 06:28:37 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 06:28:57 Historical data download thread signaled to stop. | 2019-06-24 06:28:57 HD Request # 22 | Received 7621776 records from 2018-05-14 19:02:54.000 to 2018-08-29 07:41:13.000 (106.5 days) and wrote 7621776 records for GCQ8-COMEX | 2019-06-24 06:28:57 HD Request # 22 | Completion time: 19s | 2019-06-24 06:28:57 HD Request # 22 | Intraday data download complete for GCQ8-COMEX. Unique request ID: 20 | 2019-06-24 06:28:57 Removed historical data download ID 20 | 2019-06-24 06:28:57 Real-time Intraday chart data file updates started for GCQ8-COMEX | 2019-06-24 06:28:57 Intraday chart data file opened for GCQ8-COMEX | 2019-06-24 06:28:57 Rithmic Trading | Using primary service for historical data for GCQ8-COMEX | 2019-06-24 06:28:57 Intraday data recording state for symbol GCQ8-COMEX is set to download 'Pending'. | 2019-06-24 06:28:57 HD Request # 23 | Downloading Intraday chart data for GCQ8-COMEX to the file GCQ8-COMEX.scid. Service: rithmic.trading | 2019-06-24 06:28:57 HD Request # 23 | Download start date-time: 2018-08-29 07:41:13.000 | 2019-06-24 06:28:57 HD Request # 23 | Sending historical data request. Start date-time: 2018-08-29 07:41:13. Record interval: 0. Symbol: GCQ8-COMEX | 2019-06-24 06:28:57 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 06:28:57 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 06:28:57 Socket (2) | Closed. | 2019-06-24 06:28:57 HD Request # 23 | Error downloading historical Intraday data for GCQ8-COMEX. Error downloading historical Tick data. Error: no data | 2019-06-24 06:28:57 HD Request # 23 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ8-COMEX | 2019-06-24 06:28:57 HD Request # 23 | Completion time: 0s | 2019-06-24 06:28:57 HD Request # 23 | Intraday data download complete for GCQ8-COMEX. Unique request ID: 22 | 2019-06-24 06:28:57 Removed historical data download ID 22 | 2019-06-24 06:28:57 Real-time Intraday chart data file updates started for GCQ8-COMEX | 2019-06-24 06:28:57 Intraday chart data file opened for GCQ8-COMEX | 2019-06-24 06:28:57 GCQ9-COMEX [C] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-06-24 06:28:57 GCQ9-COMEX [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:28:57 GCQ9-COMEX [C] 5 Min #3 | Reloading chart. | 2019-06-24 06:28:57 GCQ9-COMEX [C] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2018-06-25 00:00:00 | 2019-06-24 06:29:06 ESU9-CME 30 Sec #1 | Reloading chart. | 2019-06-24 06:45:15 ESU9-CME 30 Sec #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:10:30 | 2019-06-24 06:45:15 ESU9-CME 1 Min #1 | Reloading chart. | 2019-06-24 06:45:37 ESU9-CME 1 Min #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:10:00 | 2019-06-24 06:45:38 Notice: Detected that the system has resumed from a low-power state. | 2019-06-24 17:07:40 Re-connecting to the Data/Trading service. | 2019-06-24 17:07:40 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:07:40 Rithmic Trading | Disconnected. | 2019-06-24 17:07:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:40 Rithmic Trading | Port for executable: 64726 | 2019-06-24 17:07:42 Listening socket (1412). Port 64726 | Closed. | 2019-06-24 17:07:42 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 17:07:42 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64726. Current folder: C:\SierraChart\Rim | 2019-06-24 17:07:42 Rithmic Trading | Bridge process is not running! | 2019-06-24 17:07:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64726 | 2019-06-24 17:07:44 DTC Client socket (2) | Creating socket. | 2019-06-24 17:07:44 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-24 17:07:44 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-24 17:07:45 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-24 17:07:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:45 DTC Client socket (2) | Closed. | 2019-06-24 17:07:45 Rithmic Trading | Disconnected. | 2019-06-24 17:07:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:45 Rithmic Trading | Port for executable: 64826 | 2019-06-24 17:07:47 Listening socket (1812). Port 64826 | Closed. | 2019-06-24 17:07:47 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 17:07:47 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64826. Current folder: C:\SierraChart\Rim | 2019-06-24 17:07:47 Rithmic Trading | Bridge process is not running! | 2019-06-24 17:07:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64826 | 2019-06-24 17:07:49 DTC Client socket (2) | Creating socket. | 2019-06-24 17:07:49 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-24 17:07:49 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-24 17:07:50 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-24 17:07:50 DTC Client socket (2) | Closed. | 2019-06-24 17:07:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:50 Rithmic Trading | Disconnected. | 2019-06-24 17:07:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:50 Rithmic Trading | Port for executable: 64831 | 2019-06-24 17:07:52 Listening socket (1668). Port 64831 | Closed. | 2019-06-24 17:07:52 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 17:07:52 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64831. Current folder: C:\SierraChart\Rim | 2019-06-24 17:07:52 Rithmic Trading | Bridge process is not running! | 2019-06-24 17:07:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64831 | 2019-06-24 17:07:54 DTC Client socket (2) | Creating socket. | 2019-06-24 17:07:54 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-24 17:07:54 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-24 17:07:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-24 17:07:55 DTC Client socket (2) | Closed. | 2019-06-24 17:07:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:55 Rithmic Trading | Disconnected. | 2019-06-24 17:07:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:07:55 Rithmic Trading | Port for executable: 64835 | 2019-06-24 17:07:57 Listening socket (1812). Port 64835 | Closed. | 2019-06-24 17:07:57 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 17:07:57 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64835. Current folder: C:\SierraChart\Rim | 2019-06-24 17:07:57 DTC Client socket (4) | Socket gracefully closed by remote side. | 2019-06-24 17:07:58 DTC Client socket (4) | Closed. | 2019-06-24 17:07:58 Rithmic Trading | Bridge process is not running! | 2019-06-24 17:07:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64835 | 2019-06-24 17:07:59 DTC Client socket (2) | Creating socket. | 2019-06-24 17:07:59 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-24 17:07:59 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-24 17:08:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-24 17:08:00 DTC Client socket (2) | Closed. | 2019-06-24 17:08:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:08:00 Rithmic Trading | Disconnected. | 2019-06-24 17:08:00 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-24 17:08:00 Rithmic Trading | Port for executable: 64840 | 2019-06-24 17:08:02 Listening socket (1760). Port 64840 | Closed. | 2019-06-24 17:08:02 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-24 17:08:02 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64840. Current folder: C:\SierraChart\Rim | 2019-06-24 17:08:02 Rithmic Trading | Bridge process is running. | 2019-06-24 17:08:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64840 | 2019-06-24 17:08:04 DTC Client socket (1) | Creating socket. | 2019-06-24 17:08:04 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-24 17:08:04 Rithmic Trading | Connected to server. | 2019-06-24 17:08:04 Rithmic Trading | Starting socket receive thread. | 2019-06-24 17:08:04 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-24 17:08:04 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:04 Rithmic Trading | Sending logon request message. | 2019-06-24 17:08:04 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-24 17:08:04 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-24 17:08:04 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-24 17:08:04 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-24 17:08:05 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-24 17:08:06 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-24 17:08:06 Rithmic Trading | Received logon response. | 2019-06-24 17:08:06 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-24 17:08:06 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-24 17:08:06 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-24 17:08:06 Rithmic Trading | Trading is supported. | 2019-06-24 17:08:06 Rithmic Trading | Order cancel and replace is supported. | 2019-06-24 17:08:06 Rithmic Trading | OCO Orders supported. | 2019-06-24 17:08:06 Rithmic Trading | Connected to data and trading server. | 2019-06-24 17:08:06 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-24 17:08:06 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 1 Service code: rithmic.trading | 2019-06-24 17:08:06 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 1 | 2019-06-24 17:08:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-24 17:08:06 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-24 17:08:06 Delaying start of download for GCQ9-COMEX | 2019-06-24 17:08:06 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 2 Service code: rithmic.trading | 2019-06-24 17:08:06 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 2 | 2019-06-24 17:08:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-24 17:08:06 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-24 17:08:06 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 3 Service code: rithmic.trading | 2019-06-24 17:08:06 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 3 | 2019-06-24 17:08:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-24 17:08:06 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-24 17:08:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-24 17:08:06 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 17:08:06 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 4 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 4 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-24 17:08:07 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 5 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 5 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-24 17:08:07 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-24 17:08:07 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-24 17:08:07 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 6 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 6 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-24 17:08:07 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 7 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 7 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-24 17:08:07 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 8 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 8 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-24 17:08:07 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 9 Service code: rithmic.trading | 2019-06-24 17:08:07 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 9 | 2019-06-24 17:08:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-24 17:08:07 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-24 17:08:07 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-24 17:08:07 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 17:08:07 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-24 17:08:07 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-24 17:08:07 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-24 17:08:07 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-24 17:08:07 HD Request # 24 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-24 17:08:12 HD Request # 24 | Download start date-time: 2019-06-24 15:59:55.000 | 2019-06-24 17:08:12 HD Request # 24 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 17:08:12 Socket (2) | Creating socket. | 2019-06-24 17:08:12 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 17:08:12 HD Request # 24 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:12 HD Request # 24 | Sending historical data logon request message. | 2019-06-24 17:08:12 HD Request # 24 | Requesting Intraday data. Start date-time: 2019-06-24 15:59:55. Record interval: 0. Symbol: GCQ19 | 2019-06-24 17:08:12 HD Request # 24 | Decompressing data. | 2019-06-24 17:08:12 HD Request # 24 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-24 15:59:55 | 2019-06-24 17:08:12 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:12 Historical data download thread signaled to stop. | 2019-06-24 17:08:12 HD Request # 24 | Received 1 record from 2019-06-24 15:59:55.000 to 2019-06-24 15:59:55.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-24 17:08:12 HD Request # 24 | Completion time: 0s | 2019-06-24 17:08:12 HD Request # 24 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 23 | 2019-06-24 17:08:12 Removed historical data download ID 23 | 2019-06-24 17:08:12 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-24 17:08:12 Intraday chart data file opened for GCQ9-COMEX | 2019-06-24 17:08:12 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-24 17:08:12 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-24 17:08:12 HD Request # 25 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-24 17:08:12 HD Request # 25 | Download start date-time: 2019-06-24 15:59:55.000 | 2019-06-24 17:08:12 HD Request # 25 | Sending historical data request. Start date-time: 2019-06-24 15:59:55. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-24 17:08:12 HD Request # 26 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-24 17:08:12 HD Request # 26 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-24 17:08:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:12 HD Request # 26 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 17:08:12 Socket (3) | Creating socket. | 2019-06-24 17:08:12 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-24 17:08:12 HD Request # 26 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:13 HD Request # 26 | Sending historical data logon request message. | 2019-06-24 17:08:13 HD Request # 26 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-24 17:08:13 HD Request # 25 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-24 17:00:00 | 2019-06-24 17:08:13 HD Request # 25 | Timestamp of first Intraday data file record written: 2019-06-24 17:00:00 | 2019-06-24 17:08:13 HD Request # 25 | Received 573 records from 2019-06-24 17:00:00.000 to 2019-06-24 17:08:08.003 (8.1 minutes) and wrote 573 records for GCQ9-COMEX | 2019-06-24 17:08:13 HD Request # 25 | Completion time: 0s | 2019-06-24 17:08:13 HD Request # 25 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 32 | 2019-06-24 17:08:13 Removed historical data download ID 32 | 2019-06-24 17:08:13 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-24 17:08:13 Intraday chart data file opened for GCQ9-COMEX | 2019-06-24 17:08:13 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 17:08:13 Socket (2) | Closed. | 2019-06-24 17:08:13 HD Request # 26 | Decompressing data. | 2019-06-24 17:08:13 HD Request # 26 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-24 17:08:14 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:14 Historical data download thread signaled to stop. | 2019-06-24 17:08:14 HD Request # 26 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-24 17:08:14 HD Request # 26 | Completion time: 0s | 2019-06-24 17:08:14 HD Request # 26 | Intraday data download complete for 6CM9-CME. Unique request ID: 24 | 2019-06-24 17:08:14 Removed historical data download ID 24 | 2019-06-24 17:08:14 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-24 17:08:14 Intraday chart data file opened for 6CM9-CME | 2019-06-24 17:08:14 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-24 17:08:14 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-24 17:08:14 HD Request # 27 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-24 17:08:14 HD Request # 27 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-24 17:08:14 HD Request # 27 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-24 17:08:14 HD Request # 28 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-24 17:08:14 HD Request # 28 | Download start date-time: 2019-06-24 15:59:59.000 | 2019-06-24 17:08:14 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:14 HD Request # 28 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 17:08:14 Socket (2) | Creating socket. | 2019-06-24 17:08:14 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 17:08:14 HD Request # 27 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 17:08:14 HD Request # 27 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-24 17:08:14 HD Request # 27 | Completion time: 0s | 2019-06-24 17:08:14 HD Request # 27 | Intraday data download complete for 6CM9-CME. Unique request ID: 33 | 2019-06-24 17:08:14 Removed historical data download ID 33 | 2019-06-24 17:08:14 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-24 17:08:14 Intraday chart data file opened for 6CM9-CME | 2019-06-24 17:08:14 Socket (3) | Socket gracefully closed by remote side. | 2019-06-24 17:08:14 Socket (3) | Closed. | 2019-06-24 17:08:14 HD Request # 28 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:14 HD Request # 28 | Sending historical data logon request message. | 2019-06-24 17:08:14 HD Request # 28 | Requesting Intraday data. Start date-time: 2019-06-24 15:59:59. Record interval: 0. Symbol: NQU19 | 2019-06-24 17:08:14 HD Request # 28 | Decompressing data. | 2019-06-24 17:08:14 HD Request # 28 | Receiving Intraday data for NQU9-CME starting at 2019-06-24 15:59:59 | 2019-06-24 17:08:14 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:14 Historical data download thread signaled to stop. | 2019-06-24 17:08:14 HD Request # 28 | Received 2 records from 2019-06-24 15:59:59.000 to 2019-06-24 15:59:59.001 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-24 17:08:14 HD Request # 28 | Completion time: 0s | 2019-06-24 17:08:14 HD Request # 28 | Intraday data download complete for NQU9-CME. Unique request ID: 25 | 2019-06-24 17:08:14 Removed historical data download ID 25 | 2019-06-24 17:08:14 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-24 17:08:14 Intraday chart data file opened for NQU9-CME | 2019-06-24 17:08:14 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-24 17:08:14 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-24 17:08:14 HD Request # 29 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-24 17:08:14 HD Request # 29 | Download start date-time: 2019-06-24 15:59:59.000 | 2019-06-24 17:08:14 HD Request # 29 | Sending historical data request. Start date-time: 2019-06-24 15:59:59. Record interval: 0. Symbol: NQU9-CME | 2019-06-24 17:08:14 HD Request # 30 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-24 17:08:14 HD Request # 30 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-24 17:08:14 HD Request # 30 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 17:08:14 Socket (3) | Creating socket. | 2019-06-24 17:08:14 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-24 17:08:14 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:14 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 17:08:14 Socket (2) | Closed. | 2019-06-24 17:08:14 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-24 17:08:14 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-24 17:08:14 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-24 17:08:14 HD Request # 29 | Receiving Intraday data for NQU9-CME starting at 2019-06-24 17:00:00 | 2019-06-24 17:08:14 HD Request # 29 | Timestamp of first Intraday data file record written: 2019-06-24 17:00:00 | 2019-06-24 17:08:14 HD Request # 29 | Received 503 records from 2019-06-24 17:00:00.000 to 2019-06-24 17:08:04.000 (8.1 minutes) and wrote 503 records for NQU9-CME | 2019-06-24 17:08:14 HD Request # 29 | Completion time: 0s | 2019-06-24 17:08:14 HD Request # 29 | Intraday data download complete for NQU9-CME. Unique request ID: 34 | 2019-06-24 17:08:14 Removed historical data download ID 34 | 2019-06-24 17:08:14 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-24 17:08:14 Intraday chart data file opened for NQU9-CME | 2019-06-24 17:08:14 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-24 17:08:14 HD Request # 30 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:14 HD Request # 30 | Sending historical data logon request message. | 2019-06-24 17:08:14 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-24 17:08:14 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-24 17:08:14 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-24 17:08:14 HD Request # 30 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-24 17:08:14 HD Request # 30 | Decompressing data. | 2019-06-24 17:08:15 HD Request # 30 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-24 17:08:16 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:16 Historical data download thread signaled to stop. | 2019-06-24 17:08:16 HD Request # 30 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-24 17:08:16 HD Request # 30 | Completion time: 2s | 2019-06-24 17:08:16 HD Request # 30 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 26 | 2019-06-24 17:08:16 Removed historical data download ID 26 | 2019-06-24 17:08:16 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-24 17:08:16 Intraday chart data file opened for ZNM9-CBOT | 2019-06-24 17:08:16 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-24 17:08:16 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-24 17:08:16 HD Request # 31 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-24 17:08:16 HD Request # 31 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-24 17:08:16 HD Request # 31 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-24 17:08:16 HD Request # 32 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-24 17:08:16 HD Request # 32 | Download start date-time: 2019-06-24 15:59:58.000 | 2019-06-24 17:08:16 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:16 HD Request # 32 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 17:08:16 Socket (2) | Creating socket. | 2019-06-24 17:08:16 HD Request # 31 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 17:08:16 HD Request # 31 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-24 17:08:16 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 17:08:16 HD Request # 31 | Completion time: 0s | 2019-06-24 17:08:16 HD Request # 31 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 35 | 2019-06-24 17:08:16 Removed historical data download ID 35 | 2019-06-24 17:08:16 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-24 17:08:16 Intraday chart data file opened for ZNM9-CBOT | 2019-06-24 17:08:16 HD Request # 32 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:16 HD Request # 32 | Sending historical data logon request message. | 2019-06-24 17:08:16 Socket (3) | Socket gracefully closed by remote side. | 2019-06-24 17:08:16 Socket (3) | Closed. | 2019-06-24 17:08:16 HD Request # 32 | Requesting Intraday data. Start date-time: 2019-06-24 15:59:58. Record interval: 0. Symbol: YMU19 | 2019-06-24 17:08:16 HD Request # 32 | Decompressing data. | 2019-06-24 17:08:16 HD Request # 32 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-24 15:59:58 | 2019-06-24 17:08:16 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:16 Historical data download thread signaled to stop. | 2019-06-24 17:08:16 HD Request # 32 | Received 1 record from 2019-06-24 15:59:58.000 to 2019-06-24 15:59:58.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-06-24 17:08:16 HD Request # 32 | Completion time: 1s | 2019-06-24 17:08:16 HD Request # 32 | Intraday data download complete for YMU9-CBOT. Unique request ID: 27 | 2019-06-24 17:08:16 Removed historical data download ID 27 | 2019-06-24 17:08:16 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-24 17:08:16 Intraday chart data file opened for YMU9-CBOT | 2019-06-24 17:08:16 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-24 17:08:16 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-24 17:08:16 HD Request # 33 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-24 17:08:16 HD Request # 33 | Download start date-time: 2019-06-24 15:59:58.000 | 2019-06-24 17:08:16 HD Request # 33 | Sending historical data request. Start date-time: 2019-06-24 15:59:58. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-24 17:08:16 HD Request # 34 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-24 17:08:16 HD Request # 34 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-24 17:08:16 HD Request # 34 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 17:08:16 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:16 Socket (3) | Creating socket. | 2019-06-24 17:08:16 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-24 17:08:16 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 17:08:16 Socket (2) | Closed. | 2019-06-24 17:08:16 HD Request # 34 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:16 HD Request # 34 | Sending historical data logon request message. | 2019-06-24 17:08:16 HD Request # 33 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-24 17:00:00 | 2019-06-24 17:08:16 HD Request # 33 | Timestamp of first Intraday data file record written: 2019-06-24 17:00:00 | 2019-06-24 17:08:16 HD Request # 33 | Received 334 records from 2019-06-24 17:00:00.000 to 2019-06-24 17:07:41.000 (7.7 minutes) and wrote 334 records for YMU9-CBOT | 2019-06-24 17:08:16 HD Request # 33 | Completion time: 0s | 2019-06-24 17:08:16 HD Request # 33 | Intraday data download complete for YMU9-CBOT. Unique request ID: 36 | 2019-06-24 17:08:16 Removed historical data download ID 36 | 2019-06-24 17:08:16 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-24 17:08:16 Intraday chart data file opened for YMU9-CBOT | 2019-06-24 17:08:16 HD Request # 34 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-24 17:08:16 HD Request # 34 | Decompressing data. | 2019-06-24 17:08:17 HD Request # 34 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-24 17:08:17 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:17 Historical data download thread signaled to stop. | 2019-06-24 17:08:17 HD Request # 34 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-24 17:08:17 HD Request # 34 | Completion time: 0s | 2019-06-24 17:08:17 HD Request # 34 | Intraday data download complete for 6AM9-CME. Unique request ID: 28 | 2019-06-24 17:08:17 Removed historical data download ID 28 | 2019-06-24 17:08:17 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-24 17:08:17 Intraday chart data file opened for 6AM9-CME | 2019-06-24 17:08:17 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-24 17:08:17 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-24 17:08:17 HD Request # 35 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-24 17:08:17 HD Request # 35 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-24 17:08:17 HD Request # 35 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-24 17:08:17 HD Request # 36 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-24 17:08:17 HD Request # 36 | Download start date-time: 2019-06-24 15:59:59.000 | 2019-06-24 17:08:17 HD Request # 36 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 17:08:17 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:17 Socket (2) | Creating socket. | 2019-06-24 17:08:17 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 17:08:17 HD Request # 35 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 17:08:17 HD Request # 35 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-24 17:08:17 HD Request # 35 | Completion time: 0s | 2019-06-24 17:08:17 HD Request # 35 | Intraday data download complete for 6AM9-CME. Unique request ID: 37 | 2019-06-24 17:08:17 Removed historical data download ID 37 | 2019-06-24 17:08:17 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-24 17:08:17 Intraday chart data file opened for 6AM9-CME | 2019-06-24 17:08:17 Socket (3) | Socket gracefully closed by remote side. | 2019-06-24 17:08:17 Socket (3) | Closed. | 2019-06-24 17:08:17 HD Request # 36 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:17 HD Request # 36 | Sending historical data logon request message. | 2019-06-24 17:08:17 HD Request # 36 | Requesting Intraday data. Start date-time: 2019-06-24 15:59:59. Record interval: 0. Symbol: ESU19 | 2019-06-24 17:08:17 HD Request # 36 | Decompressing data. | 2019-06-24 17:08:17 HD Request # 36 | Receiving Intraday data for ESU9-CME starting at 2019-06-24 15:59:59 | 2019-06-24 17:08:17 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:17 Historical data download thread signaled to stop. | 2019-06-24 17:08:17 HD Request # 36 | Received 5 records from 2019-06-24 15:59:59.000 to 2019-06-24 15:59:59.004 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-06-24 17:08:17 HD Request # 36 | Completion time: 0s | 2019-06-24 17:08:17 HD Request # 36 | Intraday data download complete for ESU9-CME. Unique request ID: 29 | 2019-06-24 17:08:17 Removed historical data download ID 29 | 2019-06-24 17:08:17 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-24 17:08:17 Intraday chart data file opened for ESU9-CME | 2019-06-24 17:08:17 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-24 17:08:17 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-24 17:08:17 HD Request # 37 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-24 17:08:17 HD Request # 37 | Download start date-time: 2019-06-24 15:59:59.000 | 2019-06-24 17:08:17 HD Request # 37 | Sending historical data request. Start date-time: 2019-06-24 15:59:59. Record interval: 0. Symbol: ESU9-CME | 2019-06-24 17:08:17 HD Request # 38 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-24 17:08:17 HD Request # 38 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-24 17:08:17 HD Request # 38 | Using server: ds7.sierracharts.com port 10150 | 2019-06-24 17:08:17 Socket (3) | Creating socket. | 2019-06-24 17:08:17 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:17 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-24 17:08:17 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 17:08:17 Socket (2) | Closed. | 2019-06-24 17:08:17 HD Request # 37 | Receiving Intraday data for ESU9-CME starting at 2019-06-24 17:00:00 | 2019-06-24 17:08:17 HD Request # 37 | Timestamp of first Intraday data file record written: 2019-06-24 17:00:00 | 2019-06-24 17:08:17 HD Request # 37 | Received 870 records from 2019-06-24 17:00:00.000 to 2019-06-24 17:08:16.007 (8.3 minutes) and wrote 870 records for ESU9-CME | 2019-06-24 17:08:17 HD Request # 37 | Completion time: 0s | 2019-06-24 17:08:17 HD Request # 37 | Intraday data download complete for ESU9-CME. Unique request ID: 38 | 2019-06-24 17:08:17 Removed historical data download ID 38 | 2019-06-24 17:08:17 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-24 17:08:17 Intraday chart data file opened for ESU9-CME | 2019-06-24 17:08:17 HD Request # 38 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:18 HD Request # 38 | Sending historical data logon request message. | 2019-06-24 17:08:18 HD Request # 38 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-24 17:08:18 HD Request # 38 | Decompressing data. | 2019-06-24 17:08:18 HD Request # 38 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-24 17:08:18 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:18 Historical data download thread signaled to stop. | 2019-06-24 17:08:18 HD Request # 38 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-24 17:08:18 HD Request # 38 | Completion time: 1s | 2019-06-24 17:08:18 HD Request # 38 | Intraday data download complete for RTYM9-CME. Unique request ID: 30 | 2019-06-24 17:08:18 Removed historical data download ID 30 | 2019-06-24 17:08:18 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-24 17:08:18 Intraday chart data file opened for RTYM9-CME | 2019-06-24 17:08:18 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-24 17:08:18 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-24 17:08:18 HD Request # 39 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-24 17:08:18 HD Request # 39 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-24 17:08:18 HD Request # 39 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-24 17:08:18 HD Request # 40 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-24 17:08:18 HD Request # 40 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-24 17:08:18 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:18 HD Request # 40 | Using server: ds1.sierracharts.com port 10149 | 2019-06-24 17:08:18 HD Request # 39 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 17:08:18 Socket (2) | Creating socket. | 2019-06-24 17:08:18 HD Request # 39 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-24 17:08:18 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-24 17:08:18 HD Request # 39 | Completion time: 0s | 2019-06-24 17:08:18 HD Request # 39 | Intraday data download complete for RTYM9-CME. Unique request ID: 39 | 2019-06-24 17:08:18 Removed historical data download ID 39 | 2019-06-24 17:08:18 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-24 17:08:18 Intraday chart data file opened for RTYM9-CME | 2019-06-24 17:08:18 Socket (3) | Socket gracefully closed by remote side. | 2019-06-24 17:08:18 Socket (3) | Closed. | 2019-06-24 17:08:18 HD Request # 40 | Setting DTC encoding to Binary VLS | 2019-06-24 17:08:18 HD Request # 40 | Sending historical data logon request message. | 2019-06-24 17:08:18 HD Request # 40 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-24 17:08:19 HD Request # 40 | Decompressing data. | 2019-06-24 17:08:19 HD Request # 40 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-24 17:08:19 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-24 17:08:19 Historical data download thread signaled to stop. | 2019-06-24 17:08:19 HD Request # 40 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-24 17:08:19 HD Request # 40 | Completion time: 0s | 2019-06-24 17:08:19 HD Request # 40 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 31 | 2019-06-24 17:08:19 Removed historical data download ID 31 | 2019-06-24 17:08:19 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-24 17:08:19 Intraday chart data file opened for NGM9-NYMEX | 2019-06-24 17:08:19 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-24 17:08:19 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-24 17:08:19 HD Request # 41 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-24 17:08:19 HD Request # 41 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-24 17:08:19 HD Request # 41 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-24 17:08:19 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-24 17:08:19 HD Request # 41 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-24 17:08:19 HD Request # 41 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-24 17:08:19 HD Request # 41 | Completion time: 0s | 2019-06-24 17:08:19 HD Request # 41 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 40 | 2019-06-24 17:08:19 Removed historical data download ID 40 | 2019-06-24 17:08:19 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-24 17:08:19 Intraday chart data file opened for NGM9-NYMEX | 2019-06-24 17:08:19 Socket (2) | Socket gracefully closed by remote side. | 2019-06-24 17:08:19 Socket (2) | Closed. | 2019-06-24 17:08:19 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-24 17:08:20 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-24 17:08:51 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-24 17:09:15 Notice: Detected that the system has resumed from a low-power state. | 2019-06-25 06:21:26 Re-connecting to the Data/Trading service. | 2019-06-25 06:21:26 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:21:26 Rithmic Trading | Disconnected. | 2019-06-25 06:21:26 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:26 Rithmic Trading | Port for executable: 58899 | 2019-06-25 06:21:28 Listening socket (1844). Port 58899 | Closed. | 2019-06-25 06:21:28 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-25 06:21:28 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58899. Current folder: C:\SierraChart\Rim | 2019-06-25 06:21:29 Rithmic Trading | Bridge process is not running! | 2019-06-25 06:21:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 58899 | 2019-06-25 06:21:31 DTC Client socket (3) | Creating socket. | 2019-06-25 06:21:31 DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2019-06-25 06:21:31 DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-25 06:21:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-25 06:21:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:32 DTC Client socket (3) | Closed. | 2019-06-25 06:21:32 Rithmic Trading | Disconnected. | 2019-06-25 06:21:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:33 Rithmic Trading | Port for executable: 59006 | 2019-06-25 06:21:35 Listening socket (1804). Port 59006 | Closed. | 2019-06-25 06:21:35 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-25 06:21:35 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:59006. Current folder: C:\SierraChart\Rim | 2019-06-25 06:21:35 Rithmic Trading | Bridge process is not running! | 2019-06-25 06:21:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59006 | 2019-06-25 06:21:37 DTC Client socket (2) | Creating socket. | 2019-06-25 06:21:37 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-25 06:21:37 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-25 06:21:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-25 06:21:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:38 DTC Client socket (2) | Closed. | 2019-06-25 06:21:38 Rithmic Trading | Disconnected. | 2019-06-25 06:21:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:38 Rithmic Trading | Port for executable: 59013 | 2019-06-25 06:21:40 Listening socket (1844). Port 59013 | Closed. | 2019-06-25 06:21:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-25 06:21:40 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:59013. Current folder: C:\SierraChart\Rim | 2019-06-25 06:21:40 Rithmic Trading | Bridge process is not running! | 2019-06-25 06:21:42 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59013 | 2019-06-25 06:21:42 DTC Client socket (2) | Creating socket. | 2019-06-25 06:21:42 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-25 06:21:42 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-25 06:21:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-25 06:21:43 DTC Client socket (2) | Closed. | 2019-06-25 06:21:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:43 Rithmic Trading | Disconnected. | 2019-06-25 06:21:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:43 Rithmic Trading | Port for executable: 59016 | 2019-06-25 06:21:45 Listening socket (1500). Port 59016 | Closed. | 2019-06-25 06:21:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-25 06:21:45 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:59016. Current folder: C:\SierraChart\Rim | 2019-06-25 06:21:45 Rithmic Trading | Bridge process is not running! | 2019-06-25 06:21:47 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59016 | 2019-06-25 06:21:47 DTC Client socket (2) | Creating socket. | 2019-06-25 06:21:47 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-25 06:21:47 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-25 06:21:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-25 06:21:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:48 DTC Client socket (2) | Closed. | 2019-06-25 06:21:48 Rithmic Trading | Disconnected. | 2019-06-25 06:21:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-25 06:21:48 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-25 06:21:48 DTC Client socket (1) | Closed. | 2019-06-25 06:21:48 Rithmic Trading | Port for executable: 59020 | 2019-06-25 06:21:50 Listening socket (1844). Port 59020 | Closed. | 2019-06-25 06:21:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-25 06:21:50 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:59020. Current folder: C:\SierraChart\Rim | 2019-06-25 06:21:50 Rithmic Trading | Bridge process is running. | 2019-06-25 06:21:52 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59020 | 2019-06-25 06:21:52 DTC Client socket (1) | Creating socket. | 2019-06-25 06:21:52 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-25 06:21:52 Rithmic Trading | Connected to server. | 2019-06-25 06:21:52 Rithmic Trading | Starting socket receive thread. | 2019-06-25 06:21:52 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-25 06:21:52 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-25 06:21:52 Rithmic Trading | Sending logon request message. | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-25 06:21:52 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-25 06:21:53 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-25 06:21:53 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-25 06:21:53 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-25 06:21:53 Rithmic Trading | Received logon response. | 2019-06-25 06:21:54 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-25 06:21:54 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-25 06:21:54 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-25 06:21:54 Rithmic Trading | Trading is supported. | 2019-06-25 06:21:54 Rithmic Trading | Order cancel and replace is supported. | 2019-06-25 06:21:54 Rithmic Trading | OCO Orders supported. | 2019-06-25 06:21:54 Rithmic Trading | Connected to data and trading server. | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 1 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 1 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-25 06:21:54 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-25 06:21:54 Delaying start of download for RTYM9-CME | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 2 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 2 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-25 06:21:54 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 3 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 3 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-25 06:21:54 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 4 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 4 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-25 06:21:54 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-25 06:21:54 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-25 06:21:54 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-25 06:21:54 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 5 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 5 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-25 06:21:54 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 6 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 6 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-25 06:21:54 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 7 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 7 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-25 06:21:54 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 8 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 8 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-25 06:21:54 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-25 06:21:54 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-25 06:21:54 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 9 Service code: rithmic.trading | 2019-06-25 06:21:54 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 9 | 2019-06-25 06:21:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-25 06:21:54 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-25 06:21:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-25 06:21:54 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-25 06:21:54 HD Request # 42 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-25 06:21:55 HD Request # 42 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-25 06:21:55 HD Request # 42 | Using server: ds7.sierracharts.com port 10150 | 2019-06-25 06:21:55 Socket (2) | Creating socket. | 2019-06-25 06:21:55 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-25 06:21:55 HD Request # 42 | Setting DTC encoding to Binary VLS | 2019-06-25 06:21:55 HD Request # 42 | Sending historical data logon request message. | 2019-06-25 06:21:55 HD Request # 42 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-25 06:21:55 HD Request # 42 | Decompressing data. | 2019-06-25 06:21:55 HD Request # 42 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-25 06:21:55 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:21:55 Historical data download thread signaled to stop. | 2019-06-25 06:21:55 HD Request # 42 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-25 06:21:55 HD Request # 42 | Completion time: 0s | 2019-06-25 06:21:55 HD Request # 42 | Intraday data download complete for RTYM9-CME. Unique request ID: 41 | 2019-06-25 06:21:55 Removed historical data download ID 41 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-25 06:21:55 Intraday chart data file opened for RTYM9-CME | 2019-06-25 06:21:55 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-25 06:21:55 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-25 06:21:55 HD Request # 43 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-25 06:21:55 HD Request # 43 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-25 06:21:55 HD Request # 43 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-25 06:21:55 HD Request # 44 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-25 06:21:55 HD Request # 44 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-25 06:21:55 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:21:55 HD Request # 44 | Using server: ds1.sierracharts.com port 10149 | 2019-06-25 06:21:55 HD Request # 43 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-25 06:21:55 HD Request # 43 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-25 06:21:55 HD Request # 43 | Completion time: 0s | 2019-06-25 06:21:55 HD Request # 43 | Intraday data download complete for RTYM9-CME. Unique request ID: 50 | 2019-06-25 06:21:55 Removed historical data download ID 50 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-25 06:21:55 Intraday chart data file opened for RTYM9-CME | 2019-06-25 06:21:55 Socket (3) | Creating socket. | 2019-06-25 06:21:55 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-06-25 06:21:55 Socket (2) | Socket gracefully closed by remote side. | 2019-06-25 06:21:55 Socket (2) | Closed. | 2019-06-25 06:21:55 HD Request # 44 | Setting DTC encoding to Binary VLS | 2019-06-25 06:21:55 HD Request # 44 | Sending historical data logon request message. | 2019-06-25 06:21:55 HD Request # 44 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-25 06:21:55 HD Request # 44 | Decompressing data. | 2019-06-25 06:21:55 HD Request # 44 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-25 06:21:55 Historical data download thread signaled to stop. | 2019-06-25 06:21:55 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:21:55 HD Request # 44 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-25 06:21:55 HD Request # 44 | Completion time: 1s | 2019-06-25 06:21:55 HD Request # 44 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 42 | 2019-06-25 06:21:55 Removed historical data download ID 42 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-25 06:21:55 Intraday chart data file opened for NGM9-NYMEX | 2019-06-25 06:21:55 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-25 06:21:55 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-25 06:21:55 HD Request # 45 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-25 06:21:55 HD Request # 45 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-25 06:21:55 HD Request # 45 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-25 06:21:55 HD Request # 46 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-25 06:21:55 HD Request # 46 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-25 06:21:55 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:21:55 HD Request # 46 | Using server: ds7.sierracharts.com port 10150 | 2019-06-25 06:21:55 HD Request # 45 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-25 06:21:55 Socket (2) | Creating socket. | 2019-06-25 06:21:55 HD Request # 45 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-25 06:21:55 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-25 06:21:55 HD Request # 45 | Completion time: 0s | 2019-06-25 06:21:55 HD Request # 45 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 51 | 2019-06-25 06:21:55 Removed historical data download ID 51 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-25 06:21:55 Intraday chart data file opened for NGM9-NYMEX | 2019-06-25 06:21:55 Socket (3) | Socket gracefully closed by remote side. | 2019-06-25 06:21:55 Socket (3) | Closed. | 2019-06-25 06:21:55 HD Request # 46 | Setting DTC encoding to Binary VLS | 2019-06-25 06:21:55 HD Request # 46 | Sending historical data logon request message. | 2019-06-25 06:21:55 HD Request # 46 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-25 06:21:55 HD Request # 46 | Decompressing data. | 2019-06-25 06:21:55 HD Request # 46 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-25 06:21:55 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:21:55 Historical data download thread signaled to stop. | 2019-06-25 06:21:55 HD Request # 46 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-25 06:21:55 HD Request # 46 | Completion time: 0s | 2019-06-25 06:21:55 HD Request # 46 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 43 | 2019-06-25 06:21:55 Removed historical data download ID 43 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-25 06:21:55 Intraday chart data file opened for ZNM9-CBOT | 2019-06-25 06:21:55 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-25 06:21:55 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-25 06:21:55 HD Request # 47 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-25 06:21:55 HD Request # 47 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-25 06:21:55 HD Request # 47 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-25 06:21:55 Delaying start of download for NQU9-CME | 2019-06-25 06:21:55 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:21:55 HD Request # 47 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-25 06:21:55 HD Request # 47 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-25 06:21:55 HD Request # 47 | Completion time: 0s | 2019-06-25 06:21:55 HD Request # 47 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 52 | 2019-06-25 06:21:55 Removed historical data download ID 52 | 2019-06-25 06:21:55 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-25 06:21:55 Intraday chart data file opened for ZNM9-CBOT | 2019-06-25 06:21:55 Socket (2) | Socket gracefully closed by remote side. | 2019-06-25 06:21:55 Socket (2) | Closed. | 2019-06-25 06:21:55 HD Request # 48 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-25 06:22:00 HD Request # 48 | Download start date-time: 2019-06-25 06:12:01.000 | 2019-06-25 06:22:00 HD Request # 48 | Using server: ds1.sierracharts.com port 10149 | 2019-06-25 06:22:00 Socket (2) | Creating socket. | 2019-06-25 06:22:00 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-25 06:22:00 HD Request # 48 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:00 HD Request # 48 | Sending historical data logon request message. | 2019-06-25 06:22:00 HD Request # 48 | Requesting Intraday data. Start date-time: 2019-06-25 06:12:01. Record interval: 0. Symbol: NQU19 | 2019-06-25 06:22:00 HD Request # 48 | Decompressing data. | 2019-06-25 06:22:00 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:00 Historical data download thread signaled to stop. | 2019-06-25 06:22:00 HD Request # 48 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-25 06:22:00 HD Request # 48 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 48 | Intraday data download complete for NQU9-CME. Unique request ID: 44 | 2019-06-25 06:22:00 Removed historical data download ID 44 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-25 06:22:00 Intraday chart data file opened for NQU9-CME | 2019-06-25 06:22:00 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-25 06:22:00 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-25 06:22:00 HD Request # 49 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-25 06:22:00 HD Request # 49 | Download start date-time: 2019-06-25 06:12:01.000 | 2019-06-25 06:22:00 HD Request # 49 | Sending historical data request. Start date-time: 2019-06-25 06:12:01. Record interval: 0. Symbol: NQU9-CME | 2019-06-25 06:22:00 HD Request # 50 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-25 06:22:00 HD Request # 50 | Download start date-time: 2019-06-25 06:11:54.000 | 2019-06-25 06:22:00 HD Request # 50 | Using server: ds7.sierracharts.com port 10150 | 2019-06-25 06:22:00 Socket (3) | Creating socket. | 2019-06-25 06:22:00 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-25 06:22:00 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:00 Socket (2) | Socket gracefully closed by remote side. | 2019-06-25 06:22:00 Socket (2) | Closed. | 2019-06-25 06:22:00 HD Request # 50 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:00 HD Request # 50 | Sending historical data logon request message. | 2019-06-25 06:22:00 HD Request # 50 | Requesting Intraday data. Start date-time: 2019-06-25 06:11:54. Record interval: 0. Symbol: ESU19 | 2019-06-25 06:22:00 HD Request # 50 | Decompressing data. | 2019-06-25 06:22:00 HD Request # 50 | Receiving Intraday data for ESU9-CME starting at 2019-06-25 06:11:54 | 2019-06-25 06:22:00 Historical data download thread signaled to stop. | 2019-06-25 06:22:00 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:00 HD Request # 50 | Received 7 records from 2019-06-25 06:11:54.000 to 2019-06-25 06:11:54.006 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-06-25 06:22:00 HD Request # 50 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 50 | Intraday data download complete for ESU9-CME. Unique request ID: 45 | 2019-06-25 06:22:00 Removed historical data download ID 45 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-25 06:22:00 Intraday chart data file opened for ESU9-CME | 2019-06-25 06:22:00 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-25 06:22:00 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-25 06:22:00 HD Request # 51 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-25 06:22:00 HD Request # 51 | Download start date-time: 2019-06-25 06:12:03.000 | 2019-06-25 06:22:00 HD Request # 51 | Using server: ds1.sierracharts.com port 10149 | 2019-06-25 06:22:00 Socket (2) | Creating socket. | 2019-06-25 06:22:00 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-25 06:22:00 HD Request # 49 | Receiving Intraday data for NQU9-CME starting at 2019-06-25 06:12:01 | 2019-06-25 06:22:00 HD Request # 49 | Timestamp of first Intraday data file record written: 2019-06-25 06:12:04 | 2019-06-25 06:22:00 HD Request # 49 | Received 482 records from 2019-06-25 06:12:01.000 to 2019-06-25 06:21:49.000 (9.8 minutes) and wrote 481 records for NQU9-CME | 2019-06-25 06:22:00 HD Request # 49 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 49 | Intraday data download complete for NQU9-CME. Unique request ID: 53 | 2019-06-25 06:22:00 Removed historical data download ID 53 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-25 06:22:00 Intraday chart data file opened for NQU9-CME | 2019-06-25 06:22:00 HD Request # 52 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-25 06:22:00 HD Request # 52 | Download start date-time: 2019-06-25 06:11:54.000 | 2019-06-25 06:22:00 HD Request # 52 | Sending historical data request. Start date-time: 2019-06-25 06:11:54. Record interval: 0. Symbol: ESU9-CME | 2019-06-25 06:22:00 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:00 Socket (3) | Socket gracefully closed by remote side. | 2019-06-25 06:22:00 Socket (3) | Closed. | 2019-06-25 06:22:00 HD Request # 51 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:00 HD Request # 51 | Sending historical data logon request message. | 2019-06-25 06:22:00 HD Request # 51 | Requesting Intraday data. Start date-time: 2019-06-25 06:12:03. Record interval: 0. Symbol: GCQ19 | 2019-06-25 06:22:00 HD Request # 52 | Receiving Intraday data for ESU9-CME starting at 2019-06-25 06:11:54 | 2019-06-25 06:22:00 HD Request # 52 | Timestamp of first Intraday data file record written: 2019-06-25 06:12:05 | 2019-06-25 06:22:00 HD Request # 52 | Received 1243 records from 2019-06-25 06:11:54.000 to 2019-06-25 06:21:48.000 (9.9 minutes) and wrote 1236 records for ESU9-CME | 2019-06-25 06:22:00 HD Request # 52 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 52 | Intraday data download complete for ESU9-CME. Unique request ID: 54 | 2019-06-25 06:22:00 Removed historical data download ID 54 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-25 06:22:00 Intraday chart data file opened for ESU9-CME | 2019-06-25 06:22:00 HD Request # 51 | Decompressing data. | 2019-06-25 06:22:00 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:00 Historical data download thread signaled to stop. | 2019-06-25 06:22:00 HD Request # 51 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-25 06:22:00 HD Request # 51 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 51 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 46 | 2019-06-25 06:22:00 Removed historical data download ID 46 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-25 06:22:00 Intraday chart data file opened for GCQ9-COMEX | 2019-06-25 06:22:00 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-25 06:22:00 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-25 06:22:00 HD Request # 53 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-25 06:22:00 HD Request # 53 | Download start date-time: 2019-06-25 06:12:03.000 | 2019-06-25 06:22:00 HD Request # 53 | Sending historical data request. Start date-time: 2019-06-25 06:12:03. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-25 06:22:00 HD Request # 54 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-25 06:22:00 HD Request # 54 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-25 06:22:00 HD Request # 54 | Using server: ds7.sierracharts.com port 10150 | 2019-06-25 06:22:00 Socket (3) | Creating socket. | 2019-06-25 06:22:00 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-25 06:22:00 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:00 Socket (2) | Socket gracefully closed by remote side. | 2019-06-25 06:22:00 Socket (2) | Closed. | 2019-06-25 06:22:00 HD Request # 54 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:00 HD Request # 54 | Sending historical data logon request message. | 2019-06-25 06:22:00 HD Request # 54 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-25 06:22:00 HD Request # 54 | Decompressing data. | 2019-06-25 06:22:00 HD Request # 54 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-25 06:22:00 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:00 Historical data download thread signaled to stop. | 2019-06-25 06:22:00 HD Request # 54 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-25 06:22:00 HD Request # 54 | Completion time: 0s | 2019-06-25 06:22:00 HD Request # 54 | Intraday data download complete for 6CM9-CME. Unique request ID: 47 | 2019-06-25 06:22:00 Removed historical data download ID 47 | 2019-06-25 06:22:00 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-25 06:22:00 Intraday chart data file opened for 6CM9-CME | 2019-06-25 06:22:00 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-25 06:22:00 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-25 06:22:00 HD Request # 55 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-25 06:22:00 HD Request # 55 | Download start date-time: 2019-06-25 06:11:54.000 | 2019-06-25 06:22:00 HD Request # 55 | Using server: ds1.sierracharts.com port 10149 | 2019-06-25 06:22:00 Socket (2) | Creating socket. | 2019-06-25 06:22:00 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-25 06:22:00 Socket (3) | Socket gracefully closed by remote side. | 2019-06-25 06:22:00 Socket (3) | Closed. | 2019-06-25 06:22:00 HD Request # 53 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-25 06:12:03 | 2019-06-25 06:22:01 HD Request # 53 | Timestamp of first Intraday data file record written: 2019-06-25 06:12:05 | 2019-06-25 06:22:01 HD Request # 53 | Received 1773 records from 2019-06-25 06:12:03.000 to 2019-06-25 06:21:58.008 (9.9 minutes) and wrote 1768 records for GCQ9-COMEX | 2019-06-25 06:22:01 HD Request # 53 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 53 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 55 | 2019-06-25 06:22:01 Removed historical data download ID 55 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-25 06:22:01 Intraday chart data file opened for GCQ9-COMEX | 2019-06-25 06:22:01 HD Request # 56 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-25 06:22:01 HD Request # 56 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-25 06:22:01 HD Request # 56 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-25 06:22:01 HD Request # 55 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:01 HD Request # 55 | Sending historical data logon request message. | 2019-06-25 06:22:01 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:01 HD Request # 56 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-25 06:22:01 HD Request # 56 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-25 06:22:01 HD Request # 56 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 56 | Intraday data download complete for 6CM9-CME. Unique request ID: 56 | 2019-06-25 06:22:01 Removed historical data download ID 56 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-25 06:22:01 Intraday chart data file opened for 6CM9-CME | 2019-06-25 06:22:01 HD Request # 55 | Requesting Intraday data. Start date-time: 2019-06-25 06:11:54. Record interval: 0. Symbol: YMU19 | 2019-06-25 06:22:01 HD Request # 55 | Decompressing data. | 2019-06-25 06:22:01 HD Request # 55 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-25 06:11:54 | 2019-06-25 06:22:01 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:01 Historical data download thread signaled to stop. | 2019-06-25 06:22:01 HD Request # 55 | Received 1 record from 2019-06-25 06:11:54.000 to 2019-06-25 06:11:54.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-06-25 06:22:01 HD Request # 55 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 55 | Intraday data download complete for YMU9-CBOT. Unique request ID: 48 | 2019-06-25 06:22:01 Removed historical data download ID 48 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-25 06:22:01 Intraday chart data file opened for YMU9-CBOT | 2019-06-25 06:22:01 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-25 06:22:01 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-25 06:22:01 HD Request # 57 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-25 06:22:01 HD Request # 57 | Download start date-time: 2019-06-25 06:11:54.000 | 2019-06-25 06:22:01 HD Request # 57 | Sending historical data request. Start date-time: 2019-06-25 06:11:54. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-25 06:22:01 HD Request # 58 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-25 06:22:01 HD Request # 58 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-25 06:22:01 HD Request # 58 | Using server: ds7.sierracharts.com port 10150 | 2019-06-25 06:22:01 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:01 Socket (3) | Creating socket. | 2019-06-25 06:22:01 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-25 06:22:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-25 06:22:01 Socket (2) | Socket gracefully closed by remote side. | 2019-06-25 06:22:01 Socket (2) | Closed. | 2019-06-25 06:22:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-25 06:22:01 HD Request # 58 | Setting DTC encoding to Binary VLS | 2019-06-25 06:22:01 HD Request # 58 | Sending historical data logon request message. | 2019-06-25 06:22:01 HD Request # 57 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-25 06:11:54 | 2019-06-25 06:22:01 HD Request # 57 | Timestamp of first Intraday data file record written: 2019-06-25 06:12:05 | 2019-06-25 06:22:01 HD Request # 57 | Received 253 records from 2019-06-25 06:11:54.000 to 2019-06-25 06:21:58.001 (10.1 minutes) and wrote 252 records for YMU9-CBOT | 2019-06-25 06:22:01 HD Request # 57 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 57 | Intraday data download complete for YMU9-CBOT. Unique request ID: 57 | 2019-06-25 06:22:01 Removed historical data download ID 57 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-25 06:22:01 Intraday chart data file opened for YMU9-CBOT | 2019-06-25 06:22:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-25 06:22:01 HD Request # 58 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-25 06:22:01 HD Request # 58 | Decompressing data. | 2019-06-25 06:22:01 HD Request # 58 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-25 06:22:01 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-25 06:22:01 Historical data download thread signaled to stop. | 2019-06-25 06:22:01 HD Request # 58 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-25 06:22:01 HD Request # 58 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 58 | Intraday data download complete for 6AM9-CME. Unique request ID: 49 | 2019-06-25 06:22:01 Removed historical data download ID 49 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-25 06:22:01 Intraday chart data file opened for 6AM9-CME | 2019-06-25 06:22:01 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-25 06:22:01 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-25 06:22:01 HD Request # 59 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-25 06:22:01 HD Request # 59 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-25 06:22:01 HD Request # 59 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-25 06:22:01 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-25 06:22:01 HD Request # 59 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-25 06:22:01 HD Request # 59 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-25 06:22:01 HD Request # 59 | Completion time: 0s | 2019-06-25 06:22:01 HD Request # 59 | Intraday data download complete for 6AM9-CME. Unique request ID: 58 | 2019-06-25 06:22:01 Removed historical data download ID 58 | 2019-06-25 06:22:01 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-25 06:22:01 Intraday chart data file opened for 6AM9-CME | 2019-06-25 06:22:01 Socket (3) | Socket gracefully closed by remote side. | 2019-06-25 06:22:01 Socket (3) | Closed. | 2019-06-25 06:22:01 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-25 06:22:01 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-25 06:22:01 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-25 06:22:01 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-25 06:22:03 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-25 06:22:03 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-25 06:22:09 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-25 06:22:09 The data feed was lost. There was no activity for at least 60.0 seconds. | 2019-06-26 06:10:01 Connection to the external service has been lost. | 2019-06-26 06:10:01 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 06:10:06 Notice: Detected that the system has resumed from a low-power state. | 2019-06-26 06:10:06 Re-connecting to the Data/Trading service. | 2019-06-26 06:10:06 DTC Client socket (1) | 635 bytes remaining in receive buffer when socket closed. | 2019-06-26 06:10:06 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-06-26 06:10:06 DTC Client socket (1) | Closed. | 2019-06-26 06:10:06 Rithmic Trading | Disconnected. | 2019-06-26 06:10:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:06 Rithmic Trading | Port for executable: 64779 | 2019-06-26 06:10:09 Listening socket (1904). Port 64779 | Closed. | 2019-06-26 06:10:09 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:10:09 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64779. Current folder: C:\SierraChart\Rim | 2019-06-26 06:10:09 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:10:11 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64779 | 2019-06-26 06:10:11 DTC Client socket (1) | Creating socket. | 2019-06-26 06:10:11 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:10:11 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:10:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:10:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:12 DTC Client socket (1) | Closed. | 2019-06-26 06:10:12 Rithmic Trading | Disconnected. | 2019-06-26 06:10:12 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:12 Rithmic Trading | Port for executable: 64828 | 2019-06-26 06:10:14 Listening socket (2160). Port 64828 | Closed. | 2019-06-26 06:10:14 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:10:14 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64828. Current folder: C:\SierraChart\Rim | 2019-06-26 06:10:14 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:10:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64828 | 2019-06-26 06:10:16 DTC Client socket (1) | Creating socket. | 2019-06-26 06:10:16 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:10:16 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:10:17 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:10:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:17 DTC Client socket (1) | Closed. | 2019-06-26 06:10:17 Rithmic Trading | Disconnected. | 2019-06-26 06:10:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:17 Rithmic Trading | Port for executable: 64833 | 2019-06-26 06:10:19 Listening socket (1904). Port 64833 | Closed. | 2019-06-26 06:10:19 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:10:19 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64833. Current folder: C:\SierraChart\Rim | 2019-06-26 06:10:19 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:10:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64833 | 2019-06-26 06:10:21 DTC Client socket (1) | Creating socket. | 2019-06-26 06:10:21 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:10:21 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:10:22 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:10:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:22 DTC Client socket (1) | Closed. | 2019-06-26 06:10:22 Rithmic Trading | Disconnected. | 2019-06-26 06:10:22 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:10:22 Rithmic Trading | Port for executable: 59037 | 2019-06-26 06:10:24 Listening socket (1388). Port 59037 | Closed. | 2019-06-26 06:10:24 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:10:24 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:59037. Current folder: C:\SierraChart\Rim | 2019-06-26 06:10:24 Rithmic Trading | Bridge process is running. | 2019-06-26 06:10:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59037 | 2019-06-26 06:10:26 DTC Client socket (1) | Creating socket. | 2019-06-26 06:10:26 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:10:26 Rithmic Trading | Connected to server. | 2019-06-26 06:10:26 Rithmic Trading | Starting socket receive thread. | 2019-06-26 06:10:26 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 06:10:26 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:26 Rithmic Trading | Sending logon request message. | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 06:10:26 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-26 06:10:27 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-26 06:10:27 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-26 06:10:27 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-26 06:10:27 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-26 06:10:27 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-26 06:10:27 Rithmic Trading | Received logon response. | 2019-06-26 06:10:28 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-26 06:10:28 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-26 06:10:28 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-26 06:10:28 Rithmic Trading | Trading is supported. | 2019-06-26 06:10:28 Rithmic Trading | Order cancel and replace is supported. | 2019-06-26 06:10:28 Rithmic Trading | OCO Orders supported. | 2019-06-26 06:10:28 Rithmic Trading | Connected to data and trading server. | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 1 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 1 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-26 06:10:28 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 06:10:28 Delaying start of download for 6CM9-CME | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 2 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 2 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-26 06:10:28 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-26 06:10:28 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 3 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 3 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-26 06:10:28 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 4 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 4 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-26 06:10:28 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 5 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 5 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-26 06:10:28 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 6 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 6 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-26 06:10:28 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 7 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 7 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-26 06:10:28 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 8 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 8 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-26 06:10:28 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-26 06:10:28 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:10:28 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 9 Service code: rithmic.trading | 2019-06-26 06:10:28 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 9 | 2019-06-26 06:10:28 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-26 06:10:28 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-26 06:10:28 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-26 06:10:28 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:10:28 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-26 06:10:28 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-26 06:10:28 HD Request # 60 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-26 06:10:29 HD Request # 60 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 06:10:29 HD Request # 60 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:10:29 Socket (2) | Creating socket. | 2019-06-26 06:10:29 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:10:29 HD Request # 60 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:29 HD Request # 60 | Sending historical data logon request message. | 2019-06-26 06:10:29 HD Request # 60 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-26 06:10:29 HD Request # 60 | Decompressing data. | 2019-06-26 06:10:29 HD Request # 60 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-26 06:10:29 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:29 Historical data download thread signaled to stop. | 2019-06-26 06:10:29 HD Request # 60 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 06:10:29 HD Request # 60 | Completion time: 0s | 2019-06-26 06:10:29 HD Request # 60 | Intraday data download complete for 6CM9-CME. Unique request ID: 59 | 2019-06-26 06:10:29 Removed historical data download ID 59 | 2019-06-26 06:10:29 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 06:10:29 Intraday chart data file opened for 6CM9-CME | 2019-06-26 06:10:29 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-26 06:10:29 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 06:10:29 HD Request # 61 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:10:29 HD Request # 61 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 06:10:29 HD Request # 61 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-26 06:10:29 Delaying start of download for NQU9-CME | 2019-06-26 06:10:29 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:29 HD Request # 61 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:10:29 HD Request # 61 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 06:10:29 HD Request # 61 | Completion time: 0s | 2019-06-26 06:10:29 HD Request # 61 | Intraday data download complete for 6CM9-CME. Unique request ID: 68 | 2019-06-26 06:10:29 Removed historical data download ID 68 | 2019-06-26 06:10:29 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 06:10:29 Intraday chart data file opened for 6CM9-CME | 2019-06-26 06:10:29 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-26 06:10:29 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-26 06:10:29 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-26 06:10:29 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:10:29 Socket (2) | Closed. | 2019-06-26 06:10:29 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-26 06:10:30 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-26 06:10:30 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-26 06:10:30 HD Request # 62 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-26 06:10:33 HD Request # 62 | Download start date-time: 2019-06-25 17:08:21.000 | 2019-06-26 06:10:33 HD Request # 62 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:10:33 Socket (2) | Creating socket. | 2019-06-26 06:10:33 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:10:33 HD Request # 62 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:33 HD Request # 62 | Sending historical data logon request message. | 2019-06-26 06:10:33 HD Request # 62 | Requesting Intraday data. Start date-time: 2019-06-25 17:08:21. Record interval: 0. Symbol: NQU19 | 2019-06-26 06:10:33 HD Request # 62 | Decompressing data. | 2019-06-26 06:10:33 HD Request # 62 | Receiving Intraday data for NQU9-CME starting at 2019-06-25 17:08:21 | 2019-06-26 06:10:33 HD Request # 62 | Timestamp of first Intraday data file record written: 2019-06-25 17:08:34 | 2019-06-26 06:10:33 Historical data download thread signaled to stop. | 2019-06-26 06:10:34 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:34 HD Request # 62 | Received 60662 records from 2019-06-25 17:08:21.000 to 2019-06-26 06:00:33.000 (12.9 hours) and wrote 60659 records for NQU9-CME | 2019-06-26 06:10:34 HD Request # 62 | Completion time: 0s | 2019-06-26 06:10:34 HD Request # 62 | Intraday data download complete for NQU9-CME. Unique request ID: 60 | 2019-06-26 06:10:34 Removed historical data download ID 60 | 2019-06-26 06:10:34 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 06:10:34 Intraday chart data file opened for NQU9-CME | 2019-06-26 06:10:34 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-26 06:10:34 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 06:10:34 HD Request # 63 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-26 06:10:34 HD Request # 63 | Download start date-time: 2019-06-26 06:00:33.000 | 2019-06-26 06:10:34 HD Request # 63 | Sending historical data request. Start date-time: 2019-06-26 06:00:33. Record interval: 0. Symbol: NQU9-CME | 2019-06-26 06:10:34 HD Request # 64 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-26 06:10:34 HD Request # 64 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 06:10:34 HD Request # 64 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:10:34 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:34 Socket (3) | Creating socket. | 2019-06-26 06:10:34 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:10:34 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:10:34 Socket (2) | Closed. | 2019-06-26 06:10:34 HD Request # 64 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:34 HD Request # 64 | Sending historical data logon request message. | 2019-06-26 06:10:34 HD Request # 64 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-26 06:10:34 HD Request # 63 | Receiving Intraday data for NQU9-CME starting at 2019-06-26 06:00:33 | 2019-06-26 06:10:34 HD Request # 63 | Timestamp of first Intraday data file record written: 2019-06-26 06:00:35 | 2019-06-26 06:10:34 HD Request # 63 | Received 1243 records from 2019-06-26 06:00:33.000 to 2019-06-26 06:10:33.000 (10.0 minutes) and wrote 1242 records for NQU9-CME | 2019-06-26 06:10:34 Added 1 Time and Sales records to Intraday data file for NQU9-CME after download. | 2019-06-26 06:10:34 HD Request # 63 | Completion time: 0s | 2019-06-26 06:10:34 HD Request # 63 | Intraday data download complete for NQU9-CME. Unique request ID: 69 | 2019-06-26 06:10:34 Removed historical data download ID 69 | 2019-06-26 06:10:34 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 06:10:34 Intraday chart data file opened for NQU9-CME | 2019-06-26 06:10:34 HD Request # 64 | Decompressing data. | 2019-06-26 06:10:34 HD Request # 64 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-26 06:10:34 Historical data download thread signaled to stop. | 2019-06-26 06:10:34 HD Request # 64 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 06:10:34 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:34 HD Request # 64 | Completion time: 0s | 2019-06-26 06:10:34 HD Request # 64 | Intraday data download complete for 6AM9-CME. Unique request ID: 61 | 2019-06-26 06:10:34 Removed historical data download ID 61 | 2019-06-26 06:10:34 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 06:10:34 Intraday chart data file opened for 6AM9-CME | 2019-06-26 06:10:34 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-26 06:10:34 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 06:10:34 HD Request # 65 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:10:34 HD Request # 65 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 06:10:34 HD Request # 65 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-26 06:10:34 HD Request # 66 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-26 06:10:34 HD Request # 66 | Download start date-time: 2019-06-25 17:08:19.000 | 2019-06-26 06:10:34 HD Request # 66 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:10:34 Socket (2) | Creating socket. | 2019-06-26 06:10:34 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:10:34 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:34 HD Request # 65 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:10:34 HD Request # 65 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 06:10:34 HD Request # 65 | Completion time: 0s | 2019-06-26 06:10:34 HD Request # 65 | Intraday data download complete for 6AM9-CME. Unique request ID: 70 | 2019-06-26 06:10:34 Removed historical data download ID 70 | 2019-06-26 06:10:34 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 06:10:34 Intraday chart data file opened for 6AM9-CME | 2019-06-26 06:10:34 HD Request # 66 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:34 HD Request # 66 | Sending historical data logon request message. | 2019-06-26 06:10:34 HD Request # 66 | Requesting Intraday data. Start date-time: 2019-06-25 17:08:19. Record interval: 0. Symbol: ESU19 | 2019-06-26 06:10:34 HD Request # 66 | Decompressing data. | 2019-06-26 06:10:34 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:10:34 Socket (3) | Closed. | 2019-06-26 06:10:34 HD Request # 66 | Receiving Intraday data for ESU9-CME starting at 2019-06-25 17:08:19 | 2019-06-26 06:10:34 HD Request # 66 | Timestamp of first Intraday data file record written: 2019-06-25 17:08:34 | 2019-06-26 06:10:34 Historical data download thread signaled to stop. | 2019-06-26 06:10:35 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:35 HD Request # 66 | Received 109105 records from 2019-06-25 17:08:19.000 to 2019-06-26 06:00:34.007 (12.9 hours) and wrote 109100 records for ESU9-CME | 2019-06-26 06:10:35 HD Request # 66 | Completion time: 0s | 2019-06-26 06:10:35 HD Request # 66 | Intraday data download complete for ESU9-CME. Unique request ID: 62 | 2019-06-26 06:10:35 Removed historical data download ID 62 | 2019-06-26 06:10:35 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 06:10:35 Intraday chart data file opened for ESU9-CME | 2019-06-26 06:10:35 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-26 06:10:35 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 06:10:35 HD Request # 67 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-26 06:10:35 HD Request # 67 | Download start date-time: 2019-06-26 06:00:34.000 | 2019-06-26 06:10:35 HD Request # 67 | Sending historical data request. Start date-time: 2019-06-26 06:00:34. Record interval: 0. Symbol: ESU9-CME | 2019-06-26 06:10:35 HD Request # 68 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-26 06:10:35 HD Request # 68 | Download start date-time: 2019-06-25 17:08:19.000 | 2019-06-26 06:10:35 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:35 HD Request # 68 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:10:35 Socket (3) | Creating socket. | 2019-06-26 06:10:35 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:10:35 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:10:35 Socket (2) | Closed. | 2019-06-26 06:10:35 HD Request # 68 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:35 HD Request # 68 | Sending historical data logon request message. | 2019-06-26 06:10:35 HD Request # 68 | Requesting Intraday data. Start date-time: 2019-06-25 17:08:19. Record interval: 0. Symbol: GCQ19 | 2019-06-26 06:10:35 HD Request # 67 | Receiving Intraday data for ESU9-CME starting at 2019-06-26 06:00:34 | 2019-06-26 06:10:35 HD Request # 67 | Timestamp of first Intraday data file record written: 2019-06-26 06:00:40 | 2019-06-26 06:10:35 HD Request # 67 | Received 2166 records from 2019-06-26 06:00:34.000 to 2019-06-26 06:10:33.000 (10.0 minutes) and wrote 2158 records for ESU9-CME | 2019-06-26 06:10:35 HD Request # 67 | Completion time: 0s | 2019-06-26 06:10:35 HD Request # 67 | Intraday data download complete for ESU9-CME. Unique request ID: 71 | 2019-06-26 06:10:35 Removed historical data download ID 71 | 2019-06-26 06:10:35 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 06:10:35 Intraday chart data file opened for ESU9-CME | 2019-06-26 06:10:35 HD Request # 68 | Decompressing data. | 2019-06-26 06:10:35 HD Request # 68 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-25 17:08:19 | 2019-06-26 06:10:35 HD Request # 68 | Timestamp of first Intraday data file record written: 2019-06-25 17:08:23 | 2019-06-26 06:10:35 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:35 Historical data download thread signaled to stop. | 2019-06-26 06:10:35 HD Request # 68 | Received 153226 records from 2019-06-25 17:08:19.000 to 2019-06-26 06:00:35.000 (12.9 hours) and wrote 153220 records for GCQ9-COMEX | 2019-06-26 06:10:35 HD Request # 68 | Completion time: 0s | 2019-06-26 06:10:35 HD Request # 68 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 63 | 2019-06-26 06:10:35 Removed historical data download ID 63 | 2019-06-26 06:10:35 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 06:10:35 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 06:10:35 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-26 06:10:35 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 06:10:35 HD Request # 69 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-26 06:10:35 HD Request # 69 | Download start date-time: 2019-06-26 06:00:35.000 | 2019-06-26 06:10:35 HD Request # 69 | Sending historical data request. Start date-time: 2019-06-26 06:00:35. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-26 06:10:35 HD Request # 70 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-26 06:10:35 HD Request # 70 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 06:10:35 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:35 HD Request # 70 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:10:35 Socket (2) | Creating socket. | 2019-06-26 06:10:35 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:10:35 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:10:36 Socket (3) | Closed. | 2019-06-26 06:10:36 HD Request # 70 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:36 HD Request # 70 | Sending historical data logon request message. | 2019-06-26 06:10:36 HD Request # 70 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-26 06:10:36 HD Request # 70 | Decompressing data. | 2019-06-26 06:10:36 HD Request # 70 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-26 06:10:36 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:36 Historical data download thread signaled to stop. | 2019-06-26 06:10:36 HD Request # 70 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 06:10:36 HD Request # 70 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 70 | Intraday data download complete for RTYM9-CME. Unique request ID: 64 | 2019-06-26 06:10:36 Removed historical data download ID 64 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 06:10:36 Intraday chart data file opened for RTYM9-CME | 2019-06-26 06:10:36 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-26 06:10:36 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 06:10:36 HD Request # 71 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-26 06:10:36 HD Request # 71 | Download start date-time: 2019-06-25 17:08:18.000 | 2019-06-26 06:10:36 HD Request # 71 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:10:36 Socket (3) | Creating socket. | 2019-06-26 06:10:36 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:10:36 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:10:36 Socket (2) | Closed. | 2019-06-26 06:10:36 HD Request # 71 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:36 HD Request # 71 | Sending historical data logon request message. | 2019-06-26 06:10:36 HD Request # 71 | Requesting Intraday data. Start date-time: 2019-06-25 17:08:18. Record interval: 0. Symbol: YMU19 | 2019-06-26 06:10:36 HD Request # 69 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-26 06:00:35 | 2019-06-26 06:10:36 HD Request # 69 | Timestamp of first Intraday data file record written: 2019-06-26 06:00:37 | 2019-06-26 06:10:36 HD Request # 69 | Received 1366 records from 2019-06-26 06:00:35.000 to 2019-06-26 06:10:33.004 (10.0 minutes) and wrote 1365 records for GCQ9-COMEX | 2019-06-26 06:10:36 HD Request # 69 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 69 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 72 | 2019-06-26 06:10:36 Removed historical data download ID 72 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 06:10:36 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 06:10:36 HD Request # 72 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:10:36 HD Request # 72 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 06:10:36 HD Request # 72 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-26 06:10:36 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:36 HD Request # 72 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:10:36 HD Request # 72 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 06:10:36 HD Request # 72 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 72 | Intraday data download complete for RTYM9-CME. Unique request ID: 73 | 2019-06-26 06:10:36 Removed historical data download ID 73 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 06:10:36 Intraday chart data file opened for RTYM9-CME | 2019-06-26 06:10:36 HD Request # 71 | Decompressing data. | 2019-06-26 06:10:36 HD Request # 71 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-25 17:08:18 | 2019-06-26 06:10:36 HD Request # 71 | Timestamp of first Intraday data file record written: 2019-06-25 17:08:24 | 2019-06-26 06:10:36 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:36 Historical data download thread signaled to stop. | 2019-06-26 06:10:36 HD Request # 71 | Received 35995 records from 2019-06-25 17:08:18.000 to 2019-06-26 06:00:35.000 (12.9 hours) and wrote 35990 records for YMU9-CBOT | 2019-06-26 06:10:36 HD Request # 71 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 71 | Intraday data download complete for YMU9-CBOT. Unique request ID: 65 | 2019-06-26 06:10:36 Removed historical data download ID 65 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 06:10:36 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 06:10:36 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-26 06:10:36 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 06:10:36 HD Request # 73 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-26 06:10:36 HD Request # 73 | Download start date-time: 2019-06-26 06:00:35.000 | 2019-06-26 06:10:36 HD Request # 73 | Sending historical data request. Start date-time: 2019-06-26 06:00:35. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-26 06:10:36 HD Request # 74 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-26 06:10:36 HD Request # 74 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 06:10:36 HD Request # 74 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:10:36 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:36 Socket (2) | Creating socket. | 2019-06-26 06:10:36 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:10:36 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:10:36 Socket (3) | Closed. | 2019-06-26 06:10:36 HD Request # 74 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:36 HD Request # 74 | Sending historical data logon request message. | 2019-06-26 06:10:36 HD Request # 73 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-26 06:00:35 | 2019-06-26 06:10:36 HD Request # 73 | Timestamp of first Intraday data file record written: 2019-06-26 06:00:40 | 2019-06-26 06:10:36 HD Request # 73 | Received 677 records from 2019-06-26 06:00:35.000 to 2019-06-26 06:10:35.003 (10.0 minutes) and wrote 676 records for YMU9-CBOT | 2019-06-26 06:10:36 HD Request # 73 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 73 | Intraday data download complete for YMU9-CBOT. Unique request ID: 74 | 2019-06-26 06:10:36 Removed historical data download ID 74 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 06:10:36 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 06:10:36 HD Request # 74 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-26 06:10:36 HD Request # 74 | Decompressing data. | 2019-06-26 06:10:36 HD Request # 74 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-26 06:10:36 Historical data download thread signaled to stop. | 2019-06-26 06:10:36 HD Request # 74 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 06:10:36 HD Request # 74 | Completion time: 0s | 2019-06-26 06:10:36 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:36 HD Request # 74 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 66 | 2019-06-26 06:10:36 Removed historical data download ID 66 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 06:10:36 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 06:10:36 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-26 06:10:36 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 06:10:36 HD Request # 75 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 06:10:36 HD Request # 75 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 06:10:36 HD Request # 75 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-26 06:10:36 HD Request # 76 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-26 06:10:36 HD Request # 76 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 06:10:36 HD Request # 76 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:10:36 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:36 Socket (3) | Creating socket. | 2019-06-26 06:10:36 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:10:36 HD Request # 75 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:10:36 HD Request # 75 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 06:10:36 HD Request # 75 | Completion time: 0s | 2019-06-26 06:10:36 HD Request # 75 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 75 | 2019-06-26 06:10:36 Removed historical data download ID 75 | 2019-06-26 06:10:36 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 06:10:36 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 06:10:36 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:10:36 Socket (2) | Closed. | 2019-06-26 06:10:36 HD Request # 76 | Setting DTC encoding to Binary VLS | 2019-06-26 06:10:36 HD Request # 76 | Sending historical data logon request message. | 2019-06-26 06:10:36 HD Request # 76 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-26 06:10:36 HD Request # 76 | Decompressing data. | 2019-06-26 06:10:37 HD Request # 76 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-26 06:10:37 Historical data download thread signaled to stop. | 2019-06-26 06:10:37 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:10:37 HD Request # 76 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 06:10:37 HD Request # 76 | Completion time: 0s | 2019-06-26 06:10:37 HD Request # 76 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 67 | 2019-06-26 06:10:37 Removed historical data download ID 67 | 2019-06-26 06:10:37 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 06:10:37 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 06:10:37 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-26 06:10:37 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 06:10:37 HD Request # 77 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-26 06:10:37 HD Request # 77 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 06:10:37 HD Request # 77 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-26 06:10:37 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:10:37 HD Request # 77 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:10:37 HD Request # 77 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 06:10:37 HD Request # 77 | Completion time: 0s | 2019-06-26 06:10:37 HD Request # 77 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 76 | 2019-06-26 06:10:37 Removed historical data download ID 76 | 2019-06-26 06:10:37 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 06:10:37 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 06:10:37 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:10:37 Socket (3) | Closed. | 2019-06-26 06:10:37 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-26 06:10:38 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-26 06:10:38 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-26 06:10:38 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-26 06:10:44 Rithmic Trading | Message from server: Server Alert: PnL Connection Broken | 2019-06-26 06:41:33 Rithmic Trading | Message from server: Deleting API object. | 2019-06-26 06:41:33 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-06-26 06:41:33 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Broken | 2019-06-26 06:41:33 Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2019-06-26 06:41:33 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 06:41:33 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-06-26 06:41:33 DTC Client socket (1) | Closed. | 2019-06-26 06:41:33 Connection to the external service has been lost. | 2019-06-26 06:41:33 Rithmic Trading | Disconnected. | 2019-06-26 06:41:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:33 Rithmic Trading | Port for executable: 50213 | 2019-06-26 06:41:35 Listening socket (1644). Port 50213 | Closed. | 2019-06-26 06:41:35 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:41:35 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50213. Current folder: C:\SierraChart\Rim | 2019-06-26 06:41:35 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:41:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50213 | 2019-06-26 06:41:37 DTC Client socket (1) | Creating socket. | 2019-06-26 06:41:37 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:41:37 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:41:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:41:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:38 DTC Client socket (1) | Closed. | 2019-06-26 06:41:38 Rithmic Trading | Disconnected. | 2019-06-26 06:41:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:38 Rithmic Trading | Port for executable: 50219 | 2019-06-26 06:41:40 Listening socket (2148). Port 50219 | Closed. | 2019-06-26 06:41:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:41:40 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50219. Current folder: C:\SierraChart\Rim | 2019-06-26 06:41:40 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:41:42 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50219 | 2019-06-26 06:41:42 DTC Client socket (1) | Creating socket. | 2019-06-26 06:41:42 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:41:42 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:41:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:41:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:43 DTC Client socket (1) | Closed. | 2019-06-26 06:41:43 Rithmic Trading | Disconnected. | 2019-06-26 06:41:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:43 Rithmic Trading | Port for executable: 50221 | 2019-06-26 06:41:45 Listening socket (2148). Port 50221 | Closed. | 2019-06-26 06:41:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:41:45 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50221. Current folder: C:\SierraChart\Rim | 2019-06-26 06:41:45 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:41:47 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50221 | 2019-06-26 06:41:47 DTC Client socket (1) | Creating socket. | 2019-06-26 06:41:47 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:41:47 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:41:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:41:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:48 DTC Client socket (1) | Closed. | 2019-06-26 06:41:48 Rithmic Trading | Disconnected. | 2019-06-26 06:41:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:48 Rithmic Trading | Port for executable: 50223 | 2019-06-26 06:41:50 Listening socket (1644). Port 50223 | Closed. | 2019-06-26 06:41:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:41:50 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50223. Current folder: C:\SierraChart\Rim | 2019-06-26 06:41:51 Rithmic Trading | Bridge process is not running! | 2019-06-26 06:41:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50223 | 2019-06-26 06:41:53 DTC Client socket (1) | Creating socket. | 2019-06-26 06:41:53 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:41:53 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 06:41:54 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 06:41:54 DTC Client socket (1) | Closed. | 2019-06-26 06:41:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:54 Rithmic Trading | Disconnected. | 2019-06-26 06:41:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 06:41:54 Rithmic Trading | Port for executable: 50225 | 2019-06-26 06:41:56 Listening socket (2148). Port 50225 | Closed. | 2019-06-26 06:41:56 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 06:41:56 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50225. Current folder: C:\SierraChart\Rim | 2019-06-26 06:41:56 Rithmic Trading | Bridge process is running. | 2019-06-26 06:41:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50225 | 2019-06-26 06:41:58 DTC Client socket (1) | Creating socket. | 2019-06-26 06:41:58 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 06:41:58 Rithmic Trading | Connected to server. | 2019-06-26 06:41:58 Rithmic Trading | Starting socket receive thread. | 2019-06-26 06:41:58 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 06:41:58 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 06:41:58 Rithmic Trading | Sending logon request message. | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-26 06:41:58 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-26 06:41:59 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-26 06:41:59 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-26 06:41:59 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-26 06:41:59 Rithmic Trading | Received logon response. | 2019-06-26 06:42:00 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-26 06:42:00 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-26 06:42:00 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-26 06:42:00 Rithmic Trading | Trading is supported. | 2019-06-26 06:42:00 Rithmic Trading | Order cancel and replace is supported. | 2019-06-26 06:42:00 Rithmic Trading | OCO Orders supported. | 2019-06-26 06:42:00 Rithmic Trading | Connected to data and trading server. | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 1 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 1 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-26 06:42:00 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 06:42:00 Delaying start of download for 6CM9-CME | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 2 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 2 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-26 06:42:00 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 3 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 3 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-26 06:42:00 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 4 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 4 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-26 06:42:00 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 5 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 5 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-26 06:42:00 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 06:42:00 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:42:00 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 6 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 6 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-26 06:42:00 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 7 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 7 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-26 06:42:00 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 8 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 8 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-26 06:42:00 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 9 Service code: rithmic.trading | 2019-06-26 06:42:00 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 9 | 2019-06-26 06:42:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-26 06:42:00 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-26 06:42:00 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 06:42:00 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-26 06:42:00 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-26 06:42:00 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-26 06:42:00 HD Request # 78 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-26 06:42:01 HD Request # 78 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 06:42:01 HD Request # 78 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:42:01 Socket (2) | Creating socket. | 2019-06-26 06:42:01 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:42:01 HD Request # 78 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:01 HD Request # 78 | Sending historical data logon request message. | 2019-06-26 06:42:01 HD Request # 78 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-26 06:42:01 HD Request # 78 | Decompressing data. | 2019-06-26 06:42:01 HD Request # 78 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-26 06:42:01 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:01 Historical data download thread signaled to stop. | 2019-06-26 06:42:01 HD Request # 78 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 06:42:01 HD Request # 78 | Completion time: 0s | 2019-06-26 06:42:01 HD Request # 78 | Intraday data download complete for 6CM9-CME. Unique request ID: 77 | 2019-06-26 06:42:01 Removed historical data download ID 77 | 2019-06-26 06:42:01 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 06:42:01 Intraday chart data file opened for 6CM9-CME | 2019-06-26 06:42:01 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-26 06:42:01 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 06:42:01 HD Request # 79 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:42:01 HD Request # 79 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 06:42:01 HD Request # 79 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-26 06:42:01 Delaying start of download for NQU9-CME | 2019-06-26 06:42:01 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:01 HD Request # 79 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:42:01 HD Request # 79 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 06:42:01 HD Request # 79 | Completion time: 0s | 2019-06-26 06:42:01 HD Request # 79 | Intraday data download complete for 6CM9-CME. Unique request ID: 86 | 2019-06-26 06:42:01 Removed historical data download ID 86 | 2019-06-26 06:42:01 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 06:42:01 Intraday chart data file opened for 6CM9-CME | 2019-06-26 06:42:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-26 06:42:01 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:42:01 Socket (2) | Closed. | 2019-06-26 06:42:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-26 06:42:01 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-26 06:42:01 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-26 06:42:01 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-26 06:42:01 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-26 06:42:01 HD Request # 80 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-26 06:42:05 HD Request # 80 | Download start date-time: 2019-06-26 06:41:27.000 | 2019-06-26 06:42:05 HD Request # 80 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:42:05 Socket (2) | Creating socket. | 2019-06-26 06:42:05 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:42:05 HD Request # 80 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:05 HD Request # 80 | Sending historical data logon request message. | 2019-06-26 06:42:05 HD Request # 80 | Requesting Intraday data. Start date-time: 2019-06-26 06:41:27. Record interval: 0. Symbol: NQU19 | 2019-06-26 06:42:05 HD Request # 80 | Decompressing data. | 2019-06-26 06:42:05 Historical data download thread signaled to stop. | 2019-06-26 06:42:05 HD Request # 80 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-26 06:42:05 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:05 HD Request # 80 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 80 | Intraday data download complete for NQU9-CME. Unique request ID: 78 | 2019-06-26 06:42:05 Removed historical data download ID 78 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for NQU9-CME | 2019-06-26 06:42:05 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-26 06:42:05 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 06:42:05 HD Request # 81 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-26 06:42:05 HD Request # 81 | Download start date-time: 2019-06-26 06:41:27.000 | 2019-06-26 06:42:05 HD Request # 81 | Sending historical data request. Start date-time: 2019-06-26 06:41:27. Record interval: 0. Symbol: NQU9-CME | 2019-06-26 06:42:05 HD Request # 82 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-26 06:42:05 HD Request # 82 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 06:42:05 HD Request # 82 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:42:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:05 Socket (3) | Creating socket. | 2019-06-26 06:42:05 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:42:05 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:42:05 Socket (2) | Closed. | 2019-06-26 06:42:05 HD Request # 82 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:05 HD Request # 82 | Sending historical data logon request message. | 2019-06-26 06:42:05 HD Request # 81 | Receiving Intraday data for NQU9-CME starting at 2019-06-26 06:41:27 | 2019-06-26 06:42:05 HD Request # 81 | Timestamp of first Intraday data file record written: 2019-06-26 06:41:34 | 2019-06-26 06:42:05 HD Request # 81 | Received 29 records from 2019-06-26 06:41:27.000 to 2019-06-26 06:42:04.002 (37.0 seconds) and wrote 28 records for NQU9-CME | 2019-06-26 06:42:05 HD Request # 81 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 81 | Intraday data download complete for NQU9-CME. Unique request ID: 87 | 2019-06-26 06:42:05 Removed historical data download ID 87 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for NQU9-CME | 2019-06-26 06:42:05 HD Request # 82 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-26 06:42:05 HD Request # 82 | Decompressing data. | 2019-06-26 06:42:05 HD Request # 82 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-26 06:42:05 Historical data download thread signaled to stop. | 2019-06-26 06:42:05 HD Request # 82 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 06:42:05 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:05 HD Request # 82 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 82 | Intraday data download complete for 6AM9-CME. Unique request ID: 79 | 2019-06-26 06:42:05 Removed historical data download ID 79 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for 6AM9-CME | 2019-06-26 06:42:05 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-26 06:42:05 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 06:42:05 HD Request # 83 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:42:05 HD Request # 83 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 06:42:05 HD Request # 83 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-26 06:42:05 HD Request # 84 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-26 06:42:05 HD Request # 84 | Download start date-time: 2019-06-26 06:41:32.000 | 2019-06-26 06:42:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:05 HD Request # 84 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:42:05 Socket (2) | Creating socket. | 2019-06-26 06:42:05 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:42:05 HD Request # 83 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:42:05 HD Request # 83 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 06:42:05 HD Request # 83 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 83 | Intraday data download complete for 6AM9-CME. Unique request ID: 88 | 2019-06-26 06:42:05 Removed historical data download ID 88 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for 6AM9-CME | 2019-06-26 06:42:05 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:42:05 Socket (3) | Closed. | 2019-06-26 06:42:05 HD Request # 84 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:05 HD Request # 84 | Sending historical data logon request message. | 2019-06-26 06:42:05 HD Request # 84 | Requesting Intraday data. Start date-time: 2019-06-26 06:41:32. Record interval: 0. Symbol: ESU19 | 2019-06-26 06:42:05 HD Request # 84 | Decompressing data. | 2019-06-26 06:42:05 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:05 Historical data download thread signaled to stop. | 2019-06-26 06:42:05 HD Request # 84 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-06-26 06:42:05 HD Request # 84 | Completion time: 1s | 2019-06-26 06:42:05 HD Request # 84 | Intraday data download complete for ESU9-CME. Unique request ID: 80 | 2019-06-26 06:42:05 Removed historical data download ID 80 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for ESU9-CME | 2019-06-26 06:42:05 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-26 06:42:05 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 06:42:05 HD Request # 85 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-26 06:42:05 HD Request # 85 | Download start date-time: 2019-06-26 06:41:32.000 | 2019-06-26 06:42:05 HD Request # 85 | Sending historical data request. Start date-time: 2019-06-26 06:41:32. Record interval: 0. Symbol: ESU9-CME | 2019-06-26 06:42:05 HD Request # 86 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-26 06:42:05 HD Request # 86 | Download start date-time: 2019-06-26 06:41:32.000 | 2019-06-26 06:42:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:05 HD Request # 86 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:42:05 Socket (3) | Creating socket. | 2019-06-26 06:42:05 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:42:05 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:42:05 Socket (2) | Closed. | 2019-06-26 06:42:05 HD Request # 86 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:05 HD Request # 86 | Sending historical data logon request message. | 2019-06-26 06:42:05 HD Request # 85 | Receiving Intraday data for ESU9-CME starting at 2019-06-26 06:41:32 | 2019-06-26 06:42:05 HD Request # 85 | Timestamp of first Intraday data file record written: 2019-06-26 06:41:33 | 2019-06-26 06:42:05 HD Request # 85 | Received 34 records from 2019-06-26 06:41:32.000 to 2019-06-26 06:42:02.000 (30.0 seconds) and wrote 33 records for ESU9-CME | 2019-06-26 06:42:05 HD Request # 85 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 85 | Intraday data download complete for ESU9-CME. Unique request ID: 89 | 2019-06-26 06:42:05 Removed historical data download ID 89 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 06:42:05 Intraday chart data file opened for ESU9-CME | 2019-06-26 06:42:05 HD Request # 86 | Requesting Intraday data. Start date-time: 2019-06-26 06:41:32. Record interval: 0. Symbol: GCQ19 | 2019-06-26 06:42:05 HD Request # 86 | Decompressing data. | 2019-06-26 06:42:05 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:05 Historical data download thread signaled to stop. | 2019-06-26 06:42:05 HD Request # 86 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-26 06:42:05 HD Request # 86 | Completion time: 0s | 2019-06-26 06:42:05 HD Request # 86 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 81 | 2019-06-26 06:42:05 Removed historical data download ID 81 | 2019-06-26 06:42:05 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 06:42:05 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 06:42:05 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-26 06:42:05 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 06:42:05 HD Request # 87 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-26 06:42:05 HD Request # 87 | Download start date-time: 2019-06-26 06:41:32.000 | 2019-06-26 06:42:05 HD Request # 87 | Sending historical data request. Start date-time: 2019-06-26 06:41:32. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-26 06:42:05 HD Request # 88 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-26 06:42:05 HD Request # 88 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 06:42:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:05 HD Request # 88 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:42:05 Socket (2) | Creating socket. | 2019-06-26 06:42:05 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:42:05 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:42:05 Socket (3) | Closed. | 2019-06-26 06:42:05 HD Request # 88 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:05 HD Request # 88 | Sending historical data logon request message. | 2019-06-26 06:42:05 HD Request # 88 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-26 06:42:06 HD Request # 87 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-26 06:41:32 | 2019-06-26 06:42:06 HD Request # 87 | Timestamp of first Intraday data file record written: 2019-06-26 06:41:33 | 2019-06-26 06:42:06 HD Request # 87 | Received 206 records from 2019-06-26 06:41:32.000 to 2019-06-26 06:42:05.003 (33.0 seconds) and wrote 198 records for GCQ9-COMEX | 2019-06-26 06:42:06 Added 1 Time and Sales records to Intraday data file for GCQ9-COMEX after download. | 2019-06-26 06:42:06 HD Request # 88 | Decompressing data. | 2019-06-26 06:42:06 HD Request # 87 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 87 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 90 | 2019-06-26 06:42:06 Removed historical data download ID 90 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 06:42:06 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 06:42:06 HD Request # 88 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-26 06:42:06 Historical data download thread signaled to stop. | 2019-06-26 06:42:06 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:06 HD Request # 88 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 06:42:06 HD Request # 88 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 88 | Intraday data download complete for RTYM9-CME. Unique request ID: 82 | 2019-06-26 06:42:06 Removed historical data download ID 82 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 06:42:06 Intraday chart data file opened for RTYM9-CME | 2019-06-26 06:42:06 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-26 06:42:06 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 06:42:06 HD Request # 89 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-26 06:42:06 HD Request # 89 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 06:42:06 HD Request # 89 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-26 06:42:06 HD Request # 90 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-26 06:42:06 HD Request # 90 | Download start date-time: 2019-06-26 06:41:29.000 | 2019-06-26 06:42:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:06 HD Request # 90 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:42:06 HD Request # 89 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:42:06 Socket (3) | Creating socket. | 2019-06-26 06:42:06 HD Request # 89 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 06:42:06 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:42:06 HD Request # 89 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 89 | Intraday data download complete for RTYM9-CME. Unique request ID: 91 | 2019-06-26 06:42:06 Removed historical data download ID 91 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 06:42:06 Intraday chart data file opened for RTYM9-CME | 2019-06-26 06:42:06 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:42:06 Socket (2) | Closed. | 2019-06-26 06:42:06 HD Request # 90 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:06 HD Request # 90 | Sending historical data logon request message. | 2019-06-26 06:42:06 HD Request # 90 | Requesting Intraday data. Start date-time: 2019-06-26 06:41:29. Record interval: 0. Symbol: YMU19 | 2019-06-26 06:42:06 HD Request # 90 | Decompressing data. | 2019-06-26 06:42:06 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:06 Historical data download thread signaled to stop. | 2019-06-26 06:42:06 HD Request # 90 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-06-26 06:42:06 HD Request # 90 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 90 | Intraday data download complete for YMU9-CBOT. Unique request ID: 83 | 2019-06-26 06:42:06 Removed historical data download ID 83 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 06:42:06 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 06:42:06 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-26 06:42:06 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 06:42:06 HD Request # 91 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-26 06:42:06 HD Request # 91 | Download start date-time: 2019-06-26 06:41:29.000 | 2019-06-26 06:42:06 HD Request # 91 | Sending historical data request. Start date-time: 2019-06-26 06:41:29. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-26 06:42:06 HD Request # 92 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-26 06:42:06 HD Request # 92 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 06:42:06 HD Request # 92 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 06:42:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:06 Socket (2) | Creating socket. | 2019-06-26 06:42:06 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 06:42:06 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:42:06 Socket (3) | Closed. | 2019-06-26 06:42:06 HD Request # 92 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:06 HD Request # 92 | Sending historical data logon request message. | 2019-06-26 06:42:06 HD Request # 91 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-26 06:41:29 | 2019-06-26 06:42:06 HD Request # 91 | Timestamp of first Intraday data file record written: 2019-06-26 06:41:33 | 2019-06-26 06:42:06 HD Request # 91 | Received 27 records from 2019-06-26 06:41:29.000 to 2019-06-26 06:42:02.000 (33.0 seconds) and wrote 26 records for YMU9-CBOT | 2019-06-26 06:42:06 HD Request # 91 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 91 | Intraday data download complete for YMU9-CBOT. Unique request ID: 92 | 2019-06-26 06:42:06 Removed historical data download ID 92 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 06:42:06 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 06:42:06 HD Request # 92 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-26 06:42:06 HD Request # 92 | Decompressing data. | 2019-06-26 06:42:06 HD Request # 92 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-26 06:42:06 Historical data download thread signaled to stop. | 2019-06-26 06:42:06 HD Request # 92 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 06:42:06 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:06 HD Request # 92 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 92 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 84 | 2019-06-26 06:42:06 Removed historical data download ID 84 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 06:42:06 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 06:42:06 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-26 06:42:06 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 06:42:06 HD Request # 93 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 06:42:06 HD Request # 93 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 06:42:06 HD Request # 93 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-26 06:42:06 HD Request # 94 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-26 06:42:06 HD Request # 94 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 06:42:06 HD Request # 94 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 06:42:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:06 Socket (3) | Creating socket. | 2019-06-26 06:42:06 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 06:42:06 HD Request # 93 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:42:06 HD Request # 93 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 06:42:06 HD Request # 93 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 93 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 93 | 2019-06-26 06:42:06 Removed historical data download ID 93 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 06:42:06 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 06:42:06 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 06:42:06 Socket (2) | Closed. | 2019-06-26 06:42:06 HD Request # 94 | Setting DTC encoding to Binary VLS | 2019-06-26 06:42:06 HD Request # 94 | Sending historical data logon request message. | 2019-06-26 06:42:06 HD Request # 94 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-26 06:42:06 HD Request # 94 | Decompressing data. | 2019-06-26 06:42:06 HD Request # 94 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-26 06:42:06 Historical data download thread signaled to stop. | 2019-06-26 06:42:06 HD Request # 94 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 06:42:06 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 06:42:06 HD Request # 94 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 94 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 85 | 2019-06-26 06:42:06 Removed historical data download ID 85 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 06:42:06 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 06:42:06 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-26 06:42:06 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 06:42:06 HD Request # 95 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-26 06:42:06 HD Request # 95 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 06:42:06 HD Request # 95 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-26 06:42:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 06:42:06 HD Request # 95 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 06:42:06 HD Request # 95 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 06:42:06 HD Request # 95 | Completion time: 0s | 2019-06-26 06:42:06 HD Request # 95 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 94 | 2019-06-26 06:42:06 Removed historical data download ID 94 | 2019-06-26 06:42:06 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 06:42:06 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 06:42:06 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 06:42:06 Socket (3) | Closed. | 2019-06-26 06:42:06 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-26 06:42:08 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-26 06:42:11 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-26 06:42:11 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-26 06:42:14 GCQ9-COMEX [C] 60 Min #12 | Reloading chart. | 2019-06-26 07:00:22 GCQ9-COMEX [C] 60 Min #12 | StartDateTimeForLoadingOrderFills: 2018-06-27 00:00:00 | 2019-06-26 07:00:30 NGN9-NYMEX 2 Min #17 | Reloading chart. | 2019-06-26 08:30:42 NGN9-NYMEX 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NGN9-NYMEX.scid | 2019-06-26 08:30:42 Rithmic Trading | Starting real-time market data updates for: NGN9-NYMEX. ID: 10 Service code: rithmic.trading | 2019-06-26 08:30:43 Rithmic Trading | Requesting security definition data for: NGN9-NYMEX. ID: 10 | 2019-06-26 08:30:43 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGN9-NYMEX | 2019-06-26 08:30:43 Intraday data recording state for symbol NGN9-NYMEX is set to download 'Pending'. | 2019-06-26 08:30:43 Delaying start of download for NGN9-NYMEX | 2019-06-26 08:30:43 NGQ9-NYMEX 2 Min #17 | Reloading chart. | 2019-06-26 08:30:47 NGQ9-NYMEX 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NGQ9-NYMEX.scid | 2019-06-26 08:30:47 Rithmic Trading | Starting real-time market data updates for: NGQ9-NYMEX. ID: 11 Service code: rithmic.trading | 2019-06-26 08:30:47 Rithmic Trading | Requesting security definition data for: NGQ9-NYMEX. ID: 11 | 2019-06-26 08:30:47 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGQ9-NYMEX | 2019-06-26 08:30:47 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 08:30:47 HD Request # 96 | Downloading Intraday chart data for NGN9-NYMEX to the file NGN9-NYMEX.scid. Service: nymex | 2019-06-26 08:30:47 Compressing file: C:\SierraChart\Data\NGN9-NYMEX.scid. This may take a while. | 2019-06-26 08:30:47 HD Request # 96 | Download start date-time: 2018-12-22 07:30:47.000 | 2019-06-26 08:30:47 HD Request # 96 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:30:47 Socket (2) | Creating socket. | 2019-06-26 08:30:47 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:30:47 HD Request # 96 | Setting DTC encoding to Binary VLS | 2019-06-26 08:30:47 HD Request # 96 | Sending historical data logon request message. | 2019-06-26 08:30:47 HD Request # 96 | Requesting Intraday data. Start date-time: 2018-12-22 07:30:47. Record interval: 0. Symbol: NGN19 | 2019-06-26 08:30:47 HD Request # 96 | Decompressing data. | 2019-06-26 08:30:48 HD Request # 96 | Receiving Intraday data for NGN9-NYMEX starting at 2018-12-23 17:13:36 | 2019-06-26 08:30:48 HD Request # 96 | Timestamp of first Intraday data file record written: 2018-12-23 17:13:36 | 2019-06-26 08:30:48 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:30:55 Historical data download thread signaled to stop. | 2019-06-26 08:30:55 HD Request # 96 | Received 1678028 records from 2018-12-23 17:13:36.000 to 2019-06-26 08:20:41.000 (184.6 days) and wrote 1678028 records for NGN9-NYMEX | 2019-06-26 08:30:55 HD Request # 96 | Completion time: 8s | 2019-06-26 08:30:55 HD Request # 96 | Intraday data download complete for NGN9-NYMEX. Unique request ID: 95 | 2019-06-26 08:30:55 Removed historical data download ID 95 | 2019-06-26 08:30:55 Real-time Intraday chart data file updates started for NGN9-NYMEX | 2019-06-26 08:30:55 Intraday chart data file opened for NGN9-NYMEX | 2019-06-26 08:30:55 Rithmic Trading | Using primary service for historical data for NGN9-NYMEX | 2019-06-26 08:30:55 Intraday data recording state for symbol NGN9-NYMEX is set to download 'Pending'. | 2019-06-26 08:30:55 HD Request # 97 | Downloading Intraday chart data for NGN9-NYMEX to the file NGN9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 08:30:55 HD Request # 97 | Download start date-time: 2019-06-26 08:20:41.000 | 2019-06-26 08:30:55 HD Request # 97 | Sending historical data request. Start date-time: 2019-06-26 08:20:41. Record interval: 0. Symbol: NGN9-NYMEX | 2019-06-26 08:30:55 HD Request # 98 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: nymex | 2019-06-26 08:30:55 Compressing file: C:\SierraChart\Data\NGQ9-NYMEX.scid. This may take a while. | 2019-06-26 08:30:55 HD Request # 98 | Download start date-time: 2018-12-22 07:30:55.000 | 2019-06-26 08:30:55 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:30:55 HD Request # 98 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:30:55 Socket (3) | Creating socket. | 2019-06-26 08:30:55 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:30:55 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:30:55 Socket (2) | Closed. | 2019-06-26 08:30:55 HD Request # 97 | Receiving Intraday data for NGN9-NYMEX starting at 2019-06-26 08:20:41 | 2019-06-26 08:30:55 HD Request # 97 | Timestamp of first Intraday data file record written: 2019-06-26 08:20:54 | 2019-06-26 08:30:55 HD Request # 97 | Received 22 records from 2019-06-26 08:20:41.000 to 2019-06-26 08:30:53.000 (10.2 minutes) and wrote 21 records for NGN9-NYMEX | 2019-06-26 08:30:55 HD Request # 98 | Setting DTC encoding to Binary VLS | 2019-06-26 08:30:56 HD Request # 98 | Sending historical data logon request message. | 2019-06-26 08:30:56 HD Request # 97 | Completion time: 0s | 2019-06-26 08:30:56 HD Request # 97 | Intraday data download complete for NGN9-NYMEX. Unique request ID: 97 | 2019-06-26 08:30:56 Removed historical data download ID 97 | 2019-06-26 08:30:56 Real-time Intraday chart data file updates started for NGN9-NYMEX | 2019-06-26 08:30:56 Intraday chart data file opened for NGN9-NYMEX | 2019-06-26 08:30:56 HD Request # 98 | Requesting Intraday data. Start date-time: 2018-12-22 07:30:55. Record interval: 0. Symbol: NGQ19 | 2019-06-26 08:30:56 HD Request # 98 | Decompressing data. | 2019-06-26 08:30:56 HD Request # 98 | Receiving Intraday data for NGQ9-NYMEX starting at 2018-12-23 23:25:52 | 2019-06-26 08:30:56 HD Request # 98 | Timestamp of first Intraday data file record written: 2018-12-23 23:25:52 | 2019-06-26 08:30:56 Opened cached Intraday file: C:\SierraChart\Data\NGN9-NYMEX.scid | 2019-06-26 08:31:04 Historical data download thread signaled to stop. | 2019-06-26 08:31:05 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:31:05 HD Request # 98 | Received 649252 records from 2018-12-23 23:25:52.000 to 2019-06-26 08:20:54.001 (184.3 days) and wrote 649252 records for NGQ9-NYMEX | 2019-06-26 08:31:05 HD Request # 98 | Completion time: 9s | 2019-06-26 08:31:05 HD Request # 98 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 96 | 2019-06-26 08:31:05 Removed historical data download ID 96 | 2019-06-26 08:31:05 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 08:31:05 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 08:31:05 Rithmic Trading | Using primary service for historical data for NGQ9-NYMEX | 2019-06-26 08:31:05 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 08:31:05 HD Request # 99 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 08:31:05 HD Request # 99 | Download start date-time: 2019-06-26 08:20:54.000 | 2019-06-26 08:31:05 HD Request # 99 | Sending historical data request. Start date-time: 2019-06-26 08:20:54. Record interval: 0. Symbol: NGQ9-NYMEX | 2019-06-26 08:31:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:31:05 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:31:05 Socket (3) | Closed. | 2019-06-26 08:31:05 HD Request # 99 | Receiving Intraday data for NGQ9-NYMEX starting at 2019-06-26 08:20:54 | 2019-06-26 08:31:05 HD Request # 99 | Timestamp of first Intraday data file record written: 2019-06-26 08:20:57 | 2019-06-26 08:31:05 HD Request # 99 | Received 857 records from 2019-06-26 08:20:54.000 to 2019-06-26 08:31:03.011 (10.2 minutes) and wrote 855 records for NGQ9-NYMEX | 2019-06-26 08:31:05 HD Request # 99 | Completion time: 1s | 2019-06-26 08:31:05 HD Request # 99 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 98 | 2019-06-26 08:31:05 Removed historical data download ID 98 | 2019-06-26 08:31:05 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 08:31:05 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 08:31:05 Opened cached Intraday file: C:\SierraChart\Data\NGQ9-NYMEX.scid | 2019-06-26 08:31:07 Rithmic Trading | Message from server: Server Alert: PnL Connection Broken | 2019-06-26 08:33:09 Rithmic Trading | Message from server: Deleting API object. | 2019-06-26 08:33:09 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2019-06-26 08:33:09 Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2019-06-26 08:33:09 Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2019-06-26 08:33:09 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 08:33:09 Connection to the external service has been lost. | 2019-06-26 08:33:09 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-06-26 08:33:09 DTC Client socket (1) | Closed. | 2019-06-26 08:33:09 Rithmic Trading | Disconnected. | 2019-06-26 08:33:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:09 Rithmic Trading | Port for executable: 52831 | 2019-06-26 08:33:11 Listening socket (1600). Port 52831 | Closed. | 2019-06-26 08:33:11 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:11 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52831. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:11 Rithmic Trading | Bridge process is not running! | 2019-06-26 08:33:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52831 | 2019-06-26 08:33:13 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:13 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:13 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 08:33:14 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 08:33:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:14 DTC Client socket (1) | Closed. | 2019-06-26 08:33:14 Rithmic Trading | Disconnected. | 2019-06-26 08:33:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:14 Rithmic Trading | Port for executable: 52838 | 2019-06-26 08:33:16 Listening socket (1520). Port 52838 | Closed. | 2019-06-26 08:33:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:16 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52838. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:16 Rithmic Trading | Bridge process is not running! | 2019-06-26 08:33:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52838 | 2019-06-26 08:33:18 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:18 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:18 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 08:33:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 08:33:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:19 DTC Client socket (1) | Closed. | 2019-06-26 08:33:19 Rithmic Trading | Disconnected. | 2019-06-26 08:33:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:19 Rithmic Trading | Port for executable: 52843 | 2019-06-26 08:33:21 Listening socket (1520). Port 52843 | Closed. | 2019-06-26 08:33:21 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:21 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52843. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:21 Rithmic Trading | Bridge process is not running! | 2019-06-26 08:33:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52843 | 2019-06-26 08:33:23 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:23 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:23 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 08:33:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 08:33:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:24 DTC Client socket (1) | Closed. | 2019-06-26 08:33:24 Rithmic Trading | Disconnected. | 2019-06-26 08:33:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:24 Rithmic Trading | Port for executable: 52845 | 2019-06-26 08:33:26 Listening socket (1332). Port 52845 | Closed. | 2019-06-26 08:33:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:26 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52845. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:26 Rithmic Trading | Bridge process is not running! | 2019-06-26 08:33:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52845 | 2019-06-26 08:33:28 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:28 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:28 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 08:33:29 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 08:33:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:29 DTC Client socket (1) | Closed. | 2019-06-26 08:33:29 Rithmic Trading | Disconnected. | 2019-06-26 08:33:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:30 Rithmic Trading | Port for executable: 52847 | 2019-06-26 08:33:32 Listening socket (1332). Port 52847 | Closed. | 2019-06-26 08:33:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:32 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52847. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:32 Rithmic Trading | Bridge process is not running! | 2019-06-26 08:33:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52847 | 2019-06-26 08:33:34 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:34 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:34 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 08:33:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 08:33:35 DTC Client socket (1) | Closed. | 2019-06-26 08:33:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:35 Rithmic Trading | Disconnected. | 2019-06-26 08:33:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 08:33:35 Rithmic Trading | Port for executable: 52849 | 2019-06-26 08:33:37 Listening socket (1332). Port 52849 | Closed. | 2019-06-26 08:33:37 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 08:33:37 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52849. Current folder: C:\SierraChart\Rim | 2019-06-26 08:33:37 Rithmic Trading | Bridge process is running. | 2019-06-26 08:33:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52849 | 2019-06-26 08:33:39 DTC Client socket (1) | Creating socket. | 2019-06-26 08:33:39 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 08:33:39 Rithmic Trading | Connected to server. | 2019-06-26 08:33:39 Rithmic Trading | Starting socket receive thread. | 2019-06-26 08:33:39 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 08:33:39 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:39 Rithmic Trading | Sending logon request message. | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-26 08:33:39 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-26 08:33:40 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-26 08:33:40 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-26 08:33:40 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-26 08:33:40 Rithmic Trading | Received logon response. | 2019-06-26 08:33:41 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-26 08:33:41 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-26 08:33:41 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-26 08:33:41 Rithmic Trading | Trading is supported. | 2019-06-26 08:33:41 Rithmic Trading | Order cancel and replace is supported. | 2019-06-26 08:33:41 Rithmic Trading | OCO Orders supported. | 2019-06-26 08:33:41 Rithmic Trading | Connected to data and trading server. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 1 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 1 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-26 08:33:41 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 08:33:41 Delaying start of download for GCQ9-COMEX | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 2 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 2 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-26 08:33:41 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 3 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 3 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-26 08:33:41 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 4 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 4 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-26 08:33:41 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 5 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 5 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-26 08:33:41 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 6 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 6 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-26 08:33:41 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 7 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 7 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-26 08:33:41 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 8 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 8 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-26 08:33:41 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 9 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 9 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-26 08:33:41 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-26 08:33:41 Rithmic Trading | Starting real-time market data updates for: NGQ9-NYMEX. ID: 10 Service code: rithmic.trading | 2019-06-26 08:33:41 Rithmic Trading | Requesting security definition data for: NGQ9-NYMEX. ID: 10 | 2019-06-26 08:33:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGQ9-NYMEX | 2019-06-26 08:33:41 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 08:33:41 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 08:33:41 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-26 08:33:41 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-26 08:33:41 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 08:33:41 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-26 08:33:41 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-26 08:33:41 HD Request # 100 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-26 08:33:45 HD Request # 100 | Download start date-time: 2019-06-26 08:33:08.000 | 2019-06-26 08:33:45 HD Request # 100 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:33:45 Socket (2) | Creating socket. | 2019-06-26 08:33:45 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:33:45 HD Request # 100 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:45 HD Request # 100 | Sending historical data logon request message. | 2019-06-26 08:33:45 HD Request # 100 | Requesting Intraday data. Start date-time: 2019-06-26 08:33:08. Record interval: 0. Symbol: GCQ19 | 2019-06-26 08:33:45 HD Request # 100 | Decompressing data. | 2019-06-26 08:33:45 Historical data download thread signaled to stop. | 2019-06-26 08:33:45 HD Request # 100 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-26 08:33:45 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:45 HD Request # 100 | Completion time: 0s | 2019-06-26 08:33:45 HD Request # 100 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 99 | 2019-06-26 08:33:45 Removed historical data download ID 99 | 2019-06-26 08:33:45 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 08:33:45 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 08:33:45 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-26 08:33:45 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 08:33:45 HD Request # 101 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-26 08:33:45 HD Request # 101 | Download start date-time: 2019-06-26 08:33:08.000 | 2019-06-26 08:33:45 HD Request # 101 | Sending historical data request. Start date-time: 2019-06-26 08:33:08. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-26 08:33:45 HD Request # 102 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-26 08:33:45 HD Request # 102 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 08:33:45 HD Request # 102 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:33:45 Socket (3) | Creating socket. | 2019-06-26 08:33:45 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:45 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:33:45 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:33:46 Socket (2) | Closed. | 2019-06-26 08:33:46 HD Request # 102 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:46 HD Request # 102 | Sending historical data logon request message. | 2019-06-26 08:33:46 HD Request # 101 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-26 08:33:08 | 2019-06-26 08:33:46 HD Request # 101 | Timestamp of first Intraday data file record written: 2019-06-26 08:33:09 | 2019-06-26 08:33:46 HD Request # 101 | Received 114 records from 2019-06-26 08:33:08.000 to 2019-06-26 08:33:44.001 (36.0 seconds) and wrote 113 records for GCQ9-COMEX | 2019-06-26 08:33:46 HD Request # 102 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-26 08:33:46 HD Request # 101 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 101 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 109 | 2019-06-26 08:33:46 Removed historical data download ID 109 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 08:33:46 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 08:33:46 HD Request # 102 | Decompressing data. | 2019-06-26 08:33:46 HD Request # 102 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-26 08:33:46 Historical data download thread signaled to stop. | 2019-06-26 08:33:46 HD Request # 102 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 08:33:46 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:46 HD Request # 102 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 102 | Intraday data download complete for 6CM9-CME. Unique request ID: 100 | 2019-06-26 08:33:46 Removed historical data download ID 100 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for 6CM9-CME | 2019-06-26 08:33:46 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-26 08:33:46 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 08:33:46 HD Request # 103 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-26 08:33:46 HD Request # 103 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 08:33:46 HD Request # 103 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-26 08:33:46 HD Request # 104 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-26 08:33:46 HD Request # 104 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:46 HD Request # 104 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:33:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:46 Socket (2) | Creating socket. | 2019-06-26 08:33:46 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:33:46 HD Request # 103 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 08:33:46 HD Request # 103 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 08:33:46 HD Request # 103 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 103 | Intraday data download complete for 6CM9-CME. Unique request ID: 110 | 2019-06-26 08:33:46 Removed historical data download ID 110 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for 6CM9-CME | 2019-06-26 08:33:46 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:33:46 Socket (3) | Closed. | 2019-06-26 08:33:46 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-26 08:33:46 HD Request # 104 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:46 HD Request # 104 | Sending historical data logon request message. | 2019-06-26 08:33:46 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-26 08:33:46 HD Request # 104 | Requesting Intraday data. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: NQU19 | 2019-06-26 08:33:46 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-26 08:33:46 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-26 08:33:46 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-26 08:33:46 HD Request # 104 | Decompressing data. | 2019-06-26 08:33:46 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:46 Historical data download thread signaled to stop. | 2019-06-26 08:33:46 HD Request # 104 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-26 08:33:46 HD Request # 104 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 104 | Intraday data download complete for NQU9-CME. Unique request ID: 101 | 2019-06-26 08:33:46 Removed historical data download ID 101 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for NQU9-CME | 2019-06-26 08:33:46 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-26 08:33:46 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 08:33:46 HD Request # 105 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-26 08:33:46 HD Request # 105 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:46 HD Request # 105 | Sending historical data request. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: NQU9-CME | 2019-06-26 08:33:46 HD Request # 106 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-26 08:33:46 HD Request # 106 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 08:33:46 HD Request # 106 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:33:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:46 Socket (3) | Creating socket. | 2019-06-26 08:33:46 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:33:46 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:33:46 Socket (2) | Closed. | 2019-06-26 08:33:46 HD Request # 106 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:46 HD Request # 106 | Sending historical data logon request message. | 2019-06-26 08:33:46 HD Request # 106 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-26 08:33:46 HD Request # 106 | Decompressing data. | 2019-06-26 08:33:46 HD Request # 106 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-26 08:33:46 Historical data download thread signaled to stop. | 2019-06-26 08:33:46 HD Request # 106 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 08:33:46 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:46 HD Request # 106 | Completion time: 1s | 2019-06-26 08:33:46 HD Request # 106 | Intraday data download complete for 6AM9-CME. Unique request ID: 102 | 2019-06-26 08:33:46 Removed historical data download ID 102 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for 6AM9-CME | 2019-06-26 08:33:46 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-26 08:33:46 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 08:33:46 HD Request # 107 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-26 08:33:46 HD Request # 107 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:46 HD Request # 107 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:33:46 Socket (2) | Creating socket. | 2019-06-26 08:33:46 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:33:46 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:33:46 Socket (3) | Closed. | 2019-06-26 08:33:46 HD Request # 105 | Receiving Intraday data for NQU9-CME starting at 2019-06-26 08:33:09 | 2019-06-26 08:33:46 HD Request # 105 | Timestamp of first Intraday data file record written: 2019-06-26 08:33:09 | 2019-06-26 08:33:46 HD Request # 105 | Received 1189 records from 2019-06-26 08:33:09.000 to 2019-06-26 08:33:46.007 (37.0 seconds) and wrote 1178 records for NQU9-CME | 2019-06-26 08:33:46 Added 3 Time and Sales records to Intraday data file for NQU9-CME after download. | 2019-06-26 08:33:46 HD Request # 105 | Completion time: 1s | 2019-06-26 08:33:46 HD Request # 105 | Intraday data download complete for NQU9-CME. Unique request ID: 111 | 2019-06-26 08:33:46 Removed historical data download ID 111 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for NQU9-CME | 2019-06-26 08:33:46 HD Request # 108 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-26 08:33:46 HD Request # 108 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 08:33:46 HD Request # 108 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-26 08:33:46 HD Request # 107 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:46 HD Request # 107 | Sending historical data logon request message. | 2019-06-26 08:33:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:46 HD Request # 108 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 08:33:46 HD Request # 108 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 08:33:46 HD Request # 108 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 108 | Intraday data download complete for 6AM9-CME. Unique request ID: 112 | 2019-06-26 08:33:46 Removed historical data download ID 112 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for 6AM9-CME | 2019-06-26 08:33:46 HD Request # 107 | Requesting Intraday data. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: ESU19 | 2019-06-26 08:33:46 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-26 08:33:46 HD Request # 107 | Decompressing data. | 2019-06-26 08:33:46 Historical data download thread signaled to stop. | 2019-06-26 08:33:46 HD Request # 107 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-06-26 08:33:46 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:46 HD Request # 107 | Completion time: 0s | 2019-06-26 08:33:46 HD Request # 107 | Intraday data download complete for ESU9-CME. Unique request ID: 103 | 2019-06-26 08:33:46 Removed historical data download ID 103 | 2019-06-26 08:33:46 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 08:33:46 Intraday chart data file opened for ESU9-CME | 2019-06-26 08:33:46 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-26 08:33:46 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 08:33:46 HD Request # 109 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-26 08:33:46 HD Request # 109 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:46 HD Request # 109 | Sending historical data request. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: ESU9-CME | 2019-06-26 08:33:46 HD Request # 110 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-26 08:33:46 HD Request # 110 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 08:33:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:46 HD Request # 110 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:33:46 Socket (3) | Creating socket. | 2019-06-26 08:33:46 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:33:46 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:33:46 Socket (2) | Closed. | 2019-06-26 08:33:46 HD Request # 110 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:47 HD Request # 110 | Sending historical data logon request message. | 2019-06-26 08:33:47 HD Request # 110 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-26 08:33:47 HD Request # 109 | Receiving Intraday data for ESU9-CME starting at 2019-06-26 08:33:09 | 2019-06-26 08:33:47 HD Request # 109 | Timestamp of first Intraday data file record written: 2019-06-26 08:33:09 | 2019-06-26 08:33:47 HD Request # 109 | Received 1646 records from 2019-06-26 08:33:09.000 to 2019-06-26 08:33:46.001 (37.0 seconds) and wrote 1644 records for ESU9-CME | 2019-06-26 08:33:47 HD Request # 109 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 109 | Intraday data download complete for ESU9-CME. Unique request ID: 113 | 2019-06-26 08:33:47 Removed historical data download ID 113 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 08:33:47 Intraday chart data file opened for ESU9-CME | 2019-06-26 08:33:47 HD Request # 110 | Decompressing data. | 2019-06-26 08:33:47 HD Request # 110 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-26 08:33:47 Historical data download thread signaled to stop. | 2019-06-26 08:33:47 HD Request # 110 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 08:33:47 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:47 HD Request # 110 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 110 | Intraday data download complete for RTYM9-CME. Unique request ID: 104 | 2019-06-26 08:33:47 Removed historical data download ID 104 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 08:33:47 Intraday chart data file opened for RTYM9-CME | 2019-06-26 08:33:47 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-26 08:33:47 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 08:33:47 HD Request # 111 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-26 08:33:47 HD Request # 111 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 08:33:47 HD Request # 111 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-26 08:33:47 HD Request # 112 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-26 08:33:47 HD Request # 112 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 08:33:47 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:47 HD Request # 112 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:33:47 Socket (2) | Creating socket. | 2019-06-26 08:33:47 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:33:47 HD Request # 111 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 08:33:47 HD Request # 111 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 08:33:47 HD Request # 111 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 111 | Intraday data download complete for RTYM9-CME. Unique request ID: 114 | 2019-06-26 08:33:47 Removed historical data download ID 114 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 08:33:47 Intraday chart data file opened for RTYM9-CME | 2019-06-26 08:33:47 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:33:47 Socket (3) | Closed. | 2019-06-26 08:33:47 HD Request # 112 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:47 HD Request # 112 | Sending historical data logon request message. | 2019-06-26 08:33:47 HD Request # 112 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-26 08:33:47 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-26 08:33:47 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-26 08:33:47 HD Request # 112 | Decompressing data. | 2019-06-26 08:33:47 HD Request # 112 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-26 08:33:47 Historical data download thread signaled to stop. | 2019-06-26 08:33:47 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:47 HD Request # 112 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 08:33:47 HD Request # 112 | Completion time: 1s | 2019-06-26 08:33:47 HD Request # 112 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 105 | 2019-06-26 08:33:47 Removed historical data download ID 105 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 08:33:47 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 08:33:47 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-26 08:33:47 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 08:33:47 HD Request # 113 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 08:33:47 HD Request # 113 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 08:33:47 HD Request # 113 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-26 08:33:47 HD Request # 114 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-26 08:33:47 HD Request # 114 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 08:33:47 HD Request # 114 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:33:47 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:47 Socket (3) | Creating socket. | 2019-06-26 08:33:47 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:33:47 HD Request # 113 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 08:33:47 HD Request # 113 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 08:33:47 HD Request # 113 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 113 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 115 | 2019-06-26 08:33:47 Removed historical data download ID 115 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 08:33:47 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 08:33:47 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:33:47 Socket (2) | Closed. | 2019-06-26 08:33:47 HD Request # 114 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:47 HD Request # 114 | Sending historical data logon request message. | 2019-06-26 08:33:47 HD Request # 114 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-26 08:33:47 HD Request # 114 | Decompressing data. | 2019-06-26 08:33:47 HD Request # 114 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-26 08:33:47 Historical data download thread signaled to stop. | 2019-06-26 08:33:47 HD Request # 114 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 08:33:47 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:47 HD Request # 114 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 114 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 106 | 2019-06-26 08:33:47 Removed historical data download ID 106 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 08:33:47 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 08:33:47 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-26 08:33:47 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 08:33:47 HD Request # 115 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-26 08:33:47 HD Request # 115 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 08:33:47 HD Request # 115 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-26 08:33:47 HD Request # 116 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-26 08:33:47 HD Request # 116 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:47 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:47 HD Request # 116 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 08:33:47 HD Request # 115 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 08:33:47 Socket (2) | Creating socket. | 2019-06-26 08:33:47 HD Request # 115 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 08:33:47 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 08:33:47 HD Request # 115 | Completion time: 0s | 2019-06-26 08:33:47 HD Request # 115 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 116 | 2019-06-26 08:33:47 Removed historical data download ID 116 | 2019-06-26 08:33:47 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 08:33:47 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 08:33:47 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:33:47 Socket (3) | Closed. | 2019-06-26 08:33:47 HD Request # 116 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:47 HD Request # 116 | Sending historical data logon request message. | 2019-06-26 08:33:47 HD Request # 116 | Requesting Intraday data. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: YMU19 | 2019-06-26 08:33:47 HD Request # 116 | Decompressing data. | 2019-06-26 08:33:48 Historical data download thread signaled to stop. | 2019-06-26 08:33:48 HD Request # 116 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-06-26 08:33:48 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:48 HD Request # 116 | Completion time: 0s | 2019-06-26 08:33:48 HD Request # 116 | Intraday data download complete for YMU9-CBOT. Unique request ID: 107 | 2019-06-26 08:33:48 Removed historical data download ID 107 | 2019-06-26 08:33:48 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 08:33:48 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 08:33:48 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-26 08:33:48 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 08:33:48 HD Request # 117 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-26 08:33:48 HD Request # 117 | Download start date-time: 2019-06-26 08:33:09.000 | 2019-06-26 08:33:48 HD Request # 117 | Sending historical data request. Start date-time: 2019-06-26 08:33:09. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-26 08:33:48 HD Request # 118 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: nymex | 2019-06-26 08:33:48 HD Request # 118 | Download start date-time: 2019-06-26 08:33:03.000 | 2019-06-26 08:33:48 HD Request # 118 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 08:33:48 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:48 Socket (3) | Creating socket. | 2019-06-26 08:33:48 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 08:33:48 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 08:33:48 Socket (2) | Closed. | 2019-06-26 08:33:48 HD Request # 118 | Setting DTC encoding to Binary VLS | 2019-06-26 08:33:48 HD Request # 118 | Sending historical data logon request message. | 2019-06-26 08:33:48 HD Request # 117 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-26 08:33:09 | 2019-06-26 08:33:48 HD Request # 117 | Timestamp of first Intraday data file record written: 2019-06-26 08:33:09 | 2019-06-26 08:33:48 HD Request # 117 | Received 527 records from 2019-06-26 08:33:09.000 to 2019-06-26 08:33:47.005 (38.0 seconds) and wrote 526 records for YMU9-CBOT | 2019-06-26 08:33:48 Added 2 Time and Sales records to Intraday data file for YMU9-CBOT after download. | 2019-06-26 08:33:48 HD Request # 117 | Completion time: 0s | 2019-06-26 08:33:48 HD Request # 117 | Intraday data download complete for YMU9-CBOT. Unique request ID: 117 | 2019-06-26 08:33:48 Removed historical data download ID 117 | 2019-06-26 08:33:48 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 08:33:48 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 08:33:48 HD Request # 118 | Requesting Intraday data. Start date-time: 2019-06-26 08:33:03. Record interval: 0. Symbol: NGQ19 | 2019-06-26 08:33:48 HD Request # 118 | Decompressing data. | 2019-06-26 08:33:48 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 08:33:48 Historical data download thread signaled to stop. | 2019-06-26 08:33:48 HD Request # 118 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGQ9-NYMEX | 2019-06-26 08:33:48 HD Request # 118 | Completion time: 0s | 2019-06-26 08:33:48 HD Request # 118 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 108 | 2019-06-26 08:33:48 Removed historical data download ID 108 | 2019-06-26 08:33:48 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 08:33:48 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 08:33:48 Rithmic Trading | Using primary service for historical data for NGQ9-NYMEX | 2019-06-26 08:33:48 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 08:33:48 HD Request # 119 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 08:33:48 HD Request # 119 | Download start date-time: 2019-06-26 08:33:03.000 | 2019-06-26 08:33:48 HD Request # 119 | Sending historical data request. Start date-time: 2019-06-26 08:33:03. Record interval: 0. Symbol: NGQ9-NYMEX | 2019-06-26 08:33:48 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 08:33:48 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 08:33:48 Socket (3) | Closed. | 2019-06-26 08:33:48 HD Request # 119 | Receiving Intraday data for NGQ9-NYMEX starting at 2019-06-26 08:33:03 | 2019-06-26 08:33:48 HD Request # 119 | Timestamp of first Intraday data file record written: 2019-06-26 08:33:11 | 2019-06-26 08:33:48 HD Request # 119 | Received 70 records from 2019-06-26 08:33:03.000 to 2019-06-26 08:33:46.010 (43.0 seconds) and wrote 63 records for NGQ9-NYMEX | 2019-06-26 08:33:48 HD Request # 119 | Completion time: 0s | 2019-06-26 08:33:48 HD Request # 119 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 118 | 2019-06-26 08:33:48 Removed historical data download ID 118 | 2019-06-26 08:33:48 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 08:33:48 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 08:33:48 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-26 08:33:50 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-26 08:33:50 Opened cached Intraday file: C:\SierraChart\Data\NGQ9-NYMEX.scid | 2019-06-26 08:33:59 NQU9-CME 1 Min #2 | Reloading chart. | 2019-06-26 08:35:16 NQU9-CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-26 08:35:17 NQU9-CME 3 Min #2 | Reloading chart. | 2019-06-26 08:35:20 NQU9-CME 3 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-26 08:35:21 GCQ9-COMEX 1 Min #8 | Reloading chart. | 2019-06-26 08:35:53 GCQ9-COMEX 1 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-28 17:00:00 | 2019-06-26 08:35:54 NQU9-CME 30 Sec #1 | Reloading chart. | 2019-06-26 08:48:30 NQU9-CME 30 Sec #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-26 08:48:30 NQU9-CME 1 Min #1 | Reloading chart. | 2019-06-26 08:48:41 NQU9-CME 1 Min #1 | StartDateTimeForLoadingOrderFills: 2019-05-28 19:09:00 | 2019-06-26 08:48:42 Rithmic Trading | Message from server: Server Alert: Intraday History Connection - Heartbeat has been quiet for 40.969 seconds. | 2019-06-26 10:55:57 Rithmic Trading | Message from server: Server Alert: Trading System Connection - Heartbeat has been quiet for 48.738 seconds. | 2019-06-26 11:06:03 Rithmic Trading | Message from server: Deleting API object. | 2019-06-26 11:06:03 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2019-06-26 11:06:03 Rithmic Trading | Message from server: Server Alert: PnL Connection Closed | 2019-06-26 11:06:03 Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2019-06-26 11:06:03 Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2019-06-26 11:06:03 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 11:06:03 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-06-26 11:06:03 DTC Client socket (1) | Closed. | 2019-06-26 11:06:03 Connection to the external service has been lost. | 2019-06-26 11:06:03 Rithmic Trading | Disconnected. | 2019-06-26 11:06:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:03 Rithmic Trading | Port for executable: 56864 | 2019-06-26 11:06:05 Listening socket (1408). Port 56864 | Closed. | 2019-06-26 11:06:05 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:06:05 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56864. Current folder: C:\SierraChart\Rim | 2019-06-26 11:06:05 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:06:07 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56864 | 2019-06-26 11:06:07 DTC Client socket (1) | Creating socket. | 2019-06-26 11:06:07 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:06:07 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:06:08 * DTC Client socket (1) | Closed. | 2019-06-26 11:06:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:06:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:08 Rithmic Trading | Disconnected. | 2019-06-26 11:06:08 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:08 Rithmic Trading | Port for executable: 56871 | 2019-06-26 11:06:10 Listening socket (1952). Port 56871 | Closed. | 2019-06-26 11:06:10 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:06:10 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56871. Current folder: C:\SierraChart\Rim | 2019-06-26 11:06:10 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:06:12 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56871 | 2019-06-26 11:06:12 DTC Client socket (1) | Creating socket. | 2019-06-26 11:06:12 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:06:12 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:06:13 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:06:13 DTC Client socket (1) | Closed. | 2019-06-26 11:06:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:13 Rithmic Trading | Disconnected. | 2019-06-26 11:06:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:13 Rithmic Trading | Port for executable: 56873 | 2019-06-26 11:06:15 Listening socket (1528). Port 56873 | Closed. | 2019-06-26 11:06:15 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:06:15 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56873. Current folder: C:\SierraChart\Rim | 2019-06-26 11:06:15 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:06:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56873 | 2019-06-26 11:06:17 DTC Client socket (1) | Creating socket. | 2019-06-26 11:06:17 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:06:17 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:06:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:06:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:18 DTC Client socket (1) | Closed. | 2019-06-26 11:06:18 Rithmic Trading | Disconnected. | 2019-06-26 11:06:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:18 Rithmic Trading | Port for executable: 56877 | 2019-06-26 11:06:20 Listening socket (1520). Port 56877 | Closed. | 2019-06-26 11:06:20 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:06:20 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56877. Current folder: C:\SierraChart\Rim | 2019-06-26 11:06:20 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:06:22 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56877 | 2019-06-26 11:06:22 DTC Client socket (1) | Creating socket. | 2019-06-26 11:06:22 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:06:22 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:06:23 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:06:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:23 DTC Client socket (1) | Closed. | 2019-06-26 11:06:23 Rithmic Trading | Disconnected. | 2019-06-26 11:06:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:06:23 Rithmic Trading | Port for executable: 56879 | 2019-06-26 11:06:25 Listening socket (1436). Port 56879 | Closed. | 2019-06-26 11:06:25 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:06:25 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56879. Current folder: C:\SierraChart\Rim | 2019-06-26 11:06:25 Rithmic Trading | Bridge process is running. | 2019-06-26 11:06:27 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56879 | 2019-06-26 11:06:27 DTC Client socket (1) | Creating socket. | 2019-06-26 11:06:27 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:06:27 Rithmic Trading | Connected to server. | 2019-06-26 11:06:27 Rithmic Trading | Starting socket receive thread. | 2019-06-26 11:06:27 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 11:06:27 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 11:06:27 Rithmic Trading | Sending logon request message. | 2019-06-26 11:06:27 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 11:06:27 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 11:06:27 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 11:06:27 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:06:28 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 11:06:28 Service connection timed out. Will disconnect and retry. | 2019-06-26 11:08:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:08:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:25 Rithmic Trading | Disconnected. | 2019-06-26 11:08:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:25 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:08:25 Rithmic Trading | Port for executable: 56999 | 2019-06-26 11:08:27 Listening socket (1436). Port 56999 | Closed. | 2019-06-26 11:08:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:08:27 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56999. Current folder: C:\SierraChart\Rim | 2019-06-26 11:08:27 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:08:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56999 | 2019-06-26 11:08:29 DTC Client socket (2) | Creating socket. | 2019-06-26 11:08:29 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:08:29 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:08:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:08:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:30 DTC Client socket (2) | Closed. | 2019-06-26 11:08:30 Rithmic Trading | Disconnected. | 2019-06-26 11:08:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:30 Rithmic Trading | Port for executable: 57002 | 2019-06-26 11:08:32 Listening socket (1520). Port 57002 | Closed. | 2019-06-26 11:08:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:08:32 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57002. Current folder: C:\SierraChart\Rim | 2019-06-26 11:08:32 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:08:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57002 | 2019-06-26 11:08:34 DTC Client socket (2) | Creating socket. | 2019-06-26 11:08:34 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:08:34 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:08:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:08:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:36 DTC Client socket (2) | Closed. | 2019-06-26 11:08:36 Rithmic Trading | Disconnected. | 2019-06-26 11:08:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:36 Rithmic Trading | Port for executable: 57004 | 2019-06-26 11:08:38 Listening socket (1520). Port 57004 | Closed. | 2019-06-26 11:08:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:08:38 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57004. Current folder: C:\SierraChart\Rim | 2019-06-26 11:08:38 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:08:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57004 | 2019-06-26 11:08:40 DTC Client socket (2) | Creating socket. | 2019-06-26 11:08:40 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:08:40 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:08:41 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:08:41 DTC Client socket (2) | Closed. | 2019-06-26 11:08:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:41 Rithmic Trading | Disconnected. | 2019-06-26 11:08:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:41 Rithmic Trading | Port for executable: 57006 | 2019-06-26 11:08:43 Listening socket (1520). Port 57006 | Closed. | 2019-06-26 11:08:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:08:43 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57006. Current folder: C:\SierraChart\Rim | 2019-06-26 11:08:43 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:08:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57006 | 2019-06-26 11:08:45 DTC Client socket (2) | Creating socket. | 2019-06-26 11:08:45 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:08:45 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 11:08:45 DTC Client socket (1) | Closed. | 2019-06-26 11:08:45 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:08:46 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:08:46 DTC Client socket (2) | Closed. | 2019-06-26 11:08:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:46 Rithmic Trading | Disconnected. | 2019-06-26 11:08:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:08:46 Rithmic Trading | Port for executable: 57009 | 2019-06-26 11:08:48 Listening socket (1360). Port 57009 | Closed. | 2019-06-26 11:08:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:08:48 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57009. Current folder: C:\SierraChart\Rim | 2019-06-26 11:08:48 Rithmic Trading | Bridge process is running. | 2019-06-26 11:08:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57009 | 2019-06-26 11:08:50 DTC Client socket (1) | Creating socket. | 2019-06-26 11:08:50 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:08:50 Rithmic Trading | Connected to server. | 2019-06-26 11:08:50 Rithmic Trading | Starting socket receive thread. | 2019-06-26 11:08:50 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 11:08:50 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 11:08:50 Rithmic Trading | Sending logon request message. | 2019-06-26 11:08:50 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 11:08:50 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 11:08:50 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 11:08:50 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:08:50 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-06-26 11:09:30 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:09:31 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-06-26 11:10:11 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:10:11 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 11:10:11 Service connection timed out. Will disconnect and retry. | 2019-06-26 11:10:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:10:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:48 Rithmic Trading | Disconnected. | 2019-06-26 11:10:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:48 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:10:48 Rithmic Trading | Port for executable: 57111 | 2019-06-26 11:10:50 Listening socket (1360). Port 57111 | Closed. | 2019-06-26 11:10:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:10:50 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57111. Current folder: C:\SierraChart\Rim | 2019-06-26 11:10:50 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:10:52 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57111 | 2019-06-26 11:10:52 DTC Client socket (2) | Creating socket. | 2019-06-26 11:10:52 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:10:52 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:10:53 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:10:53 DTC Client socket (2) | Closed. | 2019-06-26 11:10:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:53 Rithmic Trading | Disconnected. | 2019-06-26 11:10:53 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:53 Rithmic Trading | Port for executable: 57115 | 2019-06-26 11:10:55 Listening socket (1988). Port 57115 | Closed. | 2019-06-26 11:10:55 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:10:55 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57115. Current folder: C:\SierraChart\Rim | 2019-06-26 11:10:55 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:10:57 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57115 | 2019-06-26 11:10:57 DTC Client socket (2) | Creating socket. | 2019-06-26 11:10:57 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:10:57 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:10:58 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:10:58 DTC Client socket (2) | Closed. | 2019-06-26 11:10:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:58 Rithmic Trading | Disconnected. | 2019-06-26 11:10:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:10:58 Rithmic Trading | Port for executable: 57117 | 2019-06-26 11:11:00 Listening socket (1840). Port 57117 | Closed. | 2019-06-26 11:11:00 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:11:00 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57117. Current folder: C:\SierraChart\Rim | 2019-06-26 11:11:00 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:11:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57117 | 2019-06-26 11:11:02 DTC Client socket (2) | Creating socket. | 2019-06-26 11:11:02 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:11:02 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:11:03 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:11:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:11:03 DTC Client socket (2) | Closed. | 2019-06-26 11:11:03 Rithmic Trading | Disconnected. | 2019-06-26 11:11:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:11:03 Rithmic Trading | Port for executable: 57120 | 2019-06-26 11:11:05 Listening socket (1588). Port 57120 | Closed. | 2019-06-26 11:11:05 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:11:05 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57120. Current folder: C:\SierraChart\Rim | 2019-06-26 11:11:05 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:11:07 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57120 | 2019-06-26 11:11:07 DTC Client socket (2) | Creating socket. | 2019-06-26 11:11:07 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:11:07 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 11:11:08 DTC Client socket (1) | Closed. | 2019-06-26 11:11:08 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:11:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:11:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:11:08 DTC Client socket (2) | Closed. | 2019-06-26 11:11:08 Rithmic Trading | Disconnected. | 2019-06-26 11:11:08 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:11:08 Rithmic Trading | Port for executable: 57122 | 2019-06-26 11:11:10 Listening socket (1588). Port 57122 | Closed. | 2019-06-26 11:11:10 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:11:10 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57122. Current folder: C:\SierraChart\Rim | 2019-06-26 11:11:10 Rithmic Trading | Bridge process is running. | 2019-06-26 11:11:12 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57122 | 2019-06-26 11:11:12 DTC Client socket (1) | Creating socket. | 2019-06-26 11:11:12 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:11:12 Rithmic Trading | Connected to server. | 2019-06-26 11:11:12 Rithmic Trading | Starting socket receive thread. | 2019-06-26 11:11:12 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 11:11:12 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 11:11:12 Rithmic Trading | Sending logon request message. | 2019-06-26 11:11:12 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 11:11:12 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 11:11:12 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 11:11:12 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:11:12 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-06-26 11:11:32 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:11:33 The message log has been sent to support. | 2019-06-26 11:11:41 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2019-06-26 11:11:41 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2019-06-26 11:11:41 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-06-26 11:11:42 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:11:42 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2019-06-26 11:11:43 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2019-06-26 11:11:43 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-06-26 11:12:13 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:12:13 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 11:12:13 Service connection timed out. Will disconnect and retry. | 2019-06-26 11:13:10 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:13:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:10 Rithmic Trading | Disconnected. | 2019-06-26 11:13:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:10 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:13:10 Rithmic Trading | Port for executable: 57305 | 2019-06-26 11:13:12 Listening socket (1588). Port 57305 | Closed. | 2019-06-26 11:13:12 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:13:12 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57305. Current folder: C:\SierraChart\Rim | 2019-06-26 11:13:12 Requested login tokens. | 2019-06-26 11:13:14 No available login tokens. Tokens being requested and automatic retry pending. | 2019-06-26 11:13:14 * HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2019-06-26 11:13:14 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Connecting to IP: 46.4.97.203. | 2019-06-26 11:13:14 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:13:14 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57305 | 2019-06-26 11:13:14 DTC Client socket (3) | Creating socket. | 2019-06-26 11:13:14 DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:13:14 Received 5 login tokens. | 2019-06-26 11:13:14 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:13:15 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2019-06-26 11:13:15 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Closed. | 2019-06-26 11:13:15 DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:13:15 * DTC Client socket (3) | Closed. | 2019-06-26 11:13:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:13:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:15 Rithmic Trading | Disconnected. | 2019-06-26 11:13:15 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:15 Rithmic Trading | Port for executable: 57316 | 2019-06-26 11:13:17 Listening socket (2476). Port 57316 | Closed. | 2019-06-26 11:13:17 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:13:17 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57316. Current folder: C:\SierraChart\Rim | 2019-06-26 11:13:17 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:13:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57316 | 2019-06-26 11:13:19 DTC Client socket (2) | Creating socket. | 2019-06-26 11:13:19 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:13:19 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:13:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:13:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:20 DTC Client socket (2) | Closed. | 2019-06-26 11:13:20 Rithmic Trading | Disconnected. | 2019-06-26 11:13:20 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:20 Rithmic Trading | Port for executable: 57320 | 2019-06-26 11:13:22 Listening socket (2504). Port 57320 | Closed. | 2019-06-26 11:13:22 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:13:22 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57320. Current folder: C:\SierraChart\Rim | 2019-06-26 11:13:22 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:13:24 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57320 | 2019-06-26 11:13:24 DTC Client socket (2) | Creating socket. | 2019-06-26 11:13:24 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:13:24 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:13:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:13:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:25 DTC Client socket (2) | Closed. | 2019-06-26 11:13:25 Rithmic Trading | Disconnected. | 2019-06-26 11:13:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:25 Rithmic Trading | Port for executable: 57322 | 2019-06-26 11:13:27 Listening socket (2476). Port 57322 | Closed. | 2019-06-26 11:13:27 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:13:27 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57322. Current folder: C:\SierraChart\Rim | 2019-06-26 11:13:27 Rithmic Trading | Bridge process is not running! | 2019-06-26 11:13:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57322 | 2019-06-26 11:13:29 DTC Client socket (2) | Creating socket. | 2019-06-26 11:13:29 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:13:29 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-26 11:13:30 DTC Client socket (1) | Closed. | 2019-06-26 11:13:30 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-26 11:13:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-26 11:13:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:30 DTC Client socket (2) | Closed. | 2019-06-26 11:13:30 Rithmic Trading | Disconnected. | 2019-06-26 11:13:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-26 11:13:30 Rithmic Trading | Port for executable: 57324 | 2019-06-26 11:13:32 Listening socket (2476). Port 57324 | Closed. | 2019-06-26 11:13:32 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-06-26 11:13:32 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57324. Current folder: C:\SierraChart\Rim | 2019-06-26 11:13:32 Rithmic Trading | Bridge process is running. | 2019-06-26 11:13:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57324 | 2019-06-26 11:13:34 DTC Client socket (1) | Creating socket. | 2019-06-26 11:13:34 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-26 11:13:34 Rithmic Trading | Connected to server. | 2019-06-26 11:13:34 Rithmic Trading | Starting socket receive thread. | 2019-06-26 11:13:34 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-06-26 11:13:34 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-06-26 11:13:34 Rithmic Trading | Sending logon request message. | 2019-06-26 11:13:34 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-06-26 11:13:34 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-06-26 11:13:34 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-06-26 11:13:34 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:13:35 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-06-26 11:14:10 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-06-26 11:14:10 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-06-26 11:14:10 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-06-26 11:14:31 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-06-26 11:14:31 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-06-26 11:14:31 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-06-26 11:14:31 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-06-26 11:14:31 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-06-26 11:14:32 Rithmic Trading | Received logon response. | 2019-06-26 11:14:32 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-06-26 11:14:32 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-06-26 11:14:32 Rithmic Trading | Successfully connected. IB='AGN', Firm='PhillipUS'. | 2019-06-26 11:14:32 Rithmic Trading | Trading is supported. | 2019-06-26 11:14:32 Rithmic Trading | Order cancel and replace is supported. | 2019-06-26 11:14:32 Rithmic Trading | OCO Orders supported. | 2019-06-26 11:14:32 Rithmic Trading | Connected to data and trading server. | 2019-06-26 11:14:32 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-06-26 11:14:32 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 1 Service code: rithmic.trading | 2019-06-26 11:14:32 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 1 | 2019-06-26 11:14:32 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-06-26 11:14:32 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 11:14:32 Delaying start of download for NQU9-CME | 2019-06-26 11:14:32 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 2 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 2 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-06-26 11:14:33 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: 6CM9-CME. ID: 3 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: 6CM9-CME. ID: 3 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CM9-CME | 2019-06-26 11:14:33 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: 6AM9-CME. ID: 4 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: 6AM9-CME. ID: 4 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6AM9-CME | 2019-06-26 11:14:33 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 5 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 5 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-06-26 11:14:33 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: RTYM9-CME. ID: 6 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: RTYM9-CME. ID: 6 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM9-CME | 2019-06-26 11:14:33 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: NGM9-NYMEX. ID: 7 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: NGM9-NYMEX. ID: 7 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGM9-NYMEX | 2019-06-26 11:14:33 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: ZNM9-CBOT. ID: 8 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: ZNM9-CBOT. ID: 8 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNM9-CBOT | 2019-06-26 11:14:33 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 9 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 9 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-06-26 11:14:33 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 11:14:33 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6CM9-CME | 2019-06-26 11:14:33 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: 6AM9-CME | 2019-06-26 11:14:33 Symbol Error - 6CM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 11:14:33 Symbol Error - 6AM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 11:14:33 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: RTYM9-CME | 2019-06-26 11:14:33 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: NGM9-NYMEX | 2019-06-26 11:14:33 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ZNM9-CBOT | 2019-06-26 11:14:33 Symbol Error - RTYM9-CME is unknown, unavailable, or improperly formatted. | 2019-06-26 11:14:33 Symbol Error - NGM9-NYMEX is unknown, unavailable, or improperly formatted. | 2019-06-26 11:14:33 Symbol Error - ZNM9-CBOT is unknown, unavailable, or improperly formatted. | 2019-06-26 11:14:33 Rithmic Trading | Starting real-time market data updates for: NGQ9-NYMEX. ID: 10 Service code: rithmic.trading | 2019-06-26 11:14:33 Rithmic Trading | Requesting security definition data for: NGQ9-NYMEX. ID: 10 | 2019-06-26 11:14:33 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGQ9-NYMEX | 2019-06-26 11:14:33 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 11:14:33 HD Request # 120 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-06-26 11:14:37 HD Request # 120 | Download start date-time: 2019-06-26 11:06:03.000 | 2019-06-26 11:14:37 HD Request # 120 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 11:14:37 Socket (2) | Creating socket. | 2019-06-26 11:14:37 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 11:14:37 HD Request # 120 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:37 HD Request # 120 | Sending historical data logon request message. | 2019-06-26 11:14:37 HD Request # 120 | Requesting Intraday data. Start date-time: 2019-06-26 11:06:03. Record interval: 0. Symbol: NQU19 | 2019-06-26 11:14:39 HD Request # 120 | Decompressing data. | 2019-06-26 11:14:39 Historical data download thread signaled to stop. | 2019-06-26 11:14:40 HD Request # 120 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-06-26 11:14:40 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:40 HD Request # 120 | Completion time: 2s | 2019-06-26 11:14:40 HD Request # 120 | Intraday data download complete for NQU9-CME. Unique request ID: 119 | 2019-06-26 11:14:40 Removed historical data download ID 119 | 2019-06-26 11:14:40 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 11:14:40 Intraday chart data file opened for NQU9-CME | 2019-06-26 11:14:40 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-06-26 11:14:40 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-06-26 11:14:40 HD Request # 121 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-06-26 11:14:40 HD Request # 121 | Download start date-time: 2019-06-26 11:06:03.000 | 2019-06-26 11:14:40 HD Request # 121 | Sending historical data request. Start date-time: 2019-06-26 11:06:03. Record interval: 0. Symbol: NQU9-CME | 2019-06-26 11:14:40 HD Request # 122 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-06-26 11:14:40 HD Request # 122 | Download start date-time: 2019-06-26 11:06:02.000 | 2019-06-26 11:14:40 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:40 HD Request # 122 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 11:14:40 Socket (3) | Creating socket. | 2019-06-26 11:14:40 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 11:14:40 HD Request # 122 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:40 HD Request # 122 | Sending historical data logon request message. | 2019-06-26 11:14:40 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 11:14:40 Socket (2) | Closed. | 2019-06-26 11:14:40 HD Request # 122 | Requesting Intraday data. Start date-time: 2019-06-26 11:06:02. Record interval: 0. Symbol: GCQ19 | 2019-06-26 11:14:40 HD Request # 122 | Decompressing data. | 2019-06-26 11:14:40 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:40 Historical data download thread signaled to stop. | 2019-06-26 11:14:40 HD Request # 122 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-06-26 11:14:40 HD Request # 122 | Completion time: 0s | 2019-06-26 11:14:40 HD Request # 122 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 120 | 2019-06-26 11:14:40 Removed historical data download ID 120 | 2019-06-26 11:14:40 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 11:14:40 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 11:14:40 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-06-26 11:14:40 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-06-26 11:14:40 HD Request # 123 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: cme | 2019-06-26 11:14:40 HD Request # 123 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 11:14:40 HD Request # 123 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 11:14:40 Socket (2) | Creating socket. | 2019-06-26 11:14:40 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 11:14:40 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 11:14:40 Socket (3) | Closed. | 2019-06-26 11:14:40 HD Request # 123 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:42 HD Request # 123 | Sending historical data logon request message. | 2019-06-26 11:14:42 HD Request # 123 | Requesting Intraday data. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM19 | 2019-06-26 11:14:42 HD Request # 123 | Decompressing data. | 2019-06-26 11:14:43 HD Request # 123 | Receiving Intraday data for 6CM9-CME starting at 2019-06-18 09:07:18 | 2019-06-26 11:14:43 Historical data download thread signaled to stop. | 2019-06-26 11:14:43 HD Request # 123 | Received 3 records from 2019-06-18 09:07:18.000 to 2019-06-18 09:07:18.002 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 11:14:43 HD Request # 123 | Completion time: 4s | 2019-06-26 11:14:43 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:43 HD Request # 123 | Intraday data download complete for 6CM9-CME. Unique request ID: 121 | 2019-06-26 11:14:43 Removed historical data download ID 121 | 2019-06-26 11:14:43 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 11:14:43 Intraday chart data file opened for 6CM9-CME | 2019-06-26 11:14:43 Rithmic Trading | Using primary service for historical data for 6CM9-CME | 2019-06-26 11:14:43 Intraday data recording state for symbol 6CM9-CME is set to download 'Pending'. | 2019-06-26 11:14:43 HD Request # 124 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: cme | 2019-06-26 11:14:43 HD Request # 124 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 11:14:43 HD Request # 124 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 11:14:43 Socket (3) | Creating socket. | 2019-06-26 11:14:43 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 11:14:43 HD Request # 124 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:43 HD Request # 124 | Sending historical data logon request message. | 2019-06-26 11:14:43 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 11:14:43 Socket (2) | Closed. | 2019-06-26 11:14:43 HD Request # 124 | Requesting Intraday data. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM19 | 2019-06-26 11:14:43 HD Request # 124 | Decompressing data. | 2019-06-26 11:14:43 HD Request # 124 | Receiving Intraday data for 6AM9-CME starting at 2019-06-17 09:10:01 | 2019-06-26 11:14:43 Historical data download thread signaled to stop. | 2019-06-26 11:14:43 HD Request # 124 | Received 1 record from 2019-06-17 09:10:01.000 to 2019-06-17 09:10:01.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 11:14:43 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:43 HD Request # 124 | Completion time: 0s | 2019-06-26 11:14:43 HD Request # 124 | Intraday data download complete for 6AM9-CME. Unique request ID: 122 | 2019-06-26 11:14:43 Removed historical data download ID 122 | 2019-06-26 11:14:43 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 11:14:43 Intraday chart data file opened for 6AM9-CME | 2019-06-26 11:14:43 Rithmic Trading | Using primary service for historical data for 6AM9-CME | 2019-06-26 11:14:43 Intraday data recording state for symbol 6AM9-CME is set to download 'Pending'. | 2019-06-26 11:14:43 HD Request # 125 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-06-26 11:14:43 HD Request # 125 | Download start date-time: 2019-06-26 11:06:01.000 | 2019-06-26 11:14:43 HD Request # 125 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 11:14:43 Socket (2) | Creating socket. | 2019-06-26 11:14:43 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 11:14:43 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 11:14:43 Socket (3) | Closed. | 2019-06-26 11:14:43 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-26 11:14:43 HD Request # 125 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:43 HD Request # 125 | Sending historical data logon request message. | 2019-06-26 11:14:43 HD Request # 121 | Receiving Intraday data for NQU9-CME starting at 2019-06-26 11:06:03 | 2019-06-26 11:14:43 HD Request # 121 | Timestamp of first Intraday data file record written: 2019-06-26 11:06:04 | 2019-06-26 11:14:43 HD Request # 121 | Received 2282 records from 2019-06-26 11:06:03.000 to 2019-06-26 11:14:40.000 (8.6 minutes) and wrote 2279 records for NQU9-CME | 2019-06-26 11:14:43 Added 4 Time and Sales records to Intraday data file for NQU9-CME after download. | 2019-06-26 11:14:44 HD Request # 121 | Completion time: 4s | 2019-06-26 11:14:44 HD Request # 121 | Intraday data download complete for NQU9-CME. Unique request ID: 129 | 2019-06-26 11:14:44 Removed historical data download ID 129 | 2019-06-26 11:14:44 Real-time Intraday chart data file updates started for NQU9-CME | 2019-06-26 11:14:44 Intraday chart data file opened for NQU9-CME | 2019-06-26 11:14:44 HD Request # 126 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-06-26 11:14:44 HD Request # 126 | Download start date-time: 2019-06-26 11:06:02.000 | 2019-06-26 11:14:44 HD Request # 126 | Sending historical data request. Start date-time: 2019-06-26 11:06:02. Record interval: 0. Symbol: GCQ9-COMEX | 2019-06-26 11:14:44 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:44 HD Request # 125 | Requesting Intraday data. Start date-time: 2019-06-26 11:06:01. Record interval: 0. Symbol: ESU19 | 2019-06-26 11:14:44 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-26 11:14:44 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-26 11:14:44 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-26 11:14:44 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-26 11:14:44 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-26 11:14:44 HD Request # 125 | Decompressing data. | 2019-06-26 11:14:44 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:44 Historical data download thread signaled to stop. | 2019-06-26 11:14:44 HD Request # 125 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-06-26 11:14:44 HD Request # 125 | Completion time: 1s | 2019-06-26 11:14:44 HD Request # 125 | Intraday data download complete for ESU9-CME. Unique request ID: 123 | 2019-06-26 11:14:44 Removed historical data download ID 123 | 2019-06-26 11:14:44 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 11:14:44 Intraday chart data file opened for ESU9-CME | 2019-06-26 11:14:44 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-06-26 11:14:44 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-06-26 11:14:44 HD Request # 127 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: cme | 2019-06-26 11:14:44 HD Request # 127 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 11:14:44 HD Request # 127 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 11:14:44 Socket (3) | Creating socket. | 2019-06-26 11:14:44 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 11:14:44 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 11:14:44 Socket (2) | Closed. | 2019-06-26 11:14:44 HD Request # 127 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:44 HD Request # 127 | Sending historical data logon request message. | 2019-06-26 11:14:44 HD Request # 127 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM19 | 2019-06-26 11:14:44 HD Request # 127 | Decompressing data. | 2019-06-26 11:14:44 HD Request # 127 | Receiving Intraday data for RTYM9-CME starting at 2019-06-21 08:29:40 | 2019-06-26 11:14:44 Historical data download thread signaled to stop. | 2019-06-26 11:14:44 HD Request # 127 | Received 1 record from 2019-06-21 08:29:40.000 to 2019-06-21 08:29:40.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 11:14:44 HD Request # 127 | Completion time: 0s | 2019-06-26 11:14:44 HD Request # 127 | Intraday data download complete for RTYM9-CME. Unique request ID: 124 | 2019-06-26 11:14:44 Removed historical data download ID 124 | 2019-06-26 11:14:44 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 11:14:44 Intraday chart data file opened for RTYM9-CME | 2019-06-26 11:14:44 Rithmic Trading | Using primary service for historical data for RTYM9-CME | 2019-06-26 11:14:44 Intraday data recording state for symbol RTYM9-CME is set to download 'Pending'. | 2019-06-26 11:14:44 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:44 HD Request # 128 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: nymex | 2019-06-26 11:14:44 HD Request # 128 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 11:14:44 HD Request # 128 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 11:14:44 Socket (2) | Creating socket. | 2019-06-26 11:14:44 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 11:14:44 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 11:14:44 Socket (3) | Closed. | 2019-06-26 11:14:44 HD Request # 128 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:45 HD Request # 128 | Sending historical data logon request message. | 2019-06-26 11:14:45 HD Request # 126 | Receiving Intraday data for GCQ9-COMEX starting at 2019-06-26 11:06:02 | 2019-06-26 11:14:45 HD Request # 126 | Timestamp of first Intraday data file record written: 2019-06-26 11:06:03 | 2019-06-26 11:14:45 HD Request # 126 | Received 2366 records from 2019-06-26 11:06:02.000 to 2019-06-26 11:14:41.001 (8.7 minutes) and wrote 2340 records for GCQ9-COMEX | 2019-06-26 11:14:45 HD Request # 126 | Completion time: 0s | 2019-06-26 11:14:45 HD Request # 126 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 130 | 2019-06-26 11:14:45 Removed historical data download ID 130 | 2019-06-26 11:14:45 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-06-26 11:14:45 Intraday chart data file opened for GCQ9-COMEX | 2019-06-26 11:14:45 HD Request # 129 | Downloading Intraday chart data for 6CM9-CME to the file 6CM9-CME.scid. Service: rithmic.trading | 2019-06-26 11:14:45 HD Request # 129 | Download start date-time: 2019-06-18 09:07:18.000 | 2019-06-26 11:14:45 HD Request # 129 | Sending historical data request. Start date-time: 2019-06-18 09:07:18. Record interval: 0. Symbol: 6CM9-CME | 2019-06-26 11:14:45 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:45 HD Request # 129 | Error downloading historical Intraday data for 6CM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 11:14:45 HD Request # 129 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6CM9-CME | 2019-06-26 11:14:45 HD Request # 129 | Completion time: 0s | 2019-06-26 11:14:45 HD Request # 129 | Intraday data download complete for 6CM9-CME. Unique request ID: 131 | 2019-06-26 11:14:45 Removed historical data download ID 131 | 2019-06-26 11:14:45 Real-time Intraday chart data file updates started for 6CM9-CME | 2019-06-26 11:14:45 Intraday chart data file opened for 6CM9-CME | 2019-06-26 11:14:45 HD Request # 130 | Downloading Intraday chart data for 6AM9-CME to the file 6AM9-CME.scid. Service: rithmic.trading | 2019-06-26 11:14:45 HD Request # 130 | Download start date-time: 2019-06-17 09:10:01.000 | 2019-06-26 11:14:45 HD Request # 130 | Sending historical data request. Start date-time: 2019-06-17 09:10:01. Record interval: 0. Symbol: 6AM9-CME | 2019-06-26 11:14:45 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:45 HD Request # 130 | Error downloading historical Intraday data for 6AM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 11:14:45 HD Request # 130 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6AM9-CME | 2019-06-26 11:14:45 HD Request # 130 | Completion time: 0s | 2019-06-26 11:14:45 HD Request # 130 | Intraday data download complete for 6AM9-CME. Unique request ID: 132 | 2019-06-26 11:14:45 Removed historical data download ID 132 | 2019-06-26 11:14:45 Real-time Intraday chart data file updates started for 6AM9-CME | 2019-06-26 11:14:45 Intraday chart data file opened for 6AM9-CME | 2019-06-26 11:14:45 HD Request # 131 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-06-26 11:14:45 HD Request # 131 | Download start date-time: 2019-06-26 11:06:01.000 | 2019-06-26 11:14:45 HD Request # 131 | Sending historical data request. Start date-time: 2019-06-26 11:06:01. Record interval: 0. Symbol: ESU9-CME | 2019-06-26 11:14:45 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:45 HD Request # 128 | Requesting Intraday data. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM19 | 2019-06-26 11:14:45 Opened cached Intraday file: C:\SierraChart\Data\NQU9-CME.scid | 2019-06-26 11:14:45 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACENQ.cht | 2019-06-26 11:14:45 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEGC.cht | 2019-06-26 11:14:45 Chart #4 has tagged chart #10 for full recalculation. Chartbook: ChartbookACEES.cht | 2019-06-26 11:14:45 YMU9-CBOT 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEGC.cht | 2019-06-26 11:14:45 NQU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACENQ.cht | 2019-06-26 11:14:45 HD Request # 128 | Decompressing data. | 2019-06-26 11:14:45 ESU9-CME 3 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ChartbookACEES.cht | 2019-06-26 11:14:45 HD Request # 131 | Receiving Intraday data for ESU9-CME starting at 2019-06-26 11:06:01 | 2019-06-26 11:14:46 HD Request # 131 | Timestamp of first Intraday data file record written: 2019-06-26 11:06:04 | 2019-06-26 11:14:46 HD Request # 131 | Received 4670 records from 2019-06-26 11:06:01.000 to 2019-06-26 11:14:44.001 (8.7 minutes) and wrote 4661 records for ESU9-CME | 2019-06-26 11:14:46 Added 1 Time and Sales records to Intraday data file for ESU9-CME after download. | 2019-06-26 11:14:46 HD Request # 131 | Completion time: 1s | 2019-06-26 11:14:46 HD Request # 131 | Intraday data download complete for ESU9-CME. Unique request ID: 133 | 2019-06-26 11:14:46 Removed historical data download ID 133 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for ESU9-CME | 2019-06-26 11:14:46 Intraday chart data file opened for ESU9-CME | 2019-06-26 11:14:46 HD Request # 132 | Downloading Intraday chart data for RTYM9-CME to the file RTYM9-CME.scid. Service: rithmic.trading | 2019-06-26 11:14:46 HD Request # 132 | Download start date-time: 2019-06-21 08:29:40.000 | 2019-06-26 11:14:46 HD Request # 132 | Sending historical data request. Start date-time: 2019-06-21 08:29:40. Record interval: 0. Symbol: RTYM9-CME | 2019-06-26 11:14:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:46 HD Request # 132 | Error downloading historical Intraday data for RTYM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 11:14:46 HD Request # 132 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYM9-CME | 2019-06-26 11:14:46 HD Request # 132 | Completion time: 0s | 2019-06-26 11:14:46 HD Request # 132 | Intraday data download complete for RTYM9-CME. Unique request ID: 134 | 2019-06-26 11:14:46 Removed historical data download ID 134 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for RTYM9-CME | 2019-06-26 11:14:46 Intraday chart data file opened for RTYM9-CME | 2019-06-26 11:14:46 HD Request # 128 | Receiving Intraday data for NGM9-NYMEX starting at 2019-05-29 13:29:53 | 2019-06-26 11:14:46 Historical data download thread signaled to stop. | 2019-06-26 11:14:46 HD Request # 128 | Received 1 record from 2019-05-29 13:29:53.000 to 2019-05-29 13:29:53.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 11:14:46 HD Request # 128 | Completion time: 1s | 2019-06-26 11:14:46 HD Request # 128 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 125 | 2019-06-26 11:14:46 Removed historical data download ID 125 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 11:14:46 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:46 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 11:14:46 Rithmic Trading | Using primary service for historical data for NGM9-NYMEX | 2019-06-26 11:14:46 Intraday data recording state for symbol NGM9-NYMEX is set to download 'Pending'. | 2019-06-26 11:14:46 HD Request # 133 | Downloading Intraday chart data for NGM9-NYMEX to the file NGM9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 11:14:46 HD Request # 133 | Download start date-time: 2019-05-29 13:29:53.000 | 2019-06-26 11:14:46 HD Request # 133 | Sending historical data request. Start date-time: 2019-05-29 13:29:53. Record interval: 0. Symbol: NGM9-NYMEX | 2019-06-26 11:14:46 HD Request # 134 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: cbot | 2019-06-26 11:14:46 HD Request # 134 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 11:14:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:46 HD Request # 134 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 11:14:46 HD Request # 133 | Error downloading historical Intraday data for NGM9-NYMEX. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 11:14:46 Socket (3) | Creating socket. | 2019-06-26 11:14:46 HD Request # 133 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGM9-NYMEX | 2019-06-26 11:14:46 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 11:14:46 HD Request # 133 | Completion time: 0s | 2019-06-26 11:14:46 HD Request # 133 | Intraday data download complete for NGM9-NYMEX. Unique request ID: 135 | 2019-06-26 11:14:46 Removed historical data download ID 135 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for NGM9-NYMEX | 2019-06-26 11:14:46 Intraday chart data file opened for NGM9-NYMEX | 2019-06-26 11:14:46 HD Request # 134 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:46 HD Request # 134 | Sending historical data logon request message. | 2019-06-26 11:14:46 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 11:14:46 Socket (2) | Closed. | 2019-06-26 11:14:46 HD Request # 134 | Requesting Intraday data. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM19 | 2019-06-26 11:14:46 HD Request # 134 | Decompressing data. | 2019-06-26 11:14:46 HD Request # 134 | Receiving Intraday data for ZNM9-CBOT starting at 2019-06-19 12:00:59 | 2019-06-26 11:14:46 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:46 Historical data download thread signaled to stop. | 2019-06-26 11:14:46 HD Request # 134 | Received 1 record from 2019-06-19 12:00:59.000 to 2019-06-19 12:00:59.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 11:14:46 HD Request # 134 | Completion time: 0s | 2019-06-26 11:14:46 HD Request # 134 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 126 | 2019-06-26 11:14:46 Removed historical data download ID 126 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 11:14:46 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 11:14:46 Rithmic Trading | Using primary service for historical data for ZNM9-CBOT | 2019-06-26 11:14:46 Intraday data recording state for symbol ZNM9-CBOT is set to download 'Pending'. | 2019-06-26 11:14:46 HD Request # 135 | Downloading Intraday chart data for ZNM9-CBOT to the file ZNM9-CBOT.scid. Service: rithmic.trading | 2019-06-26 11:14:46 HD Request # 135 | Download start date-time: 2019-06-19 12:00:59.000 | 2019-06-26 11:14:46 HD Request # 135 | Sending historical data request. Start date-time: 2019-06-19 12:00:59. Record interval: 0. Symbol: ZNM9-CBOT | 2019-06-26 11:14:46 HD Request # 136 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-06-26 11:14:46 HD Request # 136 | Download start date-time: 2019-06-26 11:06:01.000 | 2019-06-26 11:14:46 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:46 HD Request # 136 | Using server: ds1.sierracharts.com port 10149 | 2019-06-26 11:14:46 Socket (2) | Creating socket. | 2019-06-26 11:14:46 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-06-26 11:14:46 HD Request # 135 | Error downloading historical Intraday data for ZNM9-CBOT. Error requesting historical Tick data. Error: API_NO_DATA | 2019-06-26 11:14:46 HD Request # 135 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNM9-CBOT | 2019-06-26 11:14:46 HD Request # 135 | Completion time: 0s | 2019-06-26 11:14:46 HD Request # 135 | Intraday data download complete for ZNM9-CBOT. Unique request ID: 136 | 2019-06-26 11:14:46 Removed historical data download ID 136 | 2019-06-26 11:14:46 Real-time Intraday chart data file updates started for ZNM9-CBOT | 2019-06-26 11:14:46 Intraday chart data file opened for ZNM9-CBOT | 2019-06-26 11:14:46 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 11:14:46 Socket (3) | Closed. | 2019-06-26 11:14:46 HD Request # 136 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:46 HD Request # 136 | Sending historical data logon request message. | 2019-06-26 11:14:46 HD Request # 136 | Requesting Intraday data. Start date-time: 2019-06-26 11:06:01. Record interval: 0. Symbol: YMU19 | 2019-06-26 11:14:46 HD Request # 136 | Decompressing data. | 2019-06-26 11:14:47 Historical data download thread signaled to stop. | 2019-06-26 11:14:47 HD Request # 136 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-06-26 11:14:47 HD Request # 136 | Completion time: 0s | 2019-06-26 11:14:47 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:47 HD Request # 136 | Intraday data download complete for YMU9-CBOT. Unique request ID: 127 | 2019-06-26 11:14:47 Removed historical data download ID 127 | 2019-06-26 11:14:47 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 11:14:47 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 11:14:47 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-06-26 11:14:47 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-06-26 11:14:47 HD Request # 137 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-06-26 11:14:47 HD Request # 137 | Download start date-time: 2019-06-26 11:06:01.000 | 2019-06-26 11:14:47 HD Request # 137 | Sending historical data request. Start date-time: 2019-06-26 11:06:01. Record interval: 0. Symbol: YMU9-CBOT | 2019-06-26 11:14:47 HD Request # 138 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: nymex | 2019-06-26 11:14:47 HD Request # 138 | Download start date-time: 2019-06-26 11:06:02.000 | 2019-06-26 11:14:47 HD Request # 138 | Using server: ds7.sierracharts.com port 10150 | 2019-06-26 11:14:47 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:47 Socket (3) | Creating socket. | 2019-06-26 11:14:47 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-06-26 11:14:47 Socket (2) | Socket gracefully closed by remote side. | 2019-06-26 11:14:47 Socket (2) | Closed. | 2019-06-26 11:14:47 HD Request # 138 | Setting DTC encoding to Binary VLS | 2019-06-26 11:14:47 HD Request # 138 | Sending historical data logon request message. | 2019-06-26 11:14:47 HD Request # 138 | Requesting Intraday data. Start date-time: 2019-06-26 11:06:02. Record interval: 0. Symbol: NGQ19 | 2019-06-26 11:14:47 HD Request # 138 | Decompressing data. | 2019-06-26 11:14:47 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-06-26 11:14:47 Historical data download thread signaled to stop. | 2019-06-26 11:14:47 HD Request # 138 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NGQ9-NYMEX | 2019-06-26 11:14:47 HD Request # 138 | Completion time: 0s | 2019-06-26 11:14:47 HD Request # 138 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 128 | 2019-06-26 11:14:47 Removed historical data download ID 128 | 2019-06-26 11:14:47 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 11:14:47 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 11:14:47 Rithmic Trading | Using primary service for historical data for NGQ9-NYMEX | 2019-06-26 11:14:47 Intraday data recording state for symbol NGQ9-NYMEX is set to download 'Pending'. | 2019-06-26 11:14:47 Socket (3) | Socket gracefully closed by remote side. | 2019-06-26 11:14:47 Socket (3) | Closed. | 2019-06-26 11:14:47 HD Request # 137 | Receiving Intraday data for YMU9-CBOT starting at 2019-06-26 11:06:01 | 2019-06-26 11:14:47 HD Request # 137 | Timestamp of first Intraday data file record written: 2019-06-26 11:06:06 | 2019-06-26 11:14:47 HD Request # 137 | Received 1354 records from 2019-06-26 11:06:01.000 to 2019-06-26 11:14:46.001 (8.8 minutes) and wrote 1353 records for YMU9-CBOT | 2019-06-26 11:14:47 Added 16 Time and Sales records to Intraday data file for YMU9-CBOT after download. | 2019-06-26 11:14:47 HD Request # 137 | Completion time: 0s | 2019-06-26 11:14:47 HD Request # 137 | Intraday data download complete for YMU9-CBOT. Unique request ID: 137 | 2019-06-26 11:14:47 Removed historical data download ID 137 | 2019-06-26 11:14:47 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-06-26 11:14:47 Intraday chart data file opened for YMU9-CBOT | 2019-06-26 11:14:47 HD Request # 139 | Downloading Intraday chart data for NGQ9-NYMEX to the file NGQ9-NYMEX.scid. Service: rithmic.trading | 2019-06-26 11:14:47 HD Request # 139 | Download start date-time: 2019-06-26 11:06:02.000 | 2019-06-26 11:14:47 HD Request # 139 | Sending historical data request. Start date-time: 2019-06-26 11:06:02. Record interval: 0. Symbol: NGQ9-NYMEX | 2019-06-26 11:14:47 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-06-26 11:14:47 HD Request # 139 | Receiving Intraday data for NGQ9-NYMEX starting at 2019-06-26 11:06:02 | 2019-06-26 11:14:47 HD Request # 139 | Timestamp of first Intraday data file record written: 2019-06-26 11:06:06 | 2019-06-26 11:14:47 HD Request # 139 | Received 443 records from 2019-06-26 11:06:02.000 to 2019-06-26 11:14:39.000 (8.6 minutes) and wrote 431 records for NGQ9-NYMEX | 2019-06-26 11:14:47 HD Request # 139 | Completion time: 0s | 2019-06-26 11:14:47 HD Request # 139 | Intraday data download complete for NGQ9-NYMEX. Unique request ID: 138 | 2019-06-26 11:14:47 Removed historical data download ID 138 | 2019-06-26 11:14:47 Real-time Intraday chart data file updates started for NGQ9-NYMEX | 2019-06-26 11:14:47 Intraday chart data file opened for NGQ9-NYMEX | 2019-06-26 11:14:47 Opened cached Intraday file: C:\SierraChart\Data\GCQ9-COMEX.scid | 2019-06-26 11:14:48 Opened cached Intraday file: C:\SierraChart\Data\ESU9-CME.scid | 2019-06-26 11:14:48 Opened cached Intraday file: C:\SierraChart\Data\YMU9-CBOT.scid | 2019-06-26 11:14:51 Opened cached Intraday file: C:\SierraChart\Data\NGQ9-NYMEX.scid | 2019-06-26 11:15:00 s |
[2019-06-27 04:58:34] |
We see you are using Rithmic. Rithmic apparently had a problem with one of their servers today since we have other reports of a connectivity problem as well with Rithmic. We cannot solve Rithmic connectivity issues. For more information about this, refer to: https://www.sierrachart.com/index.php?page=doc/Rithmic.php#TechnicalSupportPolicy We recommend in the month of July that you change to this new service: Sierra Chart / Trading Technologies Futures Order Routing Service We would like to help you migrate over to our new order routing solution. We can do that anytime next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
